Question about Springfield Measuring Tools & Sensors
I have a Springfield precise temp unit ,measuring 3 1/4 by 1 1/4 inches and 5/ 16 thick. I need a battery .WHAT BATTERY is correct? Gene Hollon- 205- 763-3237.
Posted by Gene Hollon on
5 Related Answers
Rich Wright
  • 286 Answers
SOURCE: uline clr2060 produces little ice
First thing is to remove the water from the trough. Pull out the grey standpipe in the back of water trough. Then see if the grid has a good frost pattern.If the frost pattern is NOT even then you need a service call to check the sealed system. If you do have a frost pattern check to see if the water is splashing over or make sure the drain is in the bin drain hole.If water is getting in the bin then the ice can melt as fast as it makes it.Make sure your cleaning with U-line cleaner.
Posted on May 28, 2009
freetek
Steve Allison
  • 5569 Answers
SOURCE: outside temp not measuring correctly
I keep the outside unit of our in/out set under a coffee can shaded under a bench; one could argue the aesthetics but shielding it from wind and sun is mandatory otherwise one can get record temps pretty often.
The outside units generally transmit to the receivers only every few minutes to keep battery consumption down so moving them won't necessary gie you an immediate change.
Posted on Jul 15, 2009
Anonymous
  • 7 Answers
SOURCE: We have a Mastercool II & it was installed ~ 3
The pads you need are at least 8 inches thick. If you have the contractor model, then the pads will be 12 inches thick.
Find a distributor in your town that sells cooler parts, if they dont have them, some of the big home improvement stores carry the pads for your cooler.
Make sure you are using a bleedoff or a dump pump to eliminate the hard water out of the cooler. If you keep those pads clean, they wiil last for many years.
Posted on Aug 07, 2009
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: Measurements
Here is a tip that I wrote about rice cookers and the amount of rice and water needed...
How much Rice and Water go in the Cooker
http://www.fixya.com/support/r5396567-much_rice_water_go_in_cooker
heatman101
Posted on Jul 27, 2010
Anonymous
  • 5 Answers
SOURCE: We have a Springfield Precise temp Model 91905. I
Are you sure the model number is 91905? The link below is for Precision instruction manuals but that model is not listed.
http://www.springfieldprecision.com/customer-service/instruction-manuals/
Posted on Dec 16, 2010
I have an older model springfield precise outdoor temp not registering on indoor unit. Batteries have been changed, reset button pushed. Model #EMR899. Cable free
Steve, thanks for that info on the reset button , I go through this every time I change batteries. I put a note on the back of my Springfield temp now.
Jan 20, 2018 | Springfield Measuring Tools & Sensors
I have a Springfield precise temp base station 433mhz wireless It has 11 buttons on front no number. It came with outside temp and weathervane parts. Would you have a manual for it? Thank you Jackie
Hi, Jackie.
Is it look like this ?
With Windspeed and 3 station temperature reading ?
If so, model number is 91751
Good luck with finding Manual.
I have paper manual with me, I can scan most useful pages for you (Buttons)
Apr 06, 2015 | Springfield Measuring Tools & Sensors
Springfield precise temp in out thermometer 91756
Return it to the manufacturer for warranty repair/replacement
Jul 23, 2014 | Taylor 91756 Wireless Thermometer With...
Springfield precise temp instructions
The outside temp for the inside reading quit working this morning when I went to check the temp.The outside sensor was working fine.
What do I do to get the inside one to work again. The other features were working fine.
Jun 17, 2013 | Computers & Internet
Instructions for springfield precise temp model 91455
I also reset my 91455 today. Go online to Springfield precise temp manual 91455
May 29, 2012 | Springfield 91455 Wireless Digital Outdoor...
In need of instructions for springfield precise rain/temp gauge. need to know how to set the clock
Here is the website. If you know the model number the user manuals are at the bottom of each page. Hope this helps
http://www.premiereproducts.biz/products/computemp5.php
Aug 24, 2010 | Computers & Internet
Measuring Tools & Sensors Logo
205 people viewed this question
Top Springfield Measuring Tools & Sensors Experts
Harrie
Andrew Taylor
Andrew Taylor
Are you a Springfield Measuring Tool and Sensor Expert? Answer questions, earn points and help others
