Question about Locks & Locksmithing
How to change battery of godrej tauras electronic safe
Posted by vinay sharma on
1 Related Answer
Anonymous
  • 113 Answers
SOURCE: small floor safe Sentry Model 3877 electronic lock and key
This manual will answer both of your questions.
http://www.sentrysafe.com/pdfs/OwnersManuals/501664.pdf
Posted on Mar 05, 2008
I AM USING GODREJ E SWIPE ELECTRONIC SAFE, SINCE LAST DAY IT WAS FUNCTIONING PROPERLY. BUT TODAY WHEN I TRIED TO OPEN IT AND JUST INSERTED PASSWORD ITS NOT OPENING. POINT TO BE NOTED THAT THE PASSWORD IS...
Is the battery dead?
Has someone tried to get into the safe causing the keypad to "freeze"?
Have you tried the "Emergency Manual Override" also know as the key? I hope the Emergency Manual Override Activation Device (the key) is not stored inside the safe.
Dec 05, 2014 | Computers & Internet
I typed the wrong key code while closing the godrej taurus safe and now i am unable to open it
To unlock a high security safe without breaking its integrity will be a tough job for you but i guess the following link may provide you with some assistance:
http://www.youtube.com/user/harisonkeys?feature=mhee
Aug 04, 2011 | Safe International Digital Electronic Safe...
I for get my godrej safe code and key misplaced i cannot open the safe now
i have godrej electronic safe. i m forgot my password. and key is inside it. Is it possible to open.
Dec 20, 2010 | Safe International Digital Electronic Safe...
When I key in the pin it says to proceed but the bolt wont open. do I have to change the batteries? If so, how do I change it? My safe is a fire safe S0607
Locksmith advice on how to install sentry safe batteries
slide open the battery cover located just below the keypad.
Insert a paper clip or pen point into the small hole in the cover. Push in while sliding cover to the right. Disconnect and remove the battery holder. Insert the 4-batteries as indicated.
reconnect the connector and put back the battery holder. Slide the cover back in place.
How do I insert the batteries on my advanced electronic lock safe? On the newer model Fireproof Sentry Safes my locksmith recommended me To install batteries,
turn the electronic lock case to the right and remove. Insert four new batteries as indicated, replace the electronic lock case and turn to the left to reassemble.
Aug 10, 2010 | Sentry Fireproof Safe
Change battery of sentry safe
To install sentry fireproof safe battery
reconnect the connector and put back the sentry safe battery holder. Slide the cover back in place.
Dec 01, 2009 | Sentry Fireproof Safe
Locks & Locksmithing Logo
531 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Chris Walker
Chris Walker
Tom Chichester
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
