Question about Jump Start Garden
Simplicitw lawn tractor has new battery.Engine tries to turn over then quits.It turns over when I jump start it with my truck. What are the possible reasons?
Posted by Jack Mahoney on
Dan Kelly
    New Friend:
  • 6 Answers
Week starter may be
Posted on May 31, 2017
The engine clicks when i turn key, how do I determine if it is the solenoid or starter?
try jumping the battery with your car battery first. if it cranks, charge battery and possibly adjust valves. If not, try jumping directly to the starter. If that works, replace the starter solenoid. If not, might be the starter itself.
Jun 01, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Does a bad battery cause my tractor to not turn over?
Yes. Verify it is the battery by jumping mower off with car battery. If turns over, replace battery. If cannot turnover by jumping, try bypassing start solenoid by tapping positive cable to battery post on starter. Starter should turn. If starter doesn't turn, have starter tested.
May 31, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman Rider Starting Issues
If you turn engine over by hand, is it hard to turn at the start? If yes, adjust the valves.
Apr 28, 2013 | Garden
Murray lawn tractor with B & S 12.5 engine seems to lock while trying to turn to start
Hi, it will be either the battery(check by jump starting with another good battery and jumper leads) or the starter solenoid(check by connecting positive jump lead directly to starter motor post. If none of this helps the valve clearances may be to wide which stops the decompressor working. Regards Phil.
Jul 03, 2012 | Garden
My craftsman lawn tractor quit while cutting heavy grass. wouldn't restart..........pushed it to the garage............ took off deck......... still woundn't start replaced battery ......... still will...
Try using jumper cables and jumping from the positive battery post to the starter lug where the main cable hooks to the starter. If you don't have jumper cables find the solenoid on the inside of the right side panel. Pull the rubber caps off and jump that with an old screw driver if the engine turns and starts on either occasion it is the solenoid. Part # 192507 sells for about $15.00 at searspartsdirect.com
Oct 08, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Won't start
it sounds like the battery doesnt have enough crankinc amps. thats a pretty big engine and should have probably have atleast 250 cranking amps. its possible the starter is going bad also
May 03, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
2140 cub wont turn over when trying to start
Change the solenoid, if you can jump the posts on the solenoid and the engine turns over...the solenoid is bad
Apr 02, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Turn key and get a click
the started is probably jammed and needs to be unbolted and put starter bendix gear back in starting position turning over an engine too long on a jump start can cause this
Apr 02, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
37 people viewed this question
Top Jump Start Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
Are you a Jump Start Garden Expert? Answer questions, earn points and help others
