Question about Mitsubishi VS-60611 60" Rear Projection Television
Mitsubishi television I have a Mitsubishi tv, model VS6061. While watching a movie, the picture went totally black. It is the same if I switch to cable. I still have sound. I no longer hear the clicks that I heard when I switch to the different components such as from antenna B to auxillary.
Posted by rob007 on
Robert Johnson
    Sergeant:
  • 395 Answers
1. NO VIDEO, BUT HAS VIDEO WITH PIP ON. CHECK C763 (1UF 50V) ON THE BASE OF Q715, LOCATED ON THE UCOM-PCB. 2. NO MAIN VIDEO, THERE IS VIDEO IN PIP ON EXT1 AND EXT2:-CHECK FOR 1VPP OF LUMINANCE ON PIN 1 OF IC7000, IF MISSING OR LOW CHECK THE VALUE OF C7001 (4.7UF 35V), LOCATED ON THE PIP-PCB. THIS CAP MAY LEAK ELECTROLYTE ONTO THE BOARD AND OPENED A FEED THROUGH IN THE PATH BETWEEN C7001 POSITIVE LEAD AND THE EMITTER OF Q7003 OR CAUSE INTERMITTENT COLOR. PART # 181P504090. (CHECK ALL 'SMD' ELECTROLYTICS AND TRACES ON PIP) 3. NO MAIN OR PIP VIDEO, CHECK C7014, 47 UFD 16V ON THE PIP PCB. PART # 181P502060 4. CHECK FOR 7.2V DC ON THE BASE OF Q7003, IF LOW OR MISSING. CHECK THE VALUE OF R7002 (150 OHM 1/10W).LOCATED ON THE PIP-PWB. PART # 103P401050 5. SUSPECT R2045/R2048 (6.8 OHM 3W) FOR OPEN/RAISED VALUE. LOCATED ON PCB-SIGNAL AT 5V REGULATOR IC2003 PIN 5.
Posted on Jan 21, 2008
I have digihome tv has sound but no picture and nothing on virgin
is this happened either watching a tv channel or even watching dvd movies?. and then does the display only white screen or a totally black screen?.
Oct 16, 2012 | Digihome LCD TV
Have a 36 inch vizio flat screen it started about four days ago.When i switch from watching a movie on DVd back to regular picture on component 2 no picture is coming up tried chanel 3 an d4 still no...
It sounds like you aren't cycling fully.
It sounds like you are on the TV (RF/Cable) input, then you switch input to Component 1 (for your DVD) and watch the DVD, then hit the input selector again, switching it to Component 2...you need to keep switching the input until you are back on the TV / Cable input.
Jul 11, 2011 | Televison & Video
Mitsubichi VS 45609. When I turn the TV on sometimes it comes on and has beautiful picture and sound. Then after 1/2 or so it goes to a black screen. While on the black screen I am able to PIP it and see...
I have the same TV and what is happing is the TV has 2 recievers in it to allow the PIP, So you have a power pack gone on 1 reciever the other is working, Your set has 2 power packs,1 for each receiver.
I had both of mine go, 150$ a piece to have fixed, good luck.
Mar 07, 2011 | Mitsubishi VS-45609 TV
I have the Toshiba 61A61 TV. I am not sure what exactly happened, but when the TV was on, suddenly the picuter went black. I still receive the normal sound, but can't get any picture (totally black). I...
Check all connections?Unplug,replug the cable box about an hour later let it upgrade it software.The projection lamp has not been replaced in this tv the last 1 1/2 or 2 years?The tv been on and watches at lest 4 or 5 hours a day?Yes,than the projection lamp life is over.Require a new projection lamp.
Sep 03, 2010 | Toshiba 61A61 61" Rear Projection...
Black and white viewing
It's probably the new technology.Do you have a cable box or basic cable with a straight wire?If you have a box it should work.Sounds like you don't though.The cheapest fix would be a digital converter box.If you buy one and don't like the results,make sure you buy it at a place where they will accept the return.A dish digital box should work though.Do you have just a wire from the dish?It seems like a dish requires some sort of converter.How long have you had this problem?If you had a picture when they first went to digital,it would be the TV.That's all i can say.
Jul 27, 2010 | Philips 60PP9601 60 in. Rear Projection...
38 '' RCA TV XBOX Model 36V550T, lost the picture
Does it only happen when you use your Xbox?
Try pulling the cable in and out between the TV and Xbox
Dec 05, 2009 | RCA 36V430T 36" TV
Mitsubishi tv model VS6061 rear projection with rolling picture.
I know this is an old thread, but I would like to post this information in the hope that someone will find it useful.
I just finished fixing this problem on my 1994 VS-6061... the problem is the PIP (Picture In Picture) board located on the Power Signal board. The PIP board contains the numbers 530B552. I bypassed the PIP board by following the directions I found at the following link:
http://forum.doityourself.com/entertainment-center-tvs-stereos-vcrs-dvds/130383-mitsubishi-cs-35301-rolling-picture-problem.html
"Plug in a 4.7ufd @ 35v filter cap (+)at pin 5,(-)at pin 11. Plug in a .01ufd(any voltage) between pin 7 and 9. Just plug the caps into the socket, where the PIP board was mounted (they don't need to be soldered). Just don't let the leads from the two capacitors touch, as they cross each other. The 0.01 cap is non-polarity, so either way it plugged is fine. Basically you will bypass y-signal through 4.7u, in pin 5, out pin 11, and bypass c-signal in pin 7, out pin 9 of the PIP socket.”
The bypass requires 2 capacitors: One 4.7ufd @ 35v and one Non-Polar 0.01ufd @ any voltage.
Remove the PIP board, then plug the two capacitors into the socket where the PIP board was mounted: plug the 4.7ufd capacitor with (+)at pin 5,(-)at pin 11 and plug in the non-polar .01ufd capacitor between pins 7 and pin 9.
If there is a ground wire (possibly brown) soldered to one of the tin cases on the PIP board, then you should connect this ground wire to the PIP socket either at pin 2, 4, 6, 8 or 10 which are grounds of the socket.
This PIP board was used in many Mitsubishi televisions and they were plagued with problems...This is why many of these older Mitsubishi televisions had similar problems…
Good luck
Jul 19, 2008 | Mitsubishi VS-60611 60" Rear Projection...
No sound or tv signal
Probably need the TUNER either fixed or replaced.
Apr 27, 2008 | Toshiba CZ27V51 27" TV
DELL 42 inch Plasma TV
I have a 42" LG LCD TV and just experienced this today. Watching cable, then the screen went to black, but audio continued. I pressed the guide button on my remote and pic came on with my guide menu. But then went to black again 10sec later and has remained that way for nearly an hour. Tried switching off both cable box and TV, disconnecting and reconnecting cables, but no luck. Finally unplugged mains, waited a minute, then turned back on. Everything seems normal now after the reboot. Phew.
Jan 17, 2008 | Sony KV-36XBR450 36" TV
Televison & Video Logo
173 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
