Question about LG Refrigerators
My refrigerator lg LFC20760SW. It just went off by itself. It won't power on at all what can I do.
Posted by Araceli Molina on
Andy
    Habit-Forming:
    New Friend:
  • 117 Answers
Check to see if breaker is tripped .Unplugged fridge and check to see if there is power to outlet .If there is power to the outlet then follow the fridge power cord and check that connection .Maybe a burnt wire
Posted on Jun 03, 2017
Replace fuse on lg refrigerator ebr41531301
there is a power relay connector that is attached to the compressor from the power supply. shut off, unplug the fridge, and remove cover on bottom of fridge. find the compressor and tank, the power goes direct to it. unplug it and look for burnt or nasty looking connector. if that is bad , it will cost 50 to 70 to replace... if not chances are the compresser is shorted out... good luck.
Sep 26, 2014 | LG Refrigerators
LG 42CS560 42 Class LCD HDTV won't come out of standby mode.
Could be an open internal fuse or power supply failure
Jan 05, 2018 | LG 42CS560 42 Class LCD HDTV
I have the LFC20760SW. It sound like a fan running, and it stops when you open the refrigerator doors. What concerns me is that it is real loud, real loud. Not the normal hum.
FREEZER FAN MOTOR MAY NEED REPLACED. THE EASIEST WAY IS TO TAKE OFF THE BACK PANEL IN FREEZER AND REMOVE THE FAN
MOTOR, TAKE IT TO THE NEAREST APPLIANCE PARTS STORE WITH YOUR MODEL NO.
EASY JOB.
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
need more help go here:
http://www.applianceaid.com/procedures.html
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
Sep 16, 2011 | LG LFC20760 Bottom Freezer French Door...
My lg fridge just stopped working no lights or power, the receptacle works and no breakers tripped
I have a similar manual that shows just what you are up against. How about the power cord itself? Is it ok?
FRENCH DOOR REPAIR MANUAL
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 16, 2010 | LG LFC20760ST Stainless Steel Bottom...
I am looking for a refigerator either side by side with no water and ice or a bottom freezer refridgerator needs to be 31 inches wide.
Have you checked out the LG model LFC20760SW French door with no external dispenser, which fits a 30 inch wide opening? (PS. Buy from a small dealer, not a big box or Sears if you want good service over the life of your product) Check where to buy at with your zip code http://www.lge.com/us/appliances/refrigerators/LG-french-3-door-refrigerator-LFC20760ST.jsp but avoid the big guys. You may have to go to a 10 or 20 mile radius to find a servicing dealer, but it will be worth the effort.
Jan 21, 2010 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
LG LFC23760SW stopped working-no power. Power
Unplug the unit and remove the board cover. The fuses are soldered in but can be changed with a soldering iron. They are glass and easily spotted on the board.
Jan 13, 2010 | LG LFC23760SW Side by Side Bottom Freezer...
LG GR-292R freezer works/fridge does not.
well i have the exact same refrigerator but opposite problem.... the freezer works but the entire refridgerator is a freezer....why is the fridge part freezing everything. This appeared to happen after the power went out and the entire fridge is a freezer now.
Mar 02, 2009 | LG LFD25860
Refrigerators Logo
272 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Colin Stickland
Colin Stickland
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
