SOURCE: SE W960i. TouchScreen Not Working
i have the same problem with my w960i. what i did is replace a new touch screen. i brought to mall repair shop they qoute me 4,000 pesos. what i did is i bought a touch screen then , i ask the small time repair shop to replaced it, then it cost me 2,000 pesos all in.
SOURCE: My plotter seems not to output NMEA to my DSC radio and auto helm
Your plotter can talk to you Radio and your pilot. It sounds like one of two things.You must go into the system setup menu and turn on the nmea sentances. You will need to turn on RMB, RMC, GGl at least. You can turn on all the sentances if you like it does not matter. If this does not fix, check color of wiring is correct. Remember you have to go from NMEA + out (on plotter) to NMEA + IN on Radio.Then you need NMEA - out(on Plotter) to NMEA - IN on Radio.
You can look at the sentances wirth a multi meter coming out of your plotter. You put meter in DCV and connect across the NMEA out lines. You will see the meter move every second or so as it send a sentance.
Testimonial: "Good to talk with someone who knows!!"
SOURCE: I have a raymarine rl70
A replacement backlight is available from a company called Being Seen Technologies,
I believe their toll free phone number is 888 457-0117
good luck
SOURCE: My Raymarine C80 CHart plotter won't load.
Check to see if this is a power issue by connecting to shore power and fully charging your batteries overnight with instruments off. While still connected to shore power, with batteries fully charged, turn on C80 navigation system. If the loading screen comes on and does not reset, then try holding down the button immediately to the right of the red power button for at least 3 seconds to see if the system re-boots.
Testimonial: "Factory reset solved the problem. Soft key next to power button worked a treat!"
