SOURCE: Avid Juicy 7 disc brakes
It sounds like you have a piston that is not fully returned and is sticking.
Get a big flat bladed screw driver, take the wheel out and very carefully insert the screw driver into where the disc would sit and use the screw driver to try and push each brake pad back in without damaging your brake pads.
If this works go to a local bike shop and ask them for a avid brake insert for transporting your bike so this does not happen in future! :)
SOURCE: Back-up valve is not working properly. Can I take
With these pool cleaners, if they are not backing up, there are several things that you could try. Lift the valve out of the water and watch the jet. It should be going on and off. If it is not, you will need to replace the back up valve. If it appears to be working properly, try adjusting your wheel RPM.
SOURCE: The wheels on my Polaris
There are a couple things that you should check with these pool cleaners if the wheels are functioning properly. Check the filter screen in the in-line filter assembly and clean if necessary.Make sure that you do not have any debris or obstructions that could be halting wheel function. Even though you seem to have plenty of water, check the RPM and make sure they are between 28 and 32.
SOURCE: My Polaris 3900 Sport is
With these automatic pool cleaners, if they are not staying firmly on the bottom of the pool, it is most likely that there is air in the appliance casing.Try submerging your cleaner. Keep the cleaner vertical while you are putting it in slowly to let the air out. Ensure the unit sinks to the bottom of the pool.
SOURCE: hello. i have a
Defect in single side wheel. It strips out causing it to run in circles. Replace that wheel
