Question about Wells Kitchen Appliances - Others
How to fix a wells waffle maker - Wells Kitchen Appliances - Others
Posted by gilberto on
5 Related Answers
Anonymous
  • 5 Answers
SOURCE: Waring Pro Waffle maker
Just spray the grids before each use with something like Pam, or put a thin coat of oil on them. I found it's better to spray before each waffle so it won't stick.
Posted on Mar 09, 2009
Anonymous
  • 33 Answers
SOURCE: I need instructions for a waffle maker mine are lost
When making a waffle have your batter made plug in your maker and get it started heating if there is a light it will go off whenit is hot enough if not wait aprox 2-3 minutes at the most 5 then spay or brush the inside of the plates with a nonstick cooking spray or brush with butter then pour your batter in the center of the bottom plate and close the lid it should start steaming right away watch the steam it is a never fail indicater of how done your waffle is the less steam the more done your waffle is, there is a lot of trial and error with waffle makers, you should spay or brush between each waffle or they will stick. Let me know how it all cooks out. goofballlovers
Posted on May 21, 2009
Anonymous
  • 7 Answers
SOURCE: Waffle maker won't heat
There is a thermal fuse inside the bottom half of the unit, enclosed in a white insulating sleeve. A replacement can be found on Amazon.com at the following URL:
http://www.amazon.com/Thermodisc-Degrees-Celsius-Thermal-Fuse/dp/B000T9VEV6/ref=wl_it_dp_o?ie=UTF8&coliid=I2M3QCVRS1C1IV&colid=2LRN9SBBQ2MW7
Posted on Sep 03, 2009
Testimonial: "This information was extremely helpful! All the Waring people would tell me was that it was not fixable. Thank you very much!"
Anonymous
SOURCE: Turns on but doesn't Cook
It sounds like this is a common poblem but I found what it is. I am a mechanical engineer and fix anything and everything. I had the same thing with my Villeware model 2010. I took it apart and traced with a meter to find the problem. I found the wires to the heating elements in the bottom half melted and shorted where they cross (bad design) just past an inline fuse ( good part of the design!). I can't find any place that carries parts and contacted Villaware direct but do not expect any luck in getting a new wire harness. The fix is either the proper harness or the correct fuse and high temp wire and correct crip connectors. Bypassing the fuse or using incorrect wire would be dangerous, would destroy the control board if another short would occur or possibly lethal from shock or fire.
Posted on Jan 31, 2010
David Ogawa
  • 27 Answers
SOURCE: how to fix waring pro waffle maker- it does not
check out my other FixYa answers for the Waring Pro WMK300.
Posted on May 25, 2010
What is the best electric waffle iron to make waffles at home?
In my opinion, the best waffle irons are the vintage ones made here in the USA. They are more durable and more reliable than anything made in China today. Look up the older Sunbeam, Toastmaster, Kenmore and G.E. models and you can usually find either round, square or rectangular versions, as well as models with and without non-stick coatings. The years from late 50's to the late 70's are best.
Jul 31, 2015 | Cuisinart Kitchen Appliances - Others
Why is my Mickey Mouse Waffle Maker 5555-02 cooking hotter than normal?
The top of your waffle maker has an indicator on the top that shows when the heating coils are on. It should go out when the iron reaches the correct temperature. If it does not go out it may mean that the contacts are stuck and that it is dangerous.
Jul 27, 2014 | VillaWare 5555-01 Mickey Mouse Waffle...
I need to buy elements and switches
Hi there.
You will be able to find the nearest authorized parts dealer for your wells waffle maker when you visit http://www.wellsbloomfield.com
Regards.
Aug 10, 2011 | Wells WB-1 Waffle Maker
Why does the waffle stick to the maker and how do you clean it???
Waffle pans are seasoned through usage. If you clean the pans too well, they won't work right. It's a bit like cooking with a cast iron skillet. If you wash it with soap and water, you strip the oils off of it, and it will rust.
Use some Pam or similar product when you get ready to make your waffles. Spray the lower pan, add your batter, and then spray the upper pan. Close the waffle maker up quickly after spraying the upper pan.
To clean off old material, it's easiest to scrape it off with a nylon scraper, taking care not to score the metal. A bit of the cooking spray will help on the most stubborn baked on material.
I personally prefer to use the batter that requires the addition of cooking oil, and I still spray the pans as well. This leaves me with a seasoned waffle making machine.
When you've finished with the waffle machine, wipe down the outer surfaces with warm soapy water, followed by clean water. Clean the pans the least you can. Usually, if the waffles are leaving little to no residue, we just wipe the pans clean with a paper towel, and then put it away.
By the way, the first waffle in any given batch seems to never be as good as the ones that follow. We call this one the "sacrificial waffle" and move on. Our dogs appreciate it!
Best regards. Hope that you found this somewhat helpful. --W/D--
Jan 30, 2011 | Waring WMK300 Professional Belgian Waffle...
Why are my waffles sticking to my Philips KB5590 waffle maker?
WE HAD AN IDENTICAL PROBLEM. WE WASHED BOTH IRON SURFACES WELL AND THEN APPLIED A LIGHT COATING OF NON-STICK SPRAY. PROBLEM GONE - REPEAT AS NECESSARY AND HAPPY WAFFLING !!!
Jan 17, 2010 | Philips HD4482 Waffle Maker
Aug 24, 2009 | Waring WMK300 Professional Belgian Waffle...
Does the salton waffle maker have teflon in it?
It very well may, did the box or manual say? If not and even if it did you will still need to either spay or brush with butter to keep waffles from sticking, that many surfaces with all those corners and ditches something will stick everytime unless you lightly coat with non stick something. let me know if this helps goofballlovers
May 10, 2009 | Salton WM8BEL Belgian Waffle Maker
Waffle stickes
The question is! Was this waffle maker brought into the home new or used?
Jul 12, 2008 | Waring WMK300 Professional Belgian Waffle...
Kitchen Appliances - Others Logo
71 people viewed this question
Top Wells Kitchen Appliances - Others Experts
Dennis Boxerman
ray gallant
Stan Ford
Are you a Wells Kitchen Appliances - Other Expert? Answer questions, earn points and help others
