Question about Home Security
How to factory reset a kkmoon dvr - Home Security
Posted by robbo on
  • 2 more comments
  • Penchal Sep 06, 2018
    I forgot my admin password of kkmoon,I also want to do factory reset,Do you know how to reset?
  • Steven Parker
    Steven Parker Oct 21, 2018
    I forgot my password
  • Justas Zalneris
    Justas Zalneris Sep 06, 2019
  • toyanath
    toyanath Sep 16, 2019
    i forger my password how to reset new password
Herbei Johnson
    New Friend:
How do you reset a kkmoon DVR
Posted on Sep 02, 2017
Johny Johny
    Habit-Forming:
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
Our dvr recorder is blocked!We forgot the password! could u please help us!
thank you in advance.
Posted on Jan 27, 2019
I have kkmoon h264 nvm and I forgot admin password?how can I do factory reset ?how can I get the password?
call the maker of the device, we are NOT THEM.
hacking PW is the most complex topic on earth, no , really.
Sep 06, 2018 | The Computers & Internet
Can i use a hard drive out of a compture foe my kkmoon dvr
It should take any 3.5" SATA hard drive. You may have to format it, and you probably want a larger capacity than what comes in most laptops.
Jun 08, 2018 | Drive Televison & Video
Trying to reset an ATV DVR admin password manufacturen in2015. Model N8P2
The DVR has a Factory Reset switch to the left of the Alarm Output connectors
on the rear panel. This switch will only be used on the rare occasions that you want
to return all the settings to the original factory settings.
When using the Factory Reset, you will lose any settings you have saved.
To reset the unit, you will need a straightened paperclip:
1. Turn the DVR off.
2. Turn it on again.
3. While the DVR is initializing, the front panel LEDs will blink. When the front panel LEDs blink,
poke the straightened paperclip to the unlabeled hole in the left of the Alarm Output connectors.
4. Hold the switch until all the LEDs on the front panel are lit.
NOTE: When the DVR successfully resets to factory defaults all the LEDs on the front panel flash
five times.
Release the reset switch. All of the DVR's settings are now at the original settings it had when it
left the factory.
Jan 02, 2018 | Home Security
I forgot my admin password on a kkmoon 1108 DVR,how can I reset and have a new password?
Your documentation should give you a way to do a factory reset, that should put it back to the original password. If you don't have that Google factory reset for your model of machine. Last resort get a hold of their service center.
Dec 20, 2017 | New Home Security
How to set up kkmoon 8 ch DVR with 1TB H/DR 8 channel 960H/DI DVR HVR NVR HDMI P2P
so what are you setting up? the unit or the wiri to view them with your phone? this is a loose question.
Oct 21, 2017 | Home Security
How to reset password for a samsung SDE-3004N DVR home security system. There is no remote for the system and have lost the password.
Samsung Security DVR Default Password
For nearly all Samsung Security DVRs, the default password is 4321. If it hasn't been changed since setup, then you can just use that to access the DVR. The default password is included in the reset procedures for completeness. If you have changed your password or access code for your Samsung Security DVR since it was setup, or if you changed it during the initial setup, use that password in place of the default password. The password will be the latest password that was set on the DVR. If no password has ever been set, then it will be the default.
Steps to Reset your Samsung Security DVR
Samsung Security DVR Reset Procedure #1
  1. Reset the unit to factory by pressing both [MODE] and [PTZ] button for 5 seconds
  2. Then enter the 4321.
Samsung Security DVR Reset Procedure #2
  1. Reset the unit to factory by pressing both [MODE] and [CH2] button for 5 seconds
Samsung Security DVR Reset Procedure #3 This reset will work on Android based DVRs only. All steps are performed on the device itself.
  1. Turn the device Off
    Wait 2 minutes
    Press and hold the following buttons
    • POWER,
    • HOME
    • VOLUME UP
  2. The unit should power on. Once it does, you can release power.
  3. Use the volume UP and Down buttons to select "Wipe/Factory Reset" from the recovery menu.
  4. Activate the reset using the HOME button.
    When the DVR goes through it's setup again, it will be at factory defaults. The password will be 4321.
Samsung Security DVR Reset Procedure #4 This reset will work on SDR models. It may also work on other models.
  1. With just the cameras showing, press the following in quick succession using the remote:
    • Freeze
    • Alarm
    • Freeze
    • Alarm
    • Freeze
    • Menu
    • Enter
  2. Make sure you press them quickly, one after the other. If it doesn't work the first time, try doing it several times. It can take many tries to get the timing right. If/when it works, you should get a screen that gives you the option to reset.
Samsung Security DVR Reset Procedure #5 This reset will work on SDR models where procedure #4 failed. It may also work on other models.
  1. Press the DVR Button to place the system in DVR Mode
  2. Press:
    • Freeze
    • View
    • Return
As with Procedure #4, you may need to press Freeze, View, and Return in in quick succession a few times to get it to work. The timing can be tricky.
Samsung Security Reset Procedure #6 Courtesy Sergio Ayala
To factory reset the SDR-B74301
  1. Reboot the DVR
  2. Once the DVR has rebooted, enter the following sequence on the remote:
  3. UP, RIGHT, 5, 3, 3
  4. You will be prompted to do a factory reset. Confirm
This has been confirmed by several people. Thank you, Sergio! If this works for you, please thank him in the comments below.
CCTV Networking Technical Support
Sep 18, 2017 | Samsung Home Security
I have just purchased a Kkmoon dvr/avr H.264 Model AVR7308 and after purchasing a WD 500gb sata3 cctv hard drive and installing it in the unit I cant get the avr to recognize it.
Some Manufactures have a compatibility list. Before you bang your head for too long, see if the drive is compatible with your DVR. If not return it and buy one on the list.
Feb 28, 2017 | The Computers & Internet
Qihan dvr super password
Forget the DVR password, how to generate a new one with software ...
www.hkvstar.com/.../forget-the-dvr-password-how-to-generate-a-new-one-with-softw...
Nov 4, 2013 - If you forget the DVR password, you can use the password generation software to get a new super admin to unlock the DVR.
Reset DVR password to Factory default - • CCTV Forum
www.cctvforum.com/viewtopic.php?t=39460
Jan 26, 2014 - 15 posts - ‎4 authors
I have a DVR shown below and I am not able to reset the system to the factory default. It is an 8 ch standalone, unbranded, no make or model ...
How to - Zmodo DVR Resetting to Factory Defaults - YouTube
? 0:46
https://www.youtube.com/watch?v=rT-cUgWbHQM
Sep 24, 2009 - Uploaded by CCTVHotDeals
This video shows how to reset your DVR to factory defaults. ... Reset PasswordDVR H.264,AHD, With Super ...
CCTV H264 DVR password reset superpassword super password ...
https://dashcamtalk.com > Home > Forums > General Forum > Off Topic
Jan 2, 2015 - 12 posts - ‎7 authors
I was searching on internet for this problem because I set the password one year ago, I forget it and I want to reset the password. I have a ...
How to reset password ?
support.qube.asia/127247-How-to-reset-password-
STEP 2- Open the cover of the DVR. STEP 3- Remove the CMOS battery. STEP 4- Power On the DVR. STEP 5- Enter a password. Username: As given.
[PDF]Qihan NVR manual
www.riasztobolt.hu/pictures/down/en_tmanual_quihannvr.pdf
Support modifying the user's authority and password. Subdivide the authorities (preview, ... DVR: Digital Video Recorder. IPC: IP Camera. IP PTZ: Network High ...
Aug 13, 2014 | Home Security
Factory reset for a speco 16TL500 passcodes lost and needing reset to default
Open The Case and inside you will see a battery, silver disk, remove it for 5 mins and reinstall it, power up the DVR and it should be set to factory defaults, the factory default for Speco DVR's is 1234
Feb 25, 2014 | CSi Speco SPECO 4 channel TL SERIES...
Home Security Logo
7,218 people viewed this question
Top Home Security Experts
Marvin
Marvin
Tom Chichester
Are you a Home Security Expert? Answer questions, earn points and help others
