This is what I tried cleaned all contacts reset radio did not work so I pulled the fuse for awhile and also bought a different face plate and that acts the same as original no volume.Is there any tests I can do or does anyone no the problem?
SOURCE: sony cdx -m8800
Remove the radio, disconnect the blue wire, and connect the blue/white wire in its place. This should fix your problem.
SOURCE: No display
If you have tried another front & its the same, then its the main unit,...
Are the copper contacts clean? use rubbing alchol.
Are they intact? No? it needs to be professionaly repaired.
SOURCE: CDX-S2000 Volume, Source, and Mode buttons not working????
Hey jshaff, try taking off the detachable front, and you will see a reset button, press and hold in for 10 secs, this should solve your problem. if it doesn't work first time keep trying. you must have power to the head unit for this to work. you will hear the cd make a noise and that should be that, try and let me know.
SOURCE: Sony Xplod cdx-gt310
it is most likely shorted faceplate, either send it to be repaired heres address:http://www.xplodsony.com/support or buy a new one at wholesale at this address:www.godspeedaudioheaven.com
SOURCE: the clock on my sony cdx-gt71w car deck keeps reseting
It sounds like the yellow wire coming from your Sony is not hooked up to a constant positive or battery lead (it is used to keep memory and provide the main source of power to the deck). The red wire should be hooked up to a switched or ignition lead (and it is used to turn the unit on and off with the key).
This will allow 2 channels to run 100 watts each @ 4ohms with an additional single channel with 250 watts @ 4 ohms.
The single sub channel is created by bridging channels 3 & 4
