Question about Sunpak Cameras
Sunpak 3000 can not get ready light to come on after putting in new batteries
Posted by Melvin Lynam on
Digiflash 3000 will not flash even when testing. I hear it warm up, ready light comes on, but nothing.
These are not that expensive to buy, the problem is that the parts and service are more than a new one. In any case they use high voltage and you have to use special tools to measure and service the flash circuit. IT might be the flash tube is bad, the trigger circuit is bad, the capacitor is bad etc.
1helpful
How do i replace sunpak ms 4000 tube
Found 'em! Tocad has them, you just have to call to order. $62.15/ea - part S7300.
How does the Sunpak Auto 555 Thyristor Flash Unit work concrning a battery? Does it always need the ourside battery pack unit also?
When internal cells are fully charged it do not need external ones
http://www.photographyreview.com/mfr/sunpak/flashes/PRD_84012_3121crx.aspx
1helpful
My Sunpak Auto 383 Super will not fire on or off the camera. When I turn on the switch, the ready/test light lights immediately. I suspect the bulb is burned out, so I wonder if that can be replaced.
There can be one of many parts which is gone :
Flash tube,capacitor,trigger cap.or triggering switch.
Warning as it has 330 volts even when battery is removed do not open if you are not aware of the risks.
Sunpak 383 contains no bulbs inside.
Can I use re-chargeable 2500 mAh batteries with Sunpak PZ 4000?
Yes, you can use Ni-mAh re-chargeable batteries with Sunpak Pz 4000
2helpful
5answers
Sunpak Auto zoom 3000 thyristor
You can use the Sunpak on a bracket with a "slave trigger" and fire the slave with the Nikon's pop-up flash. I do the same with a SunPak 3600 Auto Zoom. Just remember not to have the red-eye feature operating. Those little slave triggers are only a couple of dollars and I already had few brackets.
Jun 03, 2008 • Cameras
Cameras Logo
Top Sunpak Cameras Experts
ADMIN Canada
ADMIN Canada
Tom Chichester
Are you a Sunpak Camera Expert? Answer questions, earn points and help others
