How to find fuse boxs
FUSE PANEL LOCATION
The fuse panel is located in the engine compartment. A label on the inside of the cover lists the fuse amperage and circuits protected.
volvo 850 fuses fuse panel layout service repair manual
FUSE PANEL IDENTIFICATION
Fig. 1: Fuse Panel Identification
Courtesy of Volvo Cars of North America.
WARNING: Always disconnect battery ground cable before servicing "high-current fuses. It is recommended that "high-current" fuses be replaced by a qualified technician.
* 1 - 15 Amp
Fuel Injection, Distributor Ignition, Automatic Gearbox
* 2 - 15 Amp
Fuel Pump, Alarm System
* 3 - 10 Amp
Courtesy Lights, Oil Level Sensor
* 4 - Not Used (1993-95)
* 4 - 10 Amp (1996)
Electronic Start Inhibitor (Immobilizer)
* 5 - 30 Amp
ECC Blower (Speed 4)
* 6 - 25 Amp
Central Locking System, Alarm
* 7 - 15 Amp
Audio System (Amplifier)
* 8 - 25 Amp (1993-95)
Power Antenna, Trailer Connector
* 8 - 40 Amp (1996)
* 9 - 30 Amp
ABS, Traction Control System
* 10 - Not Used (1993-95)
* 10 - 15 Amp (1996)
Heated Rear Seat (If Equipped)
* 11 - 30 Amp
Heated Rear Window & Side Mirrors
* 12 - 10 Amp
Brake Lights
* 13 - 15 Amp
Hazard Flashers, Headlight Flashers, Alarm
* 14 - 30 Amp
* 15 - 10 Amp (1993-95)
Audio System, Courtesy Lights, Door Open Light, Trunk Light, Glove Box Light, Remote Control Central Locking System,
Oil Level Sensor, Seat Belt Reminder
* 15 - 10 Amp (1996)
Oil Level Sensor, Seat Belt Reminder, Data Link Connector
* 16 - 30 Amp (1993-95) Accessories
* 16 - 30 Amp (1996)
Power Antenna, Trailer Connector, Accessories
* 17 - 10 Amp
Key Reminder
* 18 - 25 Amp (1993-95)
Heated Front Seats, Power Mirrors
* 18 - 15 Amp (1996) Front Fog Lamps
* 19 - 15 Amp
Left High Beam Headlight
* 20 - 15 Amp
Right High Beam Headlight, High Beam Indicator
* 21 - 15 Amp
Left Low Beam Headlight
* 22 - 15 Amp
Right Low Beam Headlight
* 23 - 10 Amp
Left Parking Light, License Light
* 24 - 10 Amp
Right Parking Light, Bulb Failure Warning Sensor
* 25 - 10 Amp
Rear Fog Lamps, Fog Lamp Indicator
* 26 - Not Used (1993-95)
* 26 - 25 Amp (1996)
* 27 - 15 Amp
Back-Up Lights, Turn Signals
* 28 - 10 Amp
Cruise Control, Heated Rear Window, Seat Belt Reminder Light, Shiftlock, Bulb Failure Warning Sensor, Heated Rear Seat
* 29 - 15 Amp
* 30 - 10 Amp
Cigarette Lighter
* 31 - 25 Amp
ECC, ECC Blower (Speeds 1-3)
* 32 - 10 Amp
Audio System, Remote Controlled Central Locking System
* 33 - 15 Amp (1993-95)
Power Seats, OBD Test Socket, Tailgate Washer/Wipe (Wagon)
* 33 - 15 Amp (1996)
Power Seats, Tailgate Washer/Wipe (Wagon)
* 34 - 25 Amp
Windshield Wiper/Washer, Horn, Headlight Washer/Wiper
* 35 - 10 Amp
Instrument Lights, Sun Roof, Traction Control System
* 36 - Not Used
* 37 - Circuit Breaker
Power Windows, Power Sun Roof
* 38 - Not Used
* 39 - Circuit Breaker
Drivers Power Seat
* 40 - Circuit Breaker
Passengers Power Seat
RELAY PANEL LOCATION
The relay panel is located at the left corner of the instrument panel.
i copied this off a volvo site Hope this helps
Oct 10, 2016 |
Volvo 850 Cars & Trucks
