Question about Sony Car Audio & Video
Sony cdx gt270s required The current version of Volt or Amp
Posted by neeraj singh on
1helpful
NEED WIRING DIAGRAM FOR SONY CDX-GT520U
red - ignition switched 12 volt
yellow - constant power 12 volts
black - ground wire
orange - dimmer wire don't use
speaker wires
drive side front
white +
white/black strip -
passanger front
gray +
gray/black strip -
drivers rear
green +
green/black strip -
passanger rear
purple +
purple/black strip -
blue - remote amp turn on wire
blue/white strip - either power antenna or remote amp turn on also
[email protected]
1helpful
Does the sony cdx -gt25 work with the sony cdx t69
To connect T69 with head unit GT25,bus cable connecting port is required through which you can connect cd-changer with your head unit.As GT25 has no bus port,it does't work.
2answers
I need to see a wiring diagram for my sony CDX-GT63UIW
You can download and print the installation manual and wiring diagram for Sony CDX-GT63UIW in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this helps. Kindly let me know if you have any difficulty in downloading the manual.
Thanks for using FixYa.
Sony cdx gt63OUI front loader keeps resetting to factory settings when the car is turned off? please help..
check the yellow wire ,he needs to be connected to a direct 12 volt feed always maybe that´s all your problem
Ribbon
Part Store is good place to buy required part of CDX-M630. type part number (would be written on flexible wire) in search box and enter to see result.
7helpful
2answers
Wiring Diagram For Sony Disc Player
how do i install a cdx-s2210 to my 92 camry..what wires do i connect?
2answers
How do i program the sony cdx-m8800 to save the radio stations?
Manual
javascript:moreinfowindow('http://www.docs.sony.com/reflib/docget.asp?manualid=14979&template_id=1&region_id=1&DL=',600,560,10,10,'Manuals')
2answers
HOW TO NAME THE ELECTRICAK SOCKET
If you are asking about CDX-R3300 Sony CD Player, please click Sony website to download Installation guide and User manual for correct info about terminals and how to plug it.
3helpful
SONY EXCD-206 December 1996
I have the same radio, the radio's harrness has a red wire ignition 12 volt,yellow battery 12 volt, black ground, and a blue Iam not positive it can be the amp, or illumination.
Cdx m 630
Do you lose them only after the car is turned off? if so, your 12 volt Costant wire (yellow) is hooked to a switched 12 volt source.
Car Audio & Video Logo
Top Sony Car Audio & Video Experts
 Francisco Mauricio...
xxxxxx xxx
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
