Question about Makita Saws
HOW DO I REMOVE BAFFLE PLATE FROM MAKITA 814
Posted by Amanda on
Makita LS1030 (not LS1030N) won't turn.
The nut is not on the bottom, but under the snapout kerf plates. You remove the plastic kerf plates to access the bolt. Once you remove the nut the turntable will lift straight up and off. Check the stainless steel wear plate at the rear for burrs or wear.
Do not use oil or wd40 etc - it will collect sawdust and cause problems down the road. I recommend a pure silicone spray that will dry completely and provide lubrication.
Jan 13, 2015 • Makita Saws
Austwood wood heater cannot remove top baffle plate in the firebox
you dont remove it,you dont need to clean it besides tapping the creosoot off,it burns it off
Baffle plates
baffle plate for the flupipe or what..
Dec 16, 2013 • Pool & Spa
How do i reinsert the black little chip on my rainbow vaccum e2 so it can turn on
<p>The part that is sounds like you are talking about is the <a href="http://www.rainvac.com/interlock-plunger-e">Interlock Plunger.</a> This part is under the <a href="http://www.rainvac.com/baffle-plate-asm-right-e">Right Baffle Plate Assembly.</a> It works with the <a href="http://www.rainvac.com/switch-interlock-e">Interlock Switch</a> for safety so the Rainbow will not turn on unless it is latched onto the water pan. Remove the Right Baffle Assembly and insert into the small pocket that the Interlock Switch is installed.</p>
<p>RainVac </p>
<p><a href="www.rainvac.com">www.rainvac.com</a></p>
<p>800-523-0510</p>
WHAT IS THE REASON FOR BAFFLE PLATE IN OIL PAN AND DOES IT NEED TO BE PUT BACK IN AFTER REMOVE I DAMAGED MINE WHILE TAKEN OUT
The baffle plate serves a couple of purposes including reducing oil slosh during turns. More importantly it adds to the stiffness of the block and is a necessary component and will need to be replaced.
What is the most efficient way to remove and replace the switch on the Makita 2703?
there is only one way that I know of. Unplug tool and lay on its backside to expose the undercarriage of tool, remove the screws holding the switch plate on and remove box
Makita LS1030 miter saw, base doesn't rotate as freely as it should
dust and debris get under the plate; remove the fence from the base and the lock mechanism from the plate; flip saw over and remove the retaining nut from the spindle, the base should pull easily away from the plate.thoroughly clean the bottom of the plate and the top of the base and check for/remove any imperfections in either with emory cloth. use a mineral oil based lubricant when reassembling and be careful not to overtighten the retaining nut.blow out the base after use with an air gun and lube lightly after each day's use to avoid this in the future
REMOVING THE DASH ON A 1980 CAMARO SO I CAN REPLACE THE HEATER CORE
it is not ness to remove the dash.
Drain cooling system.
Remove inlet and outlet hoses from heater core.
Remove lower right hush panel.
Remove lower trim panel.
Remove heater case cover screws.
Remove heater case cover.
Remove core support plate baffle screws.
Remove heater core, support plate and baffle from car.
Reverse removal proceedure to install.
Refill cooling system and check for leaks.
2answers
Can't get clutch plate off of makita 340 dcs
you need a piston stop to stop the engine from rotating,then with a clutch tool you can spin off the clutch,most of them are left had thread.if you don't have a clutch tool you can use a hammer and punch on one of the main arms of the clutch itself.for a piston stop you can use a piece of 1/4"rope.put the piston at the bottom of the stroke and stuff the rope in the sparkplug hole,this stops the piston from reaching it's full stroke.
Rainbow se d4c
There a number of screws that you have to get out. Maybe a screw extractor may work, last resort would be to drill the heads off of the screws, then after the plate is off, remove what is left of the screws.
Feb 16, 2008 • Vacuums
Saws Logo
Top Makita Saws Experts
ray gallant
Parson's Repair...
Parson's Repair...
Are you a Makita Saw Expert? Answer questions, earn points and help others
