Question about Engel Freezer 22 Qt. Fridge/Freezer
Candy fridge freezer. Freezer cold but fridge warm. Air circulation is passive; right? (No fan). So a blockage; right? Outlet low at rear is easy to see and clear. Where is inlet; how inspect/clear?
Candy CPDA 241 Type DP 24 Freezer -30; fridge +12
6ya staff
SOURCE:
douglas smith
  • 1462 Answers
SOURCE: Indesit fridge freezer (2 years old) not getting cold
if compressor is running, then you are correct in saying no point in replacing stat. by sounds of it you have a faulty compressor fault or a syatem fault - impossible to dignose by remotely. this is not a diy job i'm afraid
Posted on Jul 25, 2007
Sea Breeze
John Tripp
  • 4656 Answers
SOURCE: Indesit Fridge Freezer
YOUR DEFROST TIMER OR A BURN OUT DEFROST ELEMENT
Posted on Oct 21, 2007
dcp2
Daniel Phillips
  • 63 Answers
SOURCE: ARISTON FRIDGE FREEZER MBA 3842C PROBLEM
It should work the same as before. Does the compressor get really hot after running a while? If so it could be low on charge, or there could be a restriction inside the refrigeration system. Either way a professional would have to look at it.
Posted on Jan 28, 2008
Anonymous
SOURCE: Indesit fridge freezer not getting cold (2 years old)
how to fix my indesit light inside the fridge reply asap
Posted on Sep 19, 2008
jonniewalker
Starnley Johnwells
  • 1031 Answers
SOURCE: fridge freezer
  • Check the temperature setting
  • Assure that there is enough room for air flow in the refrigerator or freezer
  • Check for air flow restrictions in vents
  • Test the temperature control
  • Clean the condensor coils
  • Check the door seals
  • Test the door switch
  • Test defrost heater
  • Test defrost timer
  • Test evaporator fan
  • Check for a clogged drain tube
  • Check for refrigerant leak
Posted on Sep 23, 2008
What shld settings be as food is freezing in fridge it has side by side knobs saying colder mid less cold it is a westinghouse fan forced frost free freestyle unit
The settings are "relative". Someone with this fridge in Montana may need to run the same fridge with different settings than someone in Texas to get the same temperatures.
Many manufacturers recommend that the fresh food compartment should be 34 degrees F, and the freezer -10 to 0 degrees F. To set this properly, place a thermometer in the freezer (that can display temperatures as low as the desired temperature). Adjust the thermometer for the correct freezer temperature before going on to the fridge. A fully stocked freezer could take 12 hours or more for temperatures to stabilize after making changes to the thermostat. Once the -10 to 0 degree temperature has been achieved, set the fresh food compartment temperature.
Place a thermometer (that can display below freezing) in a 6 (or so) oz flexible plastic cup of water and place on a shelf in the fridge. A glass of water could break if the temperature gets below 32 degrees if the water turns to ice. The water acts as a buffer to rapidly changing temperatures when the door is opened to read the thermometer. If the fridge is "full", allow 24 hours for the temperature to stabilize before making changes.
If the fridge and freezer are empty, changes may be seen in just a few hours or less. Otherwise, wait the 12 / 24 hours for the freezer / fridge compartments.
I hope this helps and good luck!
Sep 06, 2011 | Freezers
The fridge part of my fridge freezer is freezing the food and the back wall is covered in ice
1. There can be a air leak from the gasket (door rubber).
2. Thermostat is adjusted to high cool position.
Check for these. If you still have the problem consult a technician please.
Oct 04, 2010 | Candy 11 cu. ft. / 311 liter Chest Freezer...
We have bought a new american style fridge/freezer and it was delivered yesterday. We have left it on for 24 hours and the temperature is not going down the fridge wont go below 12 degrees and the freezer...
ambient temp 10/35 degrees C.not in direct sunlight,
did you use a level to make sure that it is level in all planes,just to make sure all the door seals are tight,
(look along the seals to make sure)the unit should be left on for at least 24 hours in its chosen position with the doors shut,then check temp,it could take another 12 hours to settle down once loaded.Also make sure that its not touching the wall cuts down on vibration.
once checked,if still not right call samsung..they are good.
Apr 04, 2010 | Freezers
Kelvinator fridge freezer is a geiger counter
something could have fallen into the fan between the two compartments
Nov 10, 2009 | Kelvinator 12 cu. ft. / 340 liter Chest...
Candy frost free fridge freezer .freezer working ok
The thermostat might be turned up too high or is faulty. It should click when turned up and down from the setpoint.
May 12, 2009 | Freezers
Temperature Setting Dial in Fridge
Hi. thanks for the question. # 9 is the high, 1 is low. and it will run for 24 hrs to get on track .thanks the appliance doc
Oct 05, 2008 | Kelvinator 12 cu. ft. / 340 liter Chest...
Fridge freezer
Defrost timers usually cause this type of frost build up. However it can also be caused by the defrost heater and/or heater thermostat, and these items are behind the panels therefore not easy to get to. Also before you attempt to take the panels apart make sure the refrigerator is unplugged.
Aug 04, 2008 | Candy Freezers
It sounds like a Freon leak. The compressor is running and it gets a little cold. THis is not something you can fix yourself. You have to have certification to buy freon and gauges and know exactly how to use them. Besides in most cases you can't find the leak and will have to keep recharging it.
Jun 28, 2008 | Freezers
check that the correct thermostat is installed and that the element wire is connected.check door rubber and door hinges.check if it has independant defrost timmers and if it is working.oh and see if the element is drawing current if fitted with one.
Nov 05, 2007 | Engel Freezer 22 Qt. Fridge/Freezer
Engel Freezer 22 Qt. Fridge/Freezer Logo
96 people viewed this question
Top Engel Freezers Experts
Felizardo Erilla
Felizardo Erilla
John Tripp
John Tripp
Marvin
Marvin
Are you an Engel Freezer Expert? Answer questions, earn points and help others
