My washer was washing, but then it kept beeping thae sceen says db out of balance tryed to open the door to move the clothes around but door will not open,it's stuck on this cycle
Posted by Elizabeth Gonzalez on
erichudson37
    New Friend:
  • 50 Answers
Not sure if you have already figured this out or not, but it may be necessary to shut off the machine or unplug it to get the access you need. I have a Kenmore front load and there are some cycles other then spin, that will not allow you to stop and open the door - water in the drum and washing is one of them.
I have not had to try to open my unit but the above is what I would be trying if you have to get the door open. If the washer is still going, then maybe try to ignore the alarm beep and let it go until it gets to a stage where you can interrupt the cycle
Posted on May 22, 2017
Spin with loud noise and shaking
The clothes inside the washing machine are not balanced. Too much weight on one side. Try to move some clothes to the other side to balance the weight. It may take more than one time of moving clothes to get it balanced correctly.
Aug 01, 2015 | Samsung WA400PJHDWR Top Load Washers
My washer stopped during the spin because it got out of balance. Now I am unable to open the door and my clothes are stuck in the machine.
Non of the answers are helpfull. Unplug power.Remove bottom panel and there you find a door lock release. Pull n the door will unlock. Drain water from from pum(it has drain tube). Remove clothes. Move n push the tub a little on each side. Now plug drain pipe. Close door n put it to spin. Should work
May 27, 2015 | Whirlpool Duet GHW9150P Front Load Washer
Samsung HE Top Load washer always going off balance. Only 4 months old and Ive had trouble since day 1.
Open this link and chat with Samsung technician .
('http://support-us.samsung.com/cyber/popup/pop_troubleshooting.jsp?ia_cd=N0000651&model_name=WA45H7000AW/A2&model_cd=WA45H7000AW/A2','',800,600)
Jan 04, 2015 | Samsung WA422PRHDWR Top Load Washer...
Knocking from the drum
You really should realize that when clothes get wet, they get heavy. If those heavy clothes are sticking to one place on the drum it will be out of balance and knock at the sides of the washer. If this happens, simply open the door (not when the washer is full of water, of course) and the drum will stop spinning. Just spread the wet stuff around the drum surface and close the door...voila!
Jan 12, 2013 | Electrolux Washing Machines
Washer shakes violently!
Do you not know that unbalanced dry clotrhes become super unbalanced wet clothes! If you put too little clothing in the front loader, the weight will be in one place on the high speed turning drum. If you put in too much, the load will shift to a few locations but still be out of balance. Rather than "dance" the Chubby Checker way with your machine, try stopping it when it does "the dance" and redistribute the clothing around the drum!
Dec 26, 2012 | Dryers
Maytag washing machine gets out of balance
Could be broken suspesion leg or spring securing the drum
Sep 27, 2009 | Washing Machines
Drum wabbles more than normal. Balance
move the cloths around to balance the load better or put less in the machine
Aug 24, 2009 | Amana LW8203
Washer shakes violently when spinning at high speed.
is the washer level and on solid surface both will cause machine to dance
Feb 06, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Performa spinning banging problem
I assume it is not balanced. Try putting sponges under the feet of the washer.
Jan 06, 2009 | Washing Machines
Door on washer will not open
Select Drain/Spin to remove any water remaining in the washer. The washer door wil unlock at the end of the spin.The washer door will not unlock if the unit has not drained.
Nov 09, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
