B
Brian Rose Posted on Jun 06, 2017
Hitachi f381a remove cover
I can't see how to open the top metal case cover in order to clean the heads
5 Related Answers
hunhandad
  • Posted on Jun 03, 2008
SOURCE: u61 on panasonic dmr es15
For U61 errors:
Turn unit off
flip down front a/v input panel
simultaneously press the channel up and stop buttons for at least 10 seconds.
Slinteriors
Sonny Berry
  • 8617 Answers
  • Posted on Jul 06, 2008
SOURCE: How to replace STK392-100?
Look at the very bottom of those boards they should have a plastic socket that they slide in. If they do you will notice a little plastic tab that has to be bent back for the panels to be removed from the socket.
colliewob
David
  • 781 Answers
  • Posted on Aug 02, 2008
SOURCE: Acer 5003 fan noice due to unknown reasons
your fan has worn bearings what I do in this case is remove the little sticker over centre of fan and just put a little drop of sewing machine oil on it replace sticker and check for noise
bobicehouse
Robert Moller
  • 1524 Answers
  • Posted on May 24, 2009
SOURCE: How to take apart case and back flush heat exchange fins
You do not have to remove the coils. Just carefully lift the top with the motor and set it aside (power off). Spray the outside with a foaming cleaner (Dow bathroom) and flush from inside out.
mahal1517
Nelson Olazo
  • 62 Answers
  • Posted on Jul 20, 2009
SOURCE: How to remove the nc6220 touchpad
hi...you lock the side please be careful you only go left and upward..good luck and hopefully help me have you..
Hyundai matrix 1.6 head gasket replacement
Unscrew the rocker cover and remove the top casing, most cars now have gasket seal rather than a gasket so check this. Put new gasket in place and then replace top casing, replacing the bolts back in the order they should be in, then put rocker cover back on...
HYUNDAI MATRIX 1 6L 2003 G4ED F4AF3
How to open Teac FD-05PUB?
There are two small black phillips screws near where the cable is, take those out. The opposite side from the screws is the cover, it pries off. You can work a flat tip screwdriver in there and see if you can pop it off without damage. Start on the sides.
If you're having trouble with that you can remove the rubber piece going around the outside first. I started where the floppy opening is, you can pry it out with a small flat tip screwdriver then just pull it out. Do the same for both sides of floppy opening.
Then you'll have to take the phillips screw by the motor to remove the drive from the case. There is another small phillips screw holding the cover, remove that and you can work the cover off. Now you can clean the heads.
To put it back together screw the drive cover back on, then screw it back into the case. Put the rubber piece in, then push the top cover back down till it snaps in. Then put the black screws back.
1helpful
Printer heads errors
switch on the machine wait till error appears on panel, go to the system open internet explorer type IP address enter you can view the entire printer over view.. check which print head showing faulty, ask to replace the head open top cover of the printer open print head cover remove print heads clean print head contact pcb as well as carriage contacts insert print heads back then check for the print head recognition, printer will perform its own priming and all wait till ready mode comes onece ready mode appears.. print heads are OK.. if not replace faulty print head/s.Most of the cases cleaning is enough.
My older style Hitachi NR90AD still works OK but always leaks a little air out of the very top of gun. I took the head off, cleaned, and oiled but still leaks by.
Over time debris enters the gun and scratches the metal and plastic surfaces where orings seal against. These scratches will allow air to leak past. Remove the head and pull out the head valve. Examine the metal surface with magnify glass where the headvalve oring makes contact. Remove scratches with 400 grit paper. The surface must be smooth and the oring must seal snugly. Apply silicone paste lube on all surfaces and orings (available at Lowes in the plumbing department and swimming pool supply). Also check for scratches around the body of the gun were the cylinder plate is installed around the cylinder. The gun will not work properly will small air leaks. Remove nails and listen for leaks thru the nose of the gun. Repair as needed. Good luck with your gun.
PS3 will not start-the green light and hard drive starts up for a few seconds then shuts off
The problem is a hardware problem, which is due to a failure in a component it the unit.
You will have to dismantle the playstation, clean it and couple it back together. To dismantle the playstation, follow the steps below:
1.
  • Pull the warranty sticker off of the bottom of the PS3. This will void your warranty, so make sure that the problem you are addressing is not covered by your warranty. Note that taking your PS3 to be repaired by someone other than Sony will still void your warranty. You are not losing anything by taking apart your PS3 yourself. Under the sticker will be a small piece of rubber that hides a single screw. Remove the rubber piece and unscrew the screw.
  • 2 Slide the faceplate off of the PlayStation 3. After the faceplate is removed, you can now separate the two halves of the plastic covering. Remove and set aside the top piece of the plastic case to expose the internal components of the PS3. On the underside of the top plastic covering, there will be a memory card slot at the bottom-right corner.
  • 3 Locate and remove the Bluetooth circuit board. Remove the four screws to lift the Bluetooth board free. This is located at the bottom-left corner of the main body of the PS3 if you have the system flat on its side instead of standing up straight. This will look like a green rectangle with a tan metal covering.
  • 4 Locate the small circuit board that controls the power and eject functions of the PlayStation 3. Remove the four Phillips-head screws in order to separate this piece from the body of the system. This is located at the bottom-right corner of the PS3, directly in front of the disc box.
  • 5 Locate and remove the Blu-Ray/PS3 player. This is the large tan metal box that is located in the top right corner of the PS3. Unscrew the player and flip it upside down to expose the circuit board that controls it. If you want to remove the circuit board, there are five small screws that hold it in place.
  • 6 Remove the power supply from the inside of the gaming system. This is located at the top-left corner inside the PS3. To remove this component, there will be two telephone-like plugs that have to be unplugged, one at the top and one at the bottom of the power supply. Additionally, there will be 13 screws that hold the power supply in place. The back and front plastic coverings of the PS3's shell will now easily slide free.
  • 7 Remove the final internal component, which is the PS3's motherboard. In order to do this, remove the metal covering the rests on top of the motherboard. There will be 11 screws that border the metal covering as well as four screws in the very center, two from each of the rectangular center pieces. Once the screws are removed, the metal covering will lift off and the motherboard will be able to be removed.
  • Have it cleaned and properly reverse the process to reassemble it back together.
    Note: If you are still under the warranty period of purchase, you can take it back to the dealer that supplied it to you for their technical support.
    Take care and good luck
    Is their a way to open a PS3 counsole, my kid might of put a couple of dvd movies in it, it turns on but then shuts down and red light flashes
    To open your ps3, you need to first shut it down and disconnect all the cables connected to it, wait for about an hour for the high voltage in it to dissipate. The you get a screwdriver that matches the screws on it.
    But before you get to all these parts you must have gotten your DVD movies out.
    Take care
    How do you remove the ink cartridges from the
    To service the ink tanks:
    Ensure that the printer is on, and then open the Top Cover.
    The Print Head Holder moves to the center.
    i_note_us.gif Note
    If the Top Cover is left open for more than 10 minutes, the Print Head Holder moves to the right. Close and reopen the Top Cover to return the holder to the center.
    2 Open the Paper Output Tray.
    Put your fingers in the notches in either side of the Paper Output Tray and pull down to open it, and then pull down the Inner Cover forward to open it.
    3 Remove the ink tank whose lamp is flashing fast.
    (1) Push the tab and remove the ink tank.
    Do not touch the print head lock lever; remove only the ink tank.
    Important
    bullet_s.gif Handle ink tanks carefully to avoid staining clothing or the surrounding area.
    bullet_s.gif Discard empty ink tanks according to the local laws and regulations regarding disposal of consumables.
    i_note_us.gif Note
    Be sure to replace ink tanks one by one when replacing more than one ink tank.
    4 Prepare a replacement tank.
    * Do not touch the electrical contacts on the ink tank. Doing so can cause the printer to malfunction or become unable to print.
    (1) Unpack the new ink tank and completely pull off the orange tape. Then, remove the film.
    (2) Remove the orange protective cap from the bottom of the ink tank and discard it.
    Important
    bullet_s.gif Be sure to remove the clear film from the ink tank in the exact order shown in step 4-(1), as failure to follow this step may cause the ink to leak and stain your clothes and hands.
    bullet_s.gif Do not squeeze the side of ink tanks as this may cause the ink to leak out and stain your clothes and hands.
    bullet_s.gif Do not re-attach the protective cap once you have removed it.
    bullet_s.gif Do not touch the open ink port once the protective cap is removed, as this may prevent the ink from being ejected properly.
    bullet_s.gif Ink on the removed protective cap may stain your clothes and hands.
    bullet_s.gif Ensure that all the orange tape has been peeled off along the perforation. If there remains a part of the orange tape, ink may not be output correctly.
    5 Install the ink tank.
    (1) Insert the ink tank into the Print Head.
    (2) Press on the push_3.gif mark on the ink tank until the ink tank snaps firmly into place.
    (3) Ensure that the ink tank lamp lights red.
    Important
    Ensure that all the ink tanks are installed in the order directed by the label. The printer cannot be used unless all the ink tanks are installed.
    6 Close the Inner Cover.
    i_note_us.gif Note
    Ensure that the Inner Cover is closed. Printing will not occur if the Inner Cover is open.
    7 Close the Top Cover.
    The Print Head Holder moves to the right. The ink tank installation process is now complete.
    i_note_us.gif Note
    bullet_s.gif The ALARM lamp still flashes orange after the Top Cover is closed if an ink tank is not installed properly. Open the Top Cover and make sure that all the ink tanks are installed in the correct order directed on the label.
    bullet_s.gif To maintain optimal print quality, use an ink tank within six months of first use.
    bullet_s.gif Once an ink tank has been used, do not remove it from the printer and leave it out in the open. This will cause the ink tank to dry out and the printer may not operate properly when it is reinstalled.
    bullet_s.gif Color ink consumption may occur even when black-and-white or gray scale printing is specified.
    Color ink is consumed in the head cleaning and deep cleaning, which are necessary to maintain the printer.
    bullet_s.gif When you start printing after replacing the ink tank, Print Head Cleaning is performed automatically. Do not perform any other operations until the Print Head Cleaning finishes. The POWER lamp flashes green during cleaning.
    Canon Pixma IP4000 cyan ink will not flow even though I have repeatedly cleaned and deep cleaned and replaced ink tank.
    If you have gone through the process of cleaning and deep cleaning, as described by canon, and you still get no ink flow after printing 2-3 pages, the print head needs to be replaced.
    Here is WHO to contact and HOW to install the print head:
    WHO: Purchasing a Print Head
    You may purchase a print head* for this printer by calling 1-800-828-4040 Monday-Sunday 8:00 a.m. - 12:00 midnight. EST, excluding holidays. When calling, speak the term "order parts" when the speech routing system asks the reason for your call. You will immediately be routed to the Parts Desk for assistance. Be sure to have your model number (iP4000R) or part number (QY6-0049-000) ready for the sales person.
    HOW: Install the print head and ink tanks correctly iP4000/iP4000R/iP5000
    Seat the print head Below is the procedure for seating the print head and ink tanks:
    1. Power on the printer.
    2. Open the paper output tray and top cover.
      Note: Gently open the paper output tray while holding it.
    3. After confirming that the print head holder has moved to the center, open the inner cover.
    4. Remove the orange tape securing the print head lock lever, and raise the print head lock lever.
      Note: If the top cover is left open for more than 10 minutes, the print head holder will move to the right. If this occurs, close the top cover once and then re-open it.
    5. Remove the print head from its package and remove the orange protective cap.
      <1> Electrical Contacts and Print Head Face's Nozzle Area
      <2> Ink Supply Filters
      Note: To avoid any damage, do not touch the print head face's nozzle area, electrical contacts, and ink supply filters. After removing the protective cap, set the print head into the print head holder immediately. Do not re-attach the protective cap after it has been removed.
    6. Set the print head into the print head holder, and lower the print head lock lever until a click sound is made.
      Next, install the ink tanks.
    7. Remove the cyan ink tank (BCI-6C) from its package. Pull the orange tape in the direction of the arrow to remove the wrap film completely.
      Note: Remove the orange tape completely. If the orange tape is not completely removed, it may interfere with printing.
      <1> Removed correctly
      <2> Removed incorrectly
    8. Hold the ink tank as shown in the image below. Twist the orange protective cap in the direction of the arrow, and remove it.
      Note: Remove the protective cap while holding it, so that fingers will not be stained by the ink.
    9. Insert the ink tank into the slot at the right end, and push down on the PUSH mark on top of the ink tank until a click sound is made. Install the other ink tanks in the same manner.
    10. Close the inner cover and top cover.
      Note: Check that each ink tank is installed in the correct position:
      Properly installed:
    Water not pouring down
    Need more info such as is it a 2 head or 1 head. Have you removed the screen and diffuser to see if its clogged, do you hear the pump when you run the head. If yes to all then on top of the group, if you remove the front cover, and the sheet metal plate you will see a nut a 17 or 19mm open end wrench will help you remove it(MAKE SURE WATER IS TURNED OFF AND THAT THE MACHINE IS COOLED BEFORE OPENING). The micro filter and the jet will be covered with minerals clean filter and use a paper clip or long pin to clean the small hole in the middle of the jet.
    1helpful
    2answers
    Hitachi 51UWX20B spider web like lines help
    I know my response is a while after you asked, but to clean the inside of the tv case is pretty simple.
    Remove the bottom speaker cover...on this model you just pull it off. There is no clips or screws.
    Once the speaker cover is off you will see the bottom of the screen, there is 4-5 screws on the bottom on each side....I think 4 in the gray plastic and 1 in a black metal strap. With all of those screws out pull out SLIGHTLY on the screen and push up. The top is held in with a down force clamp and you are just popping it out of that....It will pop back in once you are done.
    Now clean the back side of the screen, the mirror and CAREFULLY dust off the lenses. I myself did not want to use any cleaners (to avoid streaking) so I used a new microfiber dusting cloth. My picture became brighter and the "crack" that I thought I had was just a dust web....
    Hope this helps and good luck
    N8
    Top Hitachi Office Equipment & Supplies Experts
    Grand Canyon Tech
    Grand Canyon Tech
    old marine
    old marine
    ZJ Limited
    ZJ Limited
    Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
