Question about Internet Computers & Internet
Hy, I am not able to access Internet on changhong though everything is fitted properly. My internet is also working cool. So dere is a problem with the tv. How should I overcome it?
Indermani Tiwari
    Habit-Forming:
    New Friend:
  • 36 Answers
Reset Internet Explorer settings
You can reset Internet Explorer settings to what they were when Internet Explorer was first installed on your PC. This can be useful for troubleshooting problems that may be caused by settings changed after installation. Note that resetting Internet Explorer isn't reversible, and all previous settings are lost after reset.
  1. Close all Internet Explorer windows. Select the Tools button, and then select Internet options.
  2. Select the Advanced tab, and then select Reset.
  3. In the Reset Internet Explorer Settings dialog box, select Reset.
  4. When Internet Explorer finishes applying default settings, select Close, and then select OK. Restart your PC to apply changes.
Posted on Jun 03, 2017
5 Related Answers
Anonymous
  • 59 Answers
SOURCE: Linksys WUSB54GC 802.11g/b can find access point but not internet
do one thing remove the prefered networks from the list of prefered network sand after that connect to the network
u will be able to go online after that ....
Posted on Nov 27, 2008
Anonymous
SOURCE: MY LINKSYS WRT54G WONT READ MY COMPUTERS INTERNET CONNECTION
Ok to start the yellow ethernet port should be connected straight to the Linksys router in the ethernet in port. Then you connect the cmputer to one of the other the 4 ports on the back of the wireless router. wala you shouldn't have any more trouble after that.
Posted on Jan 11, 2009
Anonymous
  • 54 Answers
SOURCE: cannot access internet with a linksys router
Make sure DHCP is turned off on the modem or else you will get ip conflicts. Also make sure it is plugged into the wan port on the router
Posted on Jan 15, 2009
Anonymous
  • 141 Answers
SOURCE: LINKSYS WRT54GC ver2.0
Have you call linksys tech support? Try this http://technicalsupport.blog.friendster.com/
Posted on Feb 15, 2009
mattvierra
Matt Vierra
  • 75 Answers
SOURCE: I AM UNABLE TO ACCESS INTERNET THRU MY HYBRID APPLE MAC DESK TOP-
Go into network set up a shared Internet connection using ICS (Internet Connection Sharing) You can use Internet Connection Sharing (ICS) to share an Internet connection among two or more computers on a network. First, you need one computer, called the host computer, that is connected to the Internet and that has a separate connection to the other computers on your network. You enable ICS on the Internet connection. The other computers on your network then connect to the host computer, and from there to the Internet through the host computer's shared Internet connection.
If your computer is connected to a network, network policy settings might prevent you from completing these steps.
On the host computer (the computer whose Internet connection you plan to share):
  1. ?id=microsoft.windows.resources.shellexecutetopiciconClick to open Network Connections.
  2. Right-click the connection that you want to share, and then click Properties.getcontent.aspx?assetid=18abb370-ac1e-4b6b-b663-e028a75bf05b&documentset=en-us&renderkey=signed1 If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
  3. Click the Sharing tab, and then select the Allow other network users to connect through this computer’s Internet connection check box.
Posted on Jul 22, 2009
1helpful
How do you auto tune a Changhong TV Mod No LED3207b if you dont have the remote?
Grab best holiday deals and discount up to $50 on flight tickets to India:
www.tripbeam.com
www.airfarebooking.ca
www.flyopedia.com
www.tripbeam.ca
My Rangemax wireless wndr3000 is not working properly, though it has in the past. The problem seems to be that I'm hooked up to the wireless network (ex. I can print wirelessly), but with no internet....
Same situation here. Wired connection from modem works fine. I can also log in to the router via routerlogin.net. However, the router does not detect an internet connection.
1helpful
Using Compaq Presario CQ50 - Even though wireless internet shows connected in lower right hand corner icon, when attempting to access internet get message, "Internet Explorer cannot display the webpage",...
it could be an issue with proxy on the browser.
To solve it :
click on tools on internet explorer at the top, go to internet options, clikc on connection tab, click on LAN settings, and uncheck proxy settings nad click ok. then refresh the page and check if you are online.
5helpful
3answers
Nokia 7210 Supernova handset can not access net
My Nokia 7210 Supernova handset can not access internet, though it is working on P.C. as a modem. When I try to open webpage in mobile, it reflects a message "Subscribe packet data first" and "Link not available". Sometimes it says "Connection not available". Tough all settings are installed properly. My service provider is BSNL, UP East Circle (Faizabad district). Please suggest me the solution for this problem so that I can access net from mobile too. -RP Shukla Faizabad
Aug 09, 2009 • Nokia 7210
1helpful
Can't access internet on my sony ericsson Z750a
Yes, perhaps that an add on and you might have to ring your provider and get the phone enabled. I disabled mine because I kept hitting the browser button and got charged everytime it happened even though I didn't access the internet. Anyway do this I am sure it will work, watch charges though, make sure you are covered, or aware of what it will cost.
Internet Access to Various Websites is Hit or Miss
check your antivirus program, it may be on its black list or blocked .
Can't access the internet on my A380i
You don't provide enough information to give you a proper answer. If it is a blackberry, you need to have the blackberry service and not just a regular multimedia package. If it's a regular phone, your account may not have been setup properly. While your phone is on, pull out the battery. Wait about 15 minutes then put the battery back in and turn it on. If it still doesn't work, you will need to contact AT&T and have them check that your account is setup properly.
Also, I'm assuming this is an AT&T branded phone. If not, then this may be the problem. You may need to manually enter the internet/network settings.
May 07, 2008 • Cell Phones
2helpful
4answers
I CAN'T SEND AND RECEIVE MMS MESSAGES
call the company who your sim card is with, and they will give you settings to setup MMS (and internet access if required).
it needs to be setup through them!
2answers
The other computer wont log on to the internet
hi, even if it's connected properly if its not properly configured it still wont connect..so does it mean that other pc could connect? how bout your main pc does it work? which pc wont work? whats the o.s.? if you like i could help you i just need to know the full detail so i could help you diagnose it
Computers & Internet Logo
Ekse
 Francisco Mauricio...
 Grubhead
Grubhead
