Question about Vulcan Heating & Cooling
Bonaire Vulcan ducted heater keeps coming up with code HC 01 F 03
Posted by Neal Webster on
3 Related Answers
blender719
  • 53 Answers
SOURCE: are bonaire and vulcan are same brand?
yes
Posted on Jul 17, 2009
Anonymous
SOURCE: I have a similar problem
I just went into the Bonaire website and downloaded their FAQ on gas ducted heating from their support link. Their instructions are pretty easy to understand.
Posted on Sep 09, 2009
Korede Atunrase
  • 1456 Answers
SOURCE: Vulcan Ducted Heater has gone
Hello
You are experiencing a thermostat problem,what you simply need to do is to call up an experienced repairman and have the thermostat of your heater replaced
Posted on Apr 23, 2011
Bonaire vulcan comfort control
No it cant really be fitted as the evap system uses much larger duct and also in some cases people use a different type of duct that when running a gas heater threw it it tends to melt with the heat. Your best option would be to get new ducting that way you can size it correctly so you dont have air alance issues down the track.
May 10, 2014 | Heating & Cooling
Bonaire Vulcan ducted heating system flashes F08 and HC 01. What do I do?
I was able to fix my Pyrox ducted gas heater (flashing between HC01 and F08 by pressing the reset button on the main PCB located in the main heating unit.
The reset button is located next to a set of indicator led's. It's easy to get to by just removing the covering shroud.
May 02, 2011 | Heating & Cooling
Vulcan Ducted Heater has gone into reset a couple of times in the past fortnight. This morning not in reset not functioning. Tried reset. no go, held reset on Bonaire wireless remote code F1 11 displayed??
Hello
Apr 22, 2011 | Heating & Cooling
VULCAN BONAIRE Users manual.
Try here http://www.bonaire.com.au/support/documentation/owner/default.aspx
Dec 31, 2009 | Heating & Cooling
Sep 08, 2009 | Heating & Cooling
Wiring diagram required
Just wondering if you h
Apr 19, 2009 | Washing Machines
Heating & Cooling Logo
215 people viewed this question
Top Vulcan Heating & Cooling Experts
Paul Carew
Vernon Taylor
john h
Are you a Vulcan Heating and Cooling Expert? Answer questions, earn points and help others
