Question about AT&T Cell Phones
I have a ZTE MODEL :Z958 AT&T brand phone that my wife dropped in water and now couple days later after letting it dry out the phone will come on but will not go past the android system recovery
Posted by jay hamlin on
5 Related Answers
Anonymous
  • 316 Answers
SOURCE: dropped in water
the water probably caused a short in the screen conector.
sorry but liquid and electronics just don't mix
Posted on Nov 07, 2007
GrinningFool
Terry Fritsch
  • 625 Answers
SOURCE: sidekick 3 dropped in a cup of water. Water got into screen.
Is the screen blank all the time?
If you look really hard can you see the items on the screen but they are really dark? If so the back light for the lcd may have burned out.
Take a look at the following site for instructions on disassembly.
http://www.gsfx.org/disassembly/index.htm
If you feel comfortable with it, you can easily replace your own.
A new lcd runs about 50 dollars shipped. If you buy it from ebay, they will usually come with instructions and the screwdriver you need. A T6 torx driver is the type needed.
Sidekick LCD screens
Good job on drying it out and pulling the battery. Thats the best thing you can do when you get it wet!
Posted on Jan 15, 2008
Anonymous
  • 69 Answers
SOURCE: How to dry out a cordless phone that has been dropped in water?
make sure the phone is swithced off imediatly, take out the battery or power suply, take appart the unit as much as you can and leve to dry for 24 hours underneath a lamp, do not use a hair dryer or heater as this heat will cause the cb to expand and can cause more damage, after 24 hours there wont be a prob
Posted on Jan 01, 2009
Anonymous
  • 52 Answers
SOURCE: wet cell phone-blank screen
Well it depends on the type of screen you have in the phone. Some have edges that can split open and lose the fluid that projects the picture so your best bet is to just replace the phones screen, if every thing else works fine
Posted on May 31, 2009
SOURCE: dropped phone in water for about 2 sec and pulled
problem can be solved.When a phone drops into water the water stays inside the phone.When the water dries insid the board of the phone, it might bridge two IC together and cause demage or makes the phone to act in a strange way.
In order to remove the water from the phone the phone needs to be serviced for it to work properly.
Get a screw driver that can loosen the screws on the phone, unscrew and remove the board of the phone, get a methylated spirit and a brush to clean the board in other to remove the water inside the phone.
After brushing the board, leave it to dry for 10 minutes and fix it back into the phone and the phone will be back to live.
NOTE: if you can lose the phone , i would advice you take it to a mobile engineer to fix it for you in other to cause further damage to the phone.
Have a nice day.
Posted on Mar 17, 2010
How to remove the pattern lock from my zte z958 android device
hi Jordan.
there is youtube videos at this link showing how to do it.
just pick the one you think will help you out.
How to remove the pattern lock from my zte z958 android device Google...
Nov 28, 2017 | ZTE Cell Phones
How to turn of field test mode on my zte z958
Field Test Mode: What it is and How To Enable it on Your Phone
www.ubersignal.com/field-test-mode
  1. Cached
  2. Similar
Most phones have a setting we call Field Test Mode that can show you useful information about your phone, including the signal strength in decibels. ... The iPhone has a hidden built-in Field Test Mode app. .... My Home; My Vehicle; My Work ...
Field Test Mode for iPhone and Android - RepeaterStore
https://www.repeaterstore.com/pages/field-test-mode
  1. Cached
  2. Similar
Your phone can tell you exactly how strong its signal is, in decibels, by entering Field Test Mode. How to enter Field Test Mode varies from phone to phone, but it ...
Finding Your Phone's Signal Strength Reading (Field Test Mode ...
support.weboost.com/.../206521937-Finding-Your-Phone-s-Signal-Strength-Reading-...
  1. Cached
  2. Similar
7 days ago - Finding Your Phone's Signal Strength Reading (Field Test Mode) ... My phone's 3 bars may well represent a stronger signal than your phone's ...
[PDF]Cellular Phone Field Test Modes - wpsantennas.com
www.wpsantennas.com/pdf/testmode/fieldtestmodes.pdf
  1. Cached
  2. Similar
Dial *3001#12345#* and press the Call button. This will launch the Field Test Mode app and where the bars/dots were in the top left corner of the screen, you'll now see "< Back to iPhone". Hold down the power button until you see "Slide to Power Off", then release it. field test mode on my zte z958 Google Search
Dec 13, 2016 | ZTE Cell Phones
Need an unlock code for my zte zmax2
Unlock by:
www.theunlockingcompany.com/index.php/zte.html
    1)Choose your phone
    2)Enter details & checkout
    3)Receive code through email
    4)Unlock your phone "The #1 ZTE Unlocking Company Online in the World"
    With over 7 years experience and 3 million phones unlocked to date. The unlocking company has established itself as the most trusted and visited website on the planet for all your ZTE unlocking needs. 1,2,3,4. Four easy steps
    Best price guarantee
    100% price guarantee
    24/7 live support OR
    How do I unlock my ZTE ZMAX 2?
    Unlocking a ZTE ZMAX 2 phone is a quite simple process.
    Please follow these steps:
The 1 ZTE Unlocking https://unlocklocks.com/blog/how-to-unlock-att-zte-zmaz-2-z958-by-unlock-code
Nov 19, 2015 | ZTE Cell Phones
Need an unlock code for zte zmax2
    Unlock by:
      1)Choose your phone
How can I find my updated package And root my zte z958
sorry but only your service provider can root your phone .
Nov 14, 2015 | ZTE Cell Phones
My zte zmax phone was dropped in water stop charging two days later start charging again but now the power button isn't functioning how could I fix it
your going have to take the phone apart and put all pieces in bowl of dried rice let it stay for at least 24 hours re assemble unit and everything should be okay
Sep 16, 2015 | ZTE Cell Phones
My sidekick lx 2009 got water damage, and now it
Let it DRY up! Remove the battery and let it sit, open, for several hours, if not days. It needs to dry up completely before it can operate again, if you're lucky. My wife dropped hers in the toilet, but quickly did what I suggest, and the phone was fine the following day.
Sep 11, 2009 | Cell Phones
Cell Phones Logo
49 people viewed this question
Top AT&T Cell Phones Experts
William Alequin
Muntejaya Ginting
Muntejaya Ginting
Vincent G
Vincent G
Are you an AT&T Cell Phone Expert? Answer questions, earn points and help others
