Question about Mercury Boating
50hp Mercury outboard electrical schematic
Need free electrical schematic for 2001 Mercury 50hp outboard motor, 2 stroke.
Posted by David Stewart on
Steve P
  • Mercury Master
  • 3,712 Answers
Hey David,
Yo should find all the info you need here..this will be very very helpful...' Mercury Outboard Manuals by Seloc 1965 2014
Posted on Jun 23, 2017
What year is a mercury 35hp outboard motor with serial number2491265.Is the motor 2 or 4 stroke
the serial number begins 2487558 and continues past 2491265 and as the beginning serial number denotes the year , your engine is 1969 model
it shows as a 2 stroke with auto oil injection
check the heads
if the plugs are in the flat of the head and there are no rocker covers it is 2 stroke
talk with a mercury /mariner service center
Sep 25, 2016 | Mercury Mariner Starter, Outboard, 35-40...
I need step by step procedures on how to check compression on a 2004 Mercury 50hp 4 stroke efi outboard motor
Go to a repair service and ask them to check it scanning the computer of your car.
Nov 08, 2015 | Boating
Are the controls for a 1998 15 HP 2 stroke Mercury outboard compatible with a 2011 30 HP 4 stroke Mercury outboard
If your old engine/control has the same 'options' as the30hp, yes everything is compatible... (Electric start or trim )
The throttle and shift cables are allways compatible...
Jun 25, 2015 | Mercury Marine 15hp & 20hp 4 Stroke...
Yamaha 50 outboard bogs at hi speed
Make sure carbs are clean,check exhaust tube isn't blocked,check resistance readings on charge coil,make sure filters are clean,no fuel leaks in fuel line,tank has open breather,fuel connector not blocked.if this doesn't solve the problem could be faulty cdi unit
Sep 25, 2013 | Clymer Marine Maintenance and Repair...
Free Mercury Outboard ONLY, 2-40HP 1965-1989 Repair Manual 1-2 Cylinder, 2 Stroke
I have a problem with my 2 stroke 20hp mercury 1989,when I run 10-90% throttle it's works fine but when in 100% its only runs in 90% and doesn't sound normal like it's not burning right.
May 11, 2012 | Seloc Mercury Outboard Engine Repair...
Boating Logo
346 people viewed this question
Top Mercury Boating Experts
Mike
ray gallant
john h
Are you a Mercury Boating Expert? Answer questions, earn points and help others
