Computers & Internet Logo
Question about APC Computers & Internet
I HAVE APC SMART UPS 750 TRANSISTERS HRF 3205 BURST/DAMAGED AND UPS SHOWN OVERLOAD SIGN ON NO LOAD
Posted by NADEEM on
5 Related Answers
upspro
  • 25 Answers
SOURCE: APC BR800 Overload light with beeps
Your main control board is defective, you need a new unit.
Posted on Jul 11, 2009
Jesrey Paco-in
  • 91 Answers
SOURCE: Overload light in APC RS 800 UPS
it seems that the inverter circuit of your UPS is dying. the solution here is you have to open up the UPS and check the inverter circuit. to make easier, check the power mosfet if its leaking.
Posted on Aug 14, 2009
Anonymous
SOURCE: APC Back UPS RS-1000 Overload LED with beeping sound after on.
in the end solution is you have to bring it nearest apc service.
if you loaded more than its max. capacity at past, the sensor of power is geting burn the sequare wave generator IC.
so you need help with that, olso complicated.
I live the same position with my rs1000, horrible :((
Posted on Jan 09, 2010
Anonymous
  • 25 Answers
SOURCE: APC smart UPS
Check mosfet.
Posted on Mar 09, 2010
Anonymous
  • 591 Answers
SOURCE: hi my APC 1500VA smart UPS show overload
Contact APC Customer Service. They will help you resolve this. If unit is still under warranty they will replace it. There is nothing you can do to repair anything yourself. Sorry ... try calling 1-800-555-2725800-555-2725 for support from APC
Posted on May 06, 2010
Overload problem
Hi Javier,
Is there a printer plugged into the UPS? If so, unplug it and plug it directly into a building outlet.
If not, you have to load manage what you can load the UPS with... remember it's only rated for 1000VA. Go here (http://www.apc.com/tools/ups_selector/) to get a better idea of what you need.
Reply or call if you need more help with this -- 800.260.2259
I have a UPS SMART UP 1000 all light including Overload is on , how to reset or what could be damage it like freezed
The UPS has a problem, chances Short, or IC Proces, Eeproom damaged, Relay.
you try to check the relay
SUA3000RMI2U won't carry load
Did you run this test without AC input?
Also what happens when you cut off the AC mains without any load connected to it? Will the UPS continue to run or does it switch off as well?
APC Smart Ups 1000 VA overload Alarm
you have too much plugged into the UPS. Either buy a bigger UPS or reduce the load
1helpful
Hi my APC 1500VA smart UPS show overload without any load in battery mode, but when switched on AC power all lights are blinking. plz describe me how to resolve this Issue?
My SMART UPS 750 is not sending emails. Why
Make sure you have the communication cable secure on both ends and you have the software installed and properly configured. You can get the software as well as help setting it up at the APC website:
http://www.apc.com/resource/include/techspec_index.cfm?base_sku=sua750
Dropped APC 750XL now when turned on the Load Bar Blinks...
As far as I am aware this means a general system error, but I'm not too sure, best to check before you ditch it, but I'm not sure if they can be reset anyway.
APC UPS 1500 w/full load forces immediate reboot at pwr failure
With a 980watt load the run time is only 7 minutes on a brand new battery. If you have the system on full load your run time will be much less and it has likely damaged the battery. here is the APC web site page for your model. If you are running that much equipment I think you need either a bigger UPS or another 1500 and spread the load out.
Buddy
Corporate Computer
2answers
APC smart UPS
APC is not really the best product, and if it did have a problem like have, at such a small desposable size, your best soluiton is get another one, and a better brand.
www.storminprotection.com check out my page that should help you. You overloaded your system and did damage it prior to the fact that now it shows over load all the time. Get a bigger unit.
Top APC Computers & Internet Experts
Marvin
Marvin
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
