GPS Logo
A
Anonymous Posted on Jun 08, 2017
My computer doesn't recognise my Magellan 110 Gps
1 Related Answer
brian soufane
  • 693 Answers
  • Posted on Oct 31, 2011
SOURCE: When GPS plugged into the USB port, the computer,
First, try plugging it to another USB port on your PC, if the same error appears, try using a different USB cable. If no luck the try it on another PC If you can get in to the device manager and delete the usb drivers, and drivers for the hard drive, then reboot the computer and reconnect again, it should reload the drivers and that may work..
2helpful
How do you get started... where do you plug in the gps in my toyota avalon? I have a 5045
Hello, If i understand correctly, you are just trying to set up your Magellan gps into your Toyota Avalon. First of depending on the kit you got for the bracket to hold the unit, it normally will have a suction cup, that secures the bracket, put the bracket on the window, normally to the right of driver view and toward bottom of window, then after putting mounting (suction cup and gps holder) on window, then mount gps in to bracket, now your gps is mounted at this point on window. Now, of course you have to plug it in. GPS kits when you buy them normally have a 110 power plug ( to plug into home outlet) and some will have with the kit, a 12 volt cigarette type of plug to plug in your car (which is 12 volt power) In your home of course you can charge the gps off your 110 power, and gps will run off internal battery for a few hours, but you will find out like with mine, that your better off to plug into car for power, because the internal battery does not last very long. I have a Magellan as well, and they are great units. NOW this being said, if you did not get with your gps a 12 volt car adapter for your gps, you will have to get one. ( unless you have a power converter, which takes 12 volt and converts it to 110 power, but that's another story and only recommended for devices that do not have 12 volt adapter capabilities)
In conclusion if you have the 12 volt adapter to plug in your gps, all you do is find your cigarette lighter, take out your cigarette lighter, put in glove box for storage, and plug your gps in your cigarette lighter, or any other 12 volt cig lighter plugin. That's all there is to it, and now you have power running off your car. Thanks mike , hope this helps
Magellan Maestro 4040 won't turn on with and wiothout chargers, car and 110 v. Will turn on very briefly and turn off again saying the battery is critically low. This is even after being on 110 v charge...
hi jaykremer
The following advice pertains to the following magellan gps systems.
Magellan 800, 860, 2000, 2200t, 2500, 3000, 3050, 3100, 3140, 4000, 4040, 4050, 5310 and 6000t
i fix these and many other magellan gps daily so when considering my advice , please understand i do not google my solutions.
assuming your car charger is working (the little green light is on) and your magellan still wont start up after holding the power button while its plugged in for up to ten seconds and still does not start..read below
this is actually a very common problem with these magellan power ports...they are poor quality from the factory and always and i mean always fail..the new ports that you find on ebay are 100% better then the factory port.
if your able to replace that power port yourself, you can get one HERE, if not, ask the fellow that sells them for help.
due to some dubious "experts" on fixya, im not permitted to help you directly, but please follow the link above to get further help.
let me know if you need more help or info
Bill
Standing Member of G.O.T.
Please Support Our Troops
Magellan Maestro 4040 gps
the folowing advice pertains to the following magellan gps systems.
Magellan 800, 860, 2000, 2200t, 2500, 3000, 3050, 3100, 3140, 4000, 4040, 4050 and 6000t
bill
4helpful
2answers
My gps is stuck on magellan boot up screen.
turn on your 1210 once it boots to the magellan screen press and hold the power button for about 15 seconds, once it shuts off, power it back on by pressing and holding the power button for up to ten seconds then let it load.
if that fails,power it up and try the reset button, (either on the bottom or on the side)the little pinhole, and use a paper clip to depress the reset
button.
bill
4helpful
GPS doesnt turn on with power cord adaptor or 12v lighter socket
if you can verify that the car charger is ok, try plugging it in to your computer using the usb cable. the 1412 should charge with the usb cable. if it still doesnt turn on, try and reset the unit,little pin hole on the side.
2answers
Magellan 2000 doesn't power up
try replacing the battery. ususally if the battery is dead it will freeze or not turn on. if this doesn't work magellan will replace it with a new one at a very reasonable price. I just replaced a magellan 800 with a magellan 3210 for $132.00. your may get a better deal. call magellan
if you have an a/c 110 volt to 5 volt converter for the magellan, try charging it in the house with that one rather than the car charger.
1helpful
5answers
Cannot communicate with pc/ laptop. device is not recognised
You probably have the USB adapter connected upside-down on the unit.
Top Magellan GPS Experts
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
Are you a Magellan GPS Expert? Answer questions, earn points and help others
