Question about Boating
How to remove carbs from an evinrude 115hp - Boating
Posted by Noel elliott on
Kardoc
    Top Expert:
  • Boating Master
  • 5,891 Answers
Posted on Mar 14, 2019
4 Related Answers
agent91
Ned White
  • 2100 Answers
SOURCE: how to remove starter from 1983 30hp evinrude OMC
I just read up on the removal of your carb, It says to remove the flywheel to get more room, and then the carb, the left side bolt is harder to get to but it can be done. Only get 1/6 turn of the wrench, remove the fuel line, and be careful not to lose any throttle parts. Hope this helps.
Posted on Apr 15, 2010
Testimonial: "The main problem is NOT knowing how to remove the starter. Thanks in advance, Wayne"
ray gallant
  • 68299 Answers
SOURCE: Ihave a 1982 mercury inline-6-115hp am having carb-boat motor
floats are sticking in the carbs . rebuilding is the only cure
Posted on Apr 26, 2010
imurs70
Terry
  • 34 Answers
SOURCE: could you tell or show how link and sync carbirators on 115hp evinrude 1978
Have u tried adjusting the idle? It should have an idle screw on the carb.
Posted on Apr 09, 2012
Bill Boyd
  • 53812 Answers
SOURCE: 115hp evinrude ficht outboard wont start
blocked jets in the carby or problem injectors
Posted on Jul 04, 2016
Jul 04, 2016 | Boating
115hp evinrude ficht 2000 modelover wont start,
another ecu is less than a new motor . owners choice .
Jun 16, 2016 | Boating
What should the compression be on a 1977 115 hp evinrude
Russ, not sure on factory compression, forums say motor should be good if running 100+, more important is to be with in 10% from highest reading to lowest compression reading. Balance is a key part for engine to run good. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.iboats.com/basics/find_engine_compression.html
Two problems with 1977 Evinrude 115HP Two Stroke Need some help The Hull...
One Cylinder down on Compression
May 06, 2016 | Boating
Could you tell or show how link and sync carbirators on 115hp evinrude 1978
Apr 09, 2012 | Cars & Trucks
1964 5 1/2 hp evinrude kills at high speed
You should have a High Speed carb adjust and a Low Speed carb adjust. If it's running fine while idling, adjust the high speed setting. If you have two nobs, its the lower one. May be set wrong. If you don't have two nobs, remove the carburator and check the jets to make sure they are completely clean or better yet, order yourself a carb rebuild kit to take care of all of this. I just rebuilt my 1971 evinrude 4hp and the carb kit made the world of difference.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/matthew_d24b835e574ef6ca
Apr 17, 2010 | Light Outboard Motor Boat Bass Fishing...
How to remove starter from 1983 30hp evinrude OMC
Apr 15, 2010 | Boating
Feb 07, 2010 | Boating
Boating Logo
156 people viewed this question
Top Boating Experts
ray gallant
 vpsoccer
vpsoccer
Andrew Taylor
Andrew Taylor
Are you a Boating Expert? Answer questions, earn points and help others
