Question about Pool & Spa
Need a coleman lay z spa manual - Pool & Spa
Posted by Audrey G Case on
5 Related Answers
Anonymous
SOURCE: need owners manual for coleman spa 208 or 408
Go here and print it out. Nancy
team.maaxspas.com/manuals/horizon%20series%202000.pdf
Posted on Mar 20, 2009
Anonymous
SOURCE: Need owners manual for coleman 455 BEACH GR spa.
Here's what worked for me
Press and hold the following three buttons in sequence: PROGRAM - MODE - SET DOWN. Once all three are being held down, the lock symbol will disappear; and the control functions are unlocked. =0 )
Posted on Aug 21, 2009
Anonymous
SOURCE: I need an owners manual for a Coleman Spa Horizon series 447
Chuck, did you find the manual? If not I have one with my spa maybe I could copy it for you.
Ron
Posted on Feb 24, 2010
Anonymous
  • 8 Answers
SOURCE: Coleman 500 series SPA 50A circuit breaker trips
bad connection follow wires from breaker to to moter theres abreak causing arc find it
Posted on May 09, 2010
MrMojoRisin1
Omar Guerrero
  • 412 Answers
SOURCE: Need owners manual for Coleman
Hi
You can get it here my friend... Manual
Posted on Aug 27, 2011
Hi everyone my coleman lazy spa leaks from pump is there a way to fix this?TIA
looks like this has a magnetic drive pump and are not common to leak. so disassemble and locate loose or cracked part and try silicone or epoxy to do the repair. I recommend Majic lube for rubber o-rings and gaskets Lay Spa Teardown
Jun 18, 2017 | Pool & Spa
My coleman lay-z spa pump is making an intermittent loud sound. All filters are new and spa is clean. What to do?
Could be your motor, bearings going bad or whatnot, pump flow being restricted, bad impeller, or the heater. If it sounds like metal its motor, water noise is the pump flow, and heater is other? I've heard banging and cracks from heater water heating too much and not enough flow. No mater what it is call and see if you warranty is good still.
Dec 11, 2015 | Pool & Spa
Ron
Sep 04, 2009 | Coleman Sport & Outdoor - Others
Need owners manual for coleman spa 208 or 408
Dec 19, 2008 | Coleman 10' X 10' Sundome Tent 9160K101
Pool & Spa Logo
118 people viewed this question
Top Pool & Spa Experts
john h
David Spradling
David Spradling
rogerpaul3
Level 1 Expert
Are you a Pool and Spa Expert? Answer questions, earn points and help others
