Question about Orbit Hardware & Accessories
I have an Orbit 4 station timer, I've tried to reset / program several times. The problem is it repeats each station 2 times.
Posted by Lucky Jones on
David Gramlow
The manual for these old Orbit controllers POORLY explain the setting function for multiple stations. In a program (A/B/C) all stations you set up will run when that program starts. And all stations on the same frequency, Daily, etc! I found that I need to place station 1 under Program A, and station 2 under Program B, in order to properly schedule my plants, and my trees, for individually different watering schedules. So yes, in a Program, only set up ONE start time under your first station, and then all will run consecutively. Use Programs to separate your station's schedules.
Posted on Jul 01, 2020
Steve Pack
  • Orbit Master
  • 4,340 Answers
Sounds like you have multiple start times. unplug, remove battery after 5 minutes plug transformer back in and install battery. If unit is ne return it
Posted on Jun 14, 2018
5 Related Answers
protek480
Craig Butler
  • 1730 Answers
SOURCE: Orbit sprinkler system
Have you programmed the new one with all the info for date and time? Did you set the zones for the days you want and watering times?
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Jul 02, 2009
Anonymous
SOURCE: can i get online instructions on how to program my
moved into house with 4 station Orbit sprinkler unit. Manual is faded, cannot figure out how to get it to control the sprinkler system. Can I get online instructions on how to program it?
Posted on Aug 22, 2010
SOURCE: How do I get a
Welcome To FixYa
I was able to locate a manual for your timer. Go to this website
http://www.orbitonline.com/lib/media/57894-24%20rA%2812%291.pdf
Please note that this is in PDF format which means that your computer needs to have adobe reader installed. If you dont have that you can download it here
http://get.adobe.com/reader/
If you have further questions just reply back and I will be happy to assist you
Hope this Helps
Posted on Jun 04, 2011
Anonymous
SOURCE: i ned to reset the
To reset your timer, you'll need to replace the 3 AA batteries then press the reset button on the back of the housing.
If you'd like to refer to the manual, you can find the manual at orbitonline.com. Just click on the "manual and guides" link under the "Support" heading found on the left hand side of the home page. Enter the model number of your timer "62015" and click the quick search button. Your search will provide a link to the manual in up to 5 different languages in a pdf. file format. Click on the manual of your choice. Once the manual is downloaded (this will take a second or two if you have high speed) onto your computer you can print out the manual for future reference.
Hope this helps.
Posted on Jun 05, 2011
aquaman987
Gary Nigro
  • 927 Answers
SOURCE: I just got an Orbit
You don't program each station. You only program one start time that begins the cycle that consists of the three stations.
Remove all start times but the first one and make that 5:45.
Set the station times to whatever you want, 12 minutes.
At 5:45, station 1 starts.
at 5:57, station 1 shuts off, station 2 starts.
at 6:09, station 2 shuts and station 3 starts.
at 6:21, station 3 shuts.
Your FixYa Texpert,
Gary
Posted on Aug 26, 2011
Testimonial: "Thanks Gary , you are a lifesaver, the instruction I got has no info about it, only unimportant stuff. U R amazing your instruction simple and great"
Orbit timer lets sprinkler run for 20 seconds and shuts off
replace timer, they do go bad, they are not expensive home depot or Lowes
Jul 30, 2018 | Orbit Hardware & Accessories
I have a 12 station Orbit Model #57900and I want to water the same stations two to three times a day
Program modes
Program A or 1 is your primary program setting. All Zones will run on this program.
Select program B. Or 2
Set start time for program B usually an hour or two after the LAST zone (12) run time on program A or 1
1. set selected run time for the zones you want to run. 5 min -20 min ( leave the others 00:00 or off)
Select program C or 3
And repeat above.
Keep track of the start times of each program as 12 zones running for 10 min will add up to 120 min or 2 hours total. So if Program A/1 starts at 6am it will finish at 8 am. Set program B/2 start time at 11am. Them select the specific area/zone you want to run again will water the area a second time. Just remember to leave the other areas you don't want to water Set at 00:00 or off. Repeat through all the programs and you off to enjoy your day. Cheers
Jun 06, 2016 | Orbit Hardware & Accessories
Where can I get a manual for 6 station irrigation timer?
Hi Colleen, The 1st link is a 2 page manual for a 4 & 6 station indoor controller and the 2nd link is a youtube video showing how to program an orbit timer, I hope this helps because you don't give a brand or model number.........CHEERS..
https://www.hunterindustries.com/sites/default/files/IC_EcoLogic_EM.pdf
How to Program an Orbit Easy Set Logic Timer
Apr 27, 2016 | Orbit Hardware & Accessories
How do I cancel old program and reprogram?
Did you check out the instructions that came with your Orbit? If lost download a set from their web site.
Oct 26, 2015 | Orbit 4 Station Sprinkler Timer With Easy...
How can the orbit mdoel 57894 be progrmed for multiple start times?
The product manual is confusing... how do you set 1-5 am and 2-12 pm and 3-5 pm? The manual says to press program button to choose A B or C programs, but does not give steps for programming or when to press enter to confirm setting... or say which position the dial should be in when programming.
57894 lets you program separately for each station...turn dial to Run Time and use arrow keys to select a station. Press enter or arrow keys to advance to next station.
57894 offers 'select a station', 'pick days of the week or interval between watering for that station', 'duration of watering for that station'. But picking days of the week is not the same as setting exact times 1-5 am and 2-12 pm.
The dial is set to auto for programs to operate..
Don't forget to activate battery located top right on face of timer.
http://waterheatertimer.org/pdf/Orbit-57894.pdf
So the 57894 has more options than a 24-hour analog sprinkler timer that repeats same cycle each day with 14-day-skipper.
http://waterheatertimer.org/How-to-wire-Intermatic-sprinkler-timers.html
Gene
Water Heater Timers Save Money
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Mar 12, 2015 | Orbit Hardware & Accessories
Timer programming help
Maybe the sprinkler head is not advancing.
May 22, 2013 | Orbit Hardware & Accessories
I have a 6 station orbit timer and I have problem with station 2 odd days coming on again after station 4 odd days the time is set to come on at 6 am and run for 60 min an10 min after it shuts off to start...
I am somewhat confused about your station numbers. How many stations do you have? What is Ihappening with stations 1, 3, 5, 6?
Regardless, this is probably what is happening.
No matter how many stations you have, YOU ONLY PUT IN ONE START TIME. That one start time begins the cycle that starts with station 1 and proceeds to the other stations based on your station RUN times.
If you have one start time of 6:00 am, and a run time of 60 minutes for each zone, then
At 6:00 am station 1 starts.
at 7:00, station 1 shuts off & station 2 starts.
at 8:00, station 2 shuts and station 3 starts, etc.
You are not programming the individual start times for each station.
If you put in more than one start time, the timer remembers and will run all stations then go back and begin again and if there is a third start time, it will begin a third time.
Gary
Sep 02, 2011 | Orbit 57882 9 Station Super Dial...
Model 57882 9 station timer I did set up station 1 where do I begin in order to set up station 3
Question is not clear.
Do you have programming problem with the timer?
Or problem locating sprinkler heads?
Or a sprinkler valve problem?
Add a comment with detailed information.
Sprinkler timer turns ON-and-OFF.
Timer does not advance the sprinkler to next station. The sprinkler valve advances to next station when timer turns OFF.
For example, when timer turns ON, then station 1 starts watering.
Timer turns off, and then sprinkler valve automatically advances to station 2.
Timer turns on again, and station 2 starts watering.
Orbit resources:
http://www.orbitonline.com/support/
http://www.orbitonline.com/lib/media/InstallationGuide.pdf
http://www.irrigationdirect.com/media/manuals/owners-manuals/orbit/Orbit-WaterMaster-57880-Controller-Owners-Manual.pdf
Aug 02, 2011 | Orbit 57882 9 Station Super Dial...
Hardware & Accessories Logo
1,135 people viewed this question
Top Orbit Hardware & Accessories Experts
Marvin
Marvin
Are you an Orbit Hardware and Accessory Expert? Answer questions, earn points and help others
