SOURCE: Bobbin Winder won't release
i have a husqvarna rose, i has the same problem when i started using my machine. i was suggested to not wind the bobbin so fast. the reason it gets stuck is because the thread is so tight on the bobbin it actually makes the bobbin a tiny bit smaller, making it hard to get off again. if you dont wind it so fast, it doesn't get so tight.
kylee
SOURCE: bobbin winder wont engage properly
Just click below for the guide how to put the needle ;
Sewing Machine 101- Sewing For Dudes (and Ladies) No. 2: Stitches ...
Anatomy of a Sewing Machine. 1) Bobbin winder 2) Spool pin 3) Thread guide 4) Tension Knob 5) Foot and needle 6) Bobbin housing regards,
Hope it may helps you;
Regards,
VOTIT
SOURCE: Bobbin stuck on winder
Sometimes when a bobbin is wound very fast the plastic gets hot and misshapen, and you can't remove it. Nothing for it but to break the bobbin - it's useless now anyway even if you could get it off in one piece. Pull off as much thread as you can and use pliers or something similar to break enough of the bobbin so it will come off. You need to take care not to let little broken pieces fall into the machine mechanism and take care not to yank too hard on the bobbin winder spindle. If all this scares you too much, take the machine to your dealer for help. And remember to slow the machine down a click or two when you wind bobbins! (It may be of some comfort to you to know that every user of plastic bobbins has done this at some time!)
SOURCE: bobbin stuck on winder
Sounds like you need to remove some thread off the bobbin to get the pressure off. Sometimes if you wind too fast or you have a poor quality thread, the thread will stretch as it winds and causes to bobbin to compress onto the winder shaft.
Good Luck!
SOURCE: The bobbin on my Husqvarna sewing machine (Viking
If your bobbin still has thread on it, remove it by hand and then try to pull the bobbin off the winder.
