Ovens Logo
Question about Belling Ovens
How to replace the thermocouple on belling G756 oven
Posted by Peter Tabrar on
3helpful
2answers
My oven gets warm but will not reach set temperature. Is this the element
Hello Peter;
My name is Peter. I am a retired field service appliance technician.
I recently repaired a oven that would be off as much as 200 degrees. The normal operation of your oven is to rise 20-40 degrees above set temperature and shut down until it drops 20-40 degrees below set temperature, turns back on and repeats the cycle again.
Generally, there are only three components that control your oven temperature:
1.) The Heating Element - If you are getting heat your heating element may be good. To be on the safe side inspect the two connections on the back wall to ensure they are not corroded.
2.) The Thermocouple - There are several different thermocouples depending on your model and if your have gas or electric. These are easily replaced.
3.) Oven Control - Here again there are several different controls, both mechanical or digital.
I just purchased a oven thermocouple and a reconditioned digital control over the internet for under $75.00.
IF YOU HAVE A DITIGAL CONTROL - GROUND YOURSELF BY TOUCHING BARE METAL. STATIC ELECTRICITY WILL KNOCK OUT A BOARD.
So, go into the following website put in your model number and select parts. Several diagrams with part numbers will appear. Your model number is on a metal plate on the face of your oven after you open the door.
Fine your thermocouple and oven control. Copy these part numbers and search the internet for best price.
First, replace the thermocouple. If this solves your problem then return the control for credit if not install the oven control. The highest probably is you have a bad thermocouple
Water Filters Lawn Garden Appliance Parts
May 07, 2015 • Ovens
Thermadore WO-16A electric oven but the thermocouple has gone out.does anyone know of a replacement part?or at least part #?
I believe you mean a thermostat. Contact a distributor such as Automatic Appliance Parts at 800.323.0270
My gas oven won't stay lit when knob is released
The thermocouple is faulty. This needs to be replaced by a registered gas safe engineer
My oven temperature fluctuates widely (50 degrees) in both directions and won't hold a consistent temperature. I see from the manual that I can adjust the temperature up or down, but this won't address...
Try replacing just the thermocouple. You don't say how old the oven is, but the thermocouple is the device inside the oven that takes a beating (especially if it is a self clean model) and needs to be replaced every few years. A failing thermocouple allows wide temperature fluctuations.
2helpful
How to fix F7 in turbochef
F7: Thermocouple Open
CC Thermocouple
Reads 999?F/C or
IR Thermocouple
Reads 1999?F/C
1. Check the connection of open thermocouple on the I/O control board.
If the connection is OK, verify thermocouple is not an open circuit
by using your ohm meter. The cook cavity thermocouple should
measure approximately 4-5 ohms and the IR thermocouple should
measure approximately 30-40 ohms. Measure at the I/O control board
40-pin connector.
o Thermocouple indicates open circuit: Replace defective thermocouple.
o Thermocouple OK: Replace the I/O control board.
4helpful
2answers
Is replacing a thermocouple in an oven difficult? my oven has started cutting out after just a minute or two of being on. On closer inspection, i've noticed the wire seems to be corroded at the base of...
My Kenmore electric wall oven will not increase the heat to the desired setting. The electronic display holds at 100 degrees. Could the problem be the thermocouple or the electronic range control. The range control is hard to find, which is part # 318010701, made by Fridgidaire.
Jan 17, 2010 • Ovens
Pilot light won't stay lit
Possible a bad thermocouple, could also be bad gas pressure to the unit, my bet would be a thermocouple.
You should be able to replace this on your own, if you see where the pilot flame is, you will see the thermocouple that sticks into the flame, it may have fallen off or may need replacing, it should lead back to the gas valve and should be replaceable.
Grainger normally stock a lot of thermocouples and could even cross reference one for you.
Replacing thermocouple on smeg oven
Look at the bottom of the oven and see if you can remove the panel, if its all one piece then take out broiler pan and look inside to see if you acan get to the pilot burner. Good Luck
Jan 11, 2009 • Smeg Ovens
2helpful
2answers
Blodgett 961-P pizza oven
Go here find what you seek.
BLODGETT
44 Lakeside Avenue, Burlington, VT USA 05401
Toll Free: (800) 331-5842 Phone: (802) 860-3700 Fax: (802) 864-0183
Great Co.
Top Belling Ovens Experts
Marvin
Marvin
ADMIN Andrew
ADMIN Andrew
Are you a Belling Oven Expert? Answer questions, earn points and help others
