Golf Logo
J
James ferguson Posted on May 31, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Myezgo 2007 golf cart wont charge thr batterys bill has the same cart his charger wont ework either
Ronald Prier
Level 2:
New Friend:
  • Expert 101 Answers
  • Posted on Jun 05, 2017
Ronald Prier
Expert
Level 2:
New Friend:
Answers
101
Questions
0
Helped
145912
Points
158
Check your batteries under load, then check the wiring. Make sure the black and white charging wires are connected to the mains. If all good then check the pins in the charging receptacle.
I have a 2010 yamaha golf cart,has brand new batteries,and the batteries drain by nine holes,is it the voltage regulator? or something else
Make sure the batteries are fully charged. if your cart has it's own charger it may not fully charge. I would purchase a portable one and make sure they fully charge then you would know whether the cart charger is working.
Nov 05, 2017 • Golf
Wyy wont my my batteries charge on a rzgo golf cart
Bad battery, bad wiring, bad charger-- take your pick.
May 30, 2017 • Golf
I CONNECTED MY GOLF CART TO THE CHARGER AND CHARGER IT FOR A COUPLE HOURS NOW IT WONT MOVE FORWARD OR IN REVERSE.
Troubleshooting a golf cart - APLawrence.com
aplawrence.com > Miscellaneous
Mar 29, 2015 - If you need help with a golf cart, I suggest asking at Buggies Unlimited. .... Within a half hour I had everything in place, cinched down, connected and ready. ...it is still getting power to the forward and reverse other words itsworking and ... I let mybatteries completely drain and now the charger won't turn on, ...
Put Spring In Your Electric Golf Cart ' Golf Cart Talk Blog
https://www.golfcarcatalog.com/golf-cart.../put-spring-in-your-electric-g...
Mar 9, 2004 - On a car with 8-volt batteries, connect a 12-volt charger to each individual ... If you do not have a 'Regen' system, then just put the Forward/Reverse(F/R) switch into the .... speed controller stays dormant and will not permit the car tomove. ..... My other question would be did anything "fail" in the cart prior to ...
About Golf Cart Battery Chargers ' Golf Cart Talk Blog
www.golfcarcatalog.com/golf-cart-blog/about-golf-cart-battery-chargers/
Apr 1, 2012 - Tutorial on golf cart battery chargers, the basics, what goes wrong, ...BATTERIES ARE DEAD AND CHARGER WON'T COME ON ... This is usually indicated by a car that creeps when the brake is off and the car is in forward orreverse. ... a connected pair of batteries with a 12 volt, auto style battery charger.
Basic EZGO Golf Cart Problems And How To Fix
Feb 09, 2016 • Golf
2answers
Charger wont kick off after fully charged.
Charger won't shut off - Buggies Gone Wild Golf Cart Forum
www.buggiesgonewild.com > ... > Electric Club Car
Sep 27, 2010 - 7 posts - ‎2 authors
But the cart still wouldn't fully charge. After charging the cart, I checked the voltage on the entire battery pack using my meter and then each ... 36 volt powerwise ez go charger not working
Sep 5, 2011
Club car 96 battery charger not turning off
Aug 30, 2011
2001 Club Car Charger Won't kick off
May 31, 2011
48v club car charger wont shut off
Apr 11, 2009
More results from www.buggiesgonewild.com
About Golf Cart Battery Chargers - Golf Cart TalkGolf Cart Talk
Jan 24, 2016 • Golf
Charger just workrd at my neighbors, doesn't even make a sound whwn i plug it into my cart. why does it not take a charge?
Measure your total battery voltage. That is measured across the main positive cable and the main negative cable. If you have a 48 volt golf cart and an automatic charger, any pack voltage under 42 volts will not turn the charger on. Your only recourse then would be to charge one battery at a time until you get 42 or higher.
Sep 07, 2015 • Golf
Why does my golf cart battery charger turn off after 6 seconds when battery is partially discharged?
I have seen a charger turn off like that when there is one or more bad batteries. Try a load test on each battery to see if one is bad.
You can do this with a voltmeter. Connect the voltmeter to one battery and make the cart start to move and watch the meter.
If the voltage drops a lot then it could be defective.
Aug 30, 2015 • Golf
How do you check output voltage from generator to battery in an club car golf cart
if you look at the charger plug there is a small switch it can either be held down with the cover off or with it on. It should read you between 48 and 50 volts DC with that switch in that switch will keep you from charging the batteries if it is faulty. These chargers are really rather simple and golf cart King has the motherboards cheaper than anywhere else that you can buy them. A thumbs up would be greatly appreciated if answer is helpful for your question. THANK you and GOD BLESS
Oct 31, 2014 • Golf
2answers
1helpful
2answers
Can I leave my 2004 ezgo golf cart charger plugged into the golf cart and wall all the time when golf cart not in use?
never leave charging all the time you want to charge it every 6 hrs of running time to let your batterys cycle down. it would be the same if you charge your cell phone everytime you make a call if you cant keep track of it get a state of charge its a volt metter like a gas gauge for the batterys if you do it my way you will get more run time and your batterys will last around 10 yrs if keep doing it your way them about a couple yrs on them
Top Golf Experts
Kardoc
ADMIN Andrew
ADMIN Andrew
vince
Are you a Golf Expert? Answer questions, earn points and help others
