SOURCE: Problems with Infinity Amp 611A
are you running a large ground wire directly to the battery negative terminal?
SOURCE: Protection Light
This is almost always caused by shorted output transistors. To eliminate other possible problems do the following.
Disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up, the wiring needs to be checked. If it still shuts down (goes into protection), the amp likely has blown output transistors.
Generally, an amp with blown output transistors can be repaired.
SOURCE: DUB 2502 Protection Mode help
The most common reason for an amp to go into or remain in protect mode is shorted output transistors. To eliminate other possible causes, read through the following page. Let me know if you have any other questions.
Amp in Protect Mode - Troubleshooting
SOURCE: Audiobahn DUB Mag Audio 2502 Amplifier
If the protection light is on, the amplifier likely has shorted output transistors. To eliminate other possible causes, read through the following page.
SOURCE: my amp stays in protection mode
Does it go into protect in the vehicle if you disconnect the speaker wires from the speaker terminals of the amp?
