Question about Curtis Televison & Video
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Type in this key phrase " my service table today " in the search box at the top right of the the home page, to get gathered some pages which has the details of practical experiences of the author of that site. The search result might display about 20 Nos of related posts. Press the "All posts" at the bottom of the list, then you can select them one by one.
Posted on Jun 05, 2017
SOURCE: Curtis Mathes TV Remote Control Codes for Programming the remote to the TV
I own a One-for-All universal remote, and my booklet says the setup code for a Curtis Mathes TV (without a built-in DVD or VCR) is one of the following numbers: 0030, 0047, 0054, 0060, 0093, 0145, 0154, 0166, 0451, 0702. I can not guarantee these numbers will work with your remote, but it is worth a try.
Posted on Jul 06, 2008
SOURCE: How do you reset your Curtis Mathes Tv after the
TIME TO GET OUT YOUR USER'S MANUAL AND YOUR REMOTE.IF YOU STILL HAVE A PROBLEM CALL A SERVICE TECH.
Posted on May 15, 2010
SOURCE: Need code for Cable remote to work tv
Try
http://www.remotes.com/
Thanks
Frank
Live-Tech
1-888-361-8511
http://www.mylive-tech.com.
Posted on May 23, 2010
SOURCE: What universal remote code do
The reality is that almost everyone ends up using two remotes. One to turn the tv on and off plus adjust the volume plus the second remote to change channels within cablevision.
Call cable vision and complain. They could upgrade your remote if they chose to so u could do it all on one remote. Hope this explanation helps you. Joe
Posted on Oct 14, 2010
