Question about La Crosse Measuring Tools & Sensors
La Crosse bn7 atomic clock and indoor thermometer working but no longer displays outdoor temp.
Posted by Sam Farnham on
Tom Chichester
    Top Expert:
  • La Crosse Master
  • 55,379 Answers
The batteries in the outdoor unit may have failed.
Posted on May 25, 2017
Why isn't outdoor temperature displayed on indoor unit?
I have a La Crosse unit right in front of me and it is showing +18 F tonight. Saturday, we are supposedly going to sub-zero.
With regard to your problem, La Crosse instructions are very specific about the battery replacement procedure. Remove all batteries from both units, then install new batteries in the outdoor unit. Allow time for the outdoor unit to "initialize" and begin sending temperature data. Install new batteries in the indoor unit and you should see the outdoor temperature displayed.
Feb 12, 2016 | La Crosse Technology Wireless Temperature...
OUTSIDE TEMP SENDING UNIT GOT WET AND WILL NOT CONNECT TO CLOCK. HOW CAN I FIX OR HOW CAN I REPLACE?
[PDF]WS-8117 ATOMIC CLOCK WITH OUTDOOR WIRELESS ...
https://www.lacrossetechnology.com/products/.../misc/8117-manual.pdf
NOTE: Do not set the clock until the outdoor temperature is displayed. .... The unit will still try and receive the signal every day despite it being manually set. ..... sunlight, extreme cold and wet/moist conditions as these will lead to rapid changes ... Beforesending the atomic clock in for repairs, contact La Crosse Technology.
La Crosse Technology Top Solutions
https://www.lacrossetechnology.com/support/top_solutions.php
A: Complete a restart for display with the temperature/humidity sensor: ... to rest for 15 minutes can result in failure to connect with the outdoor sensor or missing ... Products set outside of these time zones will not search for a WWVB signal as it is ... locate the Clock or Weather Display near an outside wall and point the unit in ...
Common issues weather stations: Click Here
www.weather-station-products.co.uk/faqs/common-issues-weather-stations
Under £30 £30-£75 £75-£125 From £125 Birdhouses/Feeders Outdoor Clocks ... I'mnot getting any outdoor readings from my outdoor sensor, what do I do? This willcure 90% of all sensor connection problems, important you must ... is the airtemperature, to get this reading you need to place the unit away from direct sun.
Replacement Temperature Sensor ' AcuRite
www.acurite.com > All products
Dec 16, 2015 | Audio Players & Recorders
How to set a Model:WT-8005 atomic cllock
download the manual from here: http://www.manualslib.com/manual/533191/La-Crosse-Technology-Wt-8005u.html
Mar 16, 2015 | La Crosse Technology Black Model Wt-8005...
My outdoor temperature shows three lines I have change the battier as manual said, but it didn't help? Do you sell replacements?
Fixya does not sell anything. The replacement batteries in the outdoor unit could be defective or installed incorrectly. The battery replacement procedure in the instructions must be followed exactly, i.e., batteries replaced in the outdoor unit then allowing time for the outdoor unit to begin sending data before installing batteries in the indoor unit to get an external temperature readout.
Oct 09, 2014 | La Crosse Technology Ws-8418u-it Atomic...
Skyscan atomic clock problem
Look carefully at the back of your clock for a reset button. The temp may have encountered a problem and stopped working. Also, be sure the battery is fresh. Hope this helps.
May 31, 2014 | SkyScan 86709 Atomic Wall Clock
My remote sensor Tx14TH-LCD-B started flashing several days ago and I have gone thru the factory reset new batteries and decided to buy a new sensor then discovered they have been discontinued along with...
I assume you have tried removing the batteries at both ends, reinstalling batteries at the sensor end then the indoor end, waiting without touching anything until the outdoor temp registers and heaving a sigh of relief as things are back to normal. I also assume since the word atomic is in the header that you have an atomic clock function. If nothing works or doesn't work right you probably need to replace the system.
I have a much simpler LaCrosse system which, at this moment, is showing an outside temp of 56 degrees BUT the clock doesn't work and failed early on. I share your frustration.
Nov 04, 2013 | La Crosse Technology La Crosse S98642...
My outdoor sensor no longer transmits the temperature
Have you tried replacing the batteries with good ones and setting it up again?
Mar 07, 2011 | La Crosse Radio Controlled Atomic Clock
Can not set time zone
Press the triangle shaped button to set the correct time
zone. It will toggle the clock mode through the four available time zones in the Continental U.S. Above the seconds digits, the LCD display will indicate "P" for Pacific, "M" for Mountain, "C" for Central and "E" for Eastern.
Mar 01, 2011 | La Crosse Technology WT8005UB Atomic...
My oregon scientific indoor outdoor weather station with atomic clock just stopped picking up the outdoor readings, it won't switch to that channel any longer. tried removing and reinstalling the battery,...
I had the same problem, Since the outside temp wouldn't read, I figured it was the outside unit batteries. Went through half a dozen AAA batteries and wouldn't read. It was the indoor unit. Had the same bats I installed 3 years ago. DUH! Replaced the AAA, and all was well. When the inside batteries die out, it has just enough juice to read indoor temp, but not enought to sense exterior signal.
Oct 20, 2010 | Oregon Scientific Wireless IndoorOutdoor...
Measuring Tools & Sensors Logo
143 people viewed this question
Top La Crosse Measuring Tools & Sensors Experts
Marvin
Marvin
Ngoro
Are you a La Crosse Measuring Tool and Sensor Expert? Answer questions, earn points and help others
