e
elizabeth lauer Posted on May 22, 2017
Setting the alarm on my KLH200
Your advisory does not help. My KLH does not have batteries. It does not have an HOUR and MINUTE setting; it has up and down little depressions, for which one can use a ballpoint pen. it has a button, above which it says alarm, and below that, set and on/off, which controls the radio. I have tried a couple of combinations, but nothing works.
How do I set the alarm on an Ikea slabang clock?
1. Insert two AA batteries into the battery compartment of the clock. 2. Press the "SET" button on the top of the clock. 3. Press the "AL" button to set the alarm. 4. Use the "H" (hour) and "M" (minute) buttons to adjust the hour and minutes of the alarm. 5. Press the "SET" button again to confirm the alarm time. 6. Press the "AL" button again to turn on the alarm.
2helpful
How do i set and use this clock?
press and hold time and press hour,stop when desired hour,push and hold time and minute to set minute,the same for alarm,,,push and hold alarm and then push hour and then alarm and minute
How to set alarm
Install batteries. Press and HOLD down alarm button. While holding down alarm button, press hour button until hour is set, then press minute button until your time is set. release alarm button and set time will be saved. Activate alarm function, by selecting band and station, pressing alarm button, and alarm indicator appears and alarm is on. The station will play when alarm time is reached.
1helpful
I just got a Memorex Digital CD Alarm Clock with no manul the modle number is MC 7101. I'm not able to set the clock or alarm. I just need the instructions.
To set the clock:
1. With the power off, press the TIME button; the time will blink.
2. Press the MINUTE button to set the present minute and the HOUR button to set the present hour.
Make sure to set the correct AM/PM setting.
3 Press the TIME button (or wait approx. 15 seconds) and the time will be set.
To set or reset alarm time:
1. With the power off, press the desired ALARM, Press and hold the desired ALARM 1 or ALARM 2 button; the alarm time will blink. The Alarm 1 or Alarm 2 time and settings will appear.
Press the MINUTE button to set the alarm.
2. Press and hold the desired ALARM 1 or ALARM 2button; the alarm time will blink.
Press the MINUTE button to set the alarm minute and the HOUR button to set the alarm hour. Make sure
to set AM/PM setting. Press the ALARM 1 or ALARM 2button again (or wait approx. 15 seconds).
3. Repeatedly press the ALARM 1 or ALARM 2 button to select alarm off, alarm on, for buzzer, radio or CD.
If you needed the manual it could be downloaded:
http://www.retrevo.com/support/Memorex-MC7101-Clock-Radios-manual/id/1081dj880/t/2/
Thanks.
gylacz
1helpful
I need the user manual for an alarm clock called clok. I can't set the time or radio stations
These steps will only work while your unit is OFF. The power button is located at the top left face of the unit.
How to set time?
1. With the unit OFF, press and hold down the Clock/Display/Play/Pause button for at least 5 seconds.
2. While still holding the Clock/Display/Play/Pause button, press the Hour, and then the Minute button to adjust the hour and the minute on the time.
3. After selecting the correct hour and minute time, release the Clock/Display/Play/Pause button to set the clock.
How to set the alarm?
1. With the unit OFF, press and hold down the AL1 or AL2 button for at least 5 seconds. (an alarm icon will flash on the lcd display)
2. While still holding down the AL1 or AL2 button, press the Hour and the Minute button o adjust the hour and minute on the alarm time.
3. After selecting the correct time for alarm, release the AL1 or AL2 button to set the Alarm time.
4. Press the AL1 or AL2 button consecutively to switch alarm one and alarm two between sounding to a buzzer, the currently set radio or a docked iPod.
I dropped my battery operated alarm clock: the second hand still works but the alarm doesn't come on at the set time and the hour & minute hands don't "hold" their position - I took the clear...
The hour and minute hands can be pushed onto their respective shafts at any point in most clocks.
If you already know the time that the alarm is set, let the clock run until it sounds.
When the alarm sounds, install the hour hand and the minute hand to the exact alarm set time. If, say, the alarm is set for 6:30, push the hour hand onto it's shaft at exactly half way between 6 and 7 and then push the minute hand onto it's shaft pointing at exactly 6.
I think this should get you operating.
Gary
Jan 16, 2011 • Vacuums
1helpful
I need the instructions for alarm clock model number cc208s
Please try this....
Setting the Clock
1. Press and hold the Clk Set Button.
2. While holding the Clk Set Button, press the Skip/Search/Hour/Minute Buttons to adjust the hour and minute.
3. Release the Clk Set Button to set the time.
Setting the Alarm
1. Press and hold the Alm Set Button.
2. While holding the Alm Set Button , press the Skip/Search/Hour/Minute Buttons to adjust the hour and minute for the alarm time.
3. Release the Alm Set Button to set the time.
4. Adjust the Auto/Off/On Button to Auto.
5. Adjust the AM/FM/CD Switch to the desired function for the alarm, or reduce the Volume Dial to "Buzz" to wake to the unit’s buzzer.
Cheers!
11helpful
4answers
I have a Zenith ZG120M alarm clock radio. I can't set it.
Here is how I set my ZENITH ZG120M radio alarm clock.
1) PRESS AND HOLD DOWN the HOUR BUTTON and then PRESS the TIME BUTTON to set the correct hour.
2) PRESS AND HOLD DOWN the MINUTE BUTTON and then PRESS the TIME BUTTON to set the correct minute.
To Set The Wake Up Time
1) PRESS and HOLD DOWN the SNOOZE/ALARM SET BUTTON and then PRESS the HOUR BUTTON to set the desired hour.
2) Press and HOLD DOWN the SNOOZE/ALARM SET BUTTON and then PRESS the MINUTE BUTTON to set the desired minute.
There are two light indicators that light up on the left side of the LED display...the top light indicator will come
on once the time turns to PM. The bottom light indicates the alarm is set.
13helpful
3answers
How to Set Alarm
This is the movement used in the following Seiko watches..
SNAC74 SNAC75 SNA548 SNA694 SNAC40
SNAC41 SNAC42 SNA749 SNAC03 SNA411
SNA414 SNA765 SNAA03 SNAA05 SNAA01
SNAA02 SNAA61 SNAB61 SNAB62 SNAB64
SNAB65 SNAC25 SNAC29 SNAC35 SNAC36
SNAA61 SNAC38 SNA283 SNA695 SNAA30
HOW TO SET ALARM TIME
1. Pull the crown out to the second click position.
2. Press button “B” to set the alarm hour and minute hands to
current time.
3. Push the crown back to normal position.
4. Pull the crown to the first click position.
5. Press button “B” to set the alarm hour and minute hands to
desired alarm time.
6. Push the crown back to normal position.
Note:
Alarm setting on a 12-hour basis only. Alarm will ring at the
designated time for 20 seconds; one time alarm only. The alarm
needs to be reset in order to re-engage the alarm function.
HOW TO USE CHRONOGRAPH
1. Set crown at normal position.
2. Press button “A” to Start/Stop/Restart.
3. Press button “B” to Split/Split release/Reset.
HOW TO USE ALARM DIAL
AS DUAL TIME DISPLAY
2. Pres the button “B” to set the hour and minute hands to time of
a different time zone.
Top KLH Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
NOEL
NOEL
Are you a KLH Audio Player and Recorder Expert? Answer questions, earn points and help others
