SOURCE: Wired remote bass control knobs
I'm wanting to know the same thing... But be careful on the pin out of the control you get.
I have an audiobahn 2300HCQ amp... Before I had the 1800. The 1800 came with a remote with 6pin remote cord. I got the 2300 used and did not get a control for it. The plug on the 2300 is a 4 pin plug... I can't figure out how to cross it over correctly to get the 1800 remote to work on the 2300.
I have tools to crimp an end... Just can't figure out the color pin out.
hello!Most ep boats need to be in water in order for it to run.you say te model is 7000 ,who makes it? NQD....?
SOURCE: remote bass control short
It Could be Eiher Problem Make Sure The Remote our using is thew same brand as the amp its plugged in to
SOURCE: How do I use the remote to cont bass & treble for rxv-657 reeiver
No, Tone controls are on the front of the unit only. If your passing video thru the unit you can go into the setup menu from the harmony and adjust all the sound parameters that way "on screen" The only "EQ" capabilities are for the Center channel only. You can adjust "speaker size". "Large" setting will give you a little lower response. "Small" will crossover the speaker at "100hz" That's about as far as tone adjustment goes on this unit. Hope this helps
SOURCE: remote code for commtel control freak remote.
I can help you with your URC-3021 Universal Remote Control issues.
I do not see a listing for Alba TVs in the Urc-3021 Code List.
But don't
give up; many manufacturer's re-use other's control codes.
Therefore,
I recommend using the One For All URC-3021
Code Search, feature to find the
compatible codes to control your device.
I hope that helps.
_______________________________________________
Reassign URC-3021 Device Key
Urc-3021 Code List Download
Code Search
