Question about Hoover F5411 SteamVac Jr. Canister Vacuum
Hoover steam vac jr. F5411
The cleaner will not dispense the spray (cleaning soulution) Motor works good, lots of suction. And yes we have the soulution in the right side. Please any suggestions would help. Thanks.
Posted by 5411micky on
  • bblaredo Oct 22, 2008
    Same Problem. was told I needed a pump but don't know where to get one and the shop that sold it and diagnosed it refused to fix it. Any suggestions?
Anonymous
First take the guard off the nozzle and remove the nozzle being careful to not let the spring fly. Now pull off the little white tip of the nozzle which less than 1 inch long. Run a needle or fine wire through the main hole running parallel to the hose and make sure you can see it at the head of the nozzel end. It is best to also blow on it to make sure any dirt particles are gone. Even a speck of dust in your solution part of the tank can easily clog it. In 90% of these vacs, that solves the problem and I have repaired at least 50 of them in the past 4 years.
If that doesn't solve it then try this:
Take the impeller on the bottom out by flipping the tank part over, and clean it. Make sure it spins well.
These Hovver Jr Steam Vacs are long lasting and very effective in cleaning spills and stains. Our janitorial company has many of them and in 5 years only one of about 60 has finally been shelved for parts only. I have replaced a few nozzles and several tank latches plus filters, hoses, and the brush and capp on the end of the hose. An additional chore that is made easy with this is defrosting a freezer!
Posted on Dec 04, 2008
  • handywomantx Oct 06, 2010
    THANK YOU!! I cleaned the impeller with CLR and when it still did not spin right, I gave it a couple of whacks with the handle of screwdriver - that reseated it and machine works perfectly now!!!!!!!
Lauren Junge
    President:
  • 1,673 Answers
Sounds like the pump or turbine (part #43582004) isn't working. Could also have a problem with the trigger asembly.
Posted on Feb 12, 2008
I have the hoover automatic dual vac 5. this is the 3rd hoover rug cleaner i purchased and always the same problem the spray underneth the rotator bars hardly dispenses and the floor hardly gets wet, this...
The carpet is not intended to get soaked, like what you see with a spray application. If you are seeing a stream of water in the nozzle/tank during the recovery stroke, this is working properly.
Jan 17, 2010 | Hoover Steam Vac Dual V w/ SpinScrub...
How do I clean the nozzle of my Hoover steam vac Jr?
No, this assembly can only be rinsed under running water.
Sep 29, 2009 | Hoover F5411 SteamVac Jr. Canister Vacuum
I have a hoover steam vac carpet cleaner, it won't extract solution once it's sprayed out? it hasn't beeen used in about 4 months ?
You probably have no suction and that is because the aluminum flywheel has broken apart under neath the blower motor. (cheap construction) I know I just figured it out on my unit.
Nov 26, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Hoover steam vac model F5853-900 series 17.9
Make sure that the recovery tank is completely close.
Oct 13, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
We purchased a Hoover Steam/Vac (F5915-900) cleaner. We assumed it be a combination STEAM and Vacuum machine. Where is the Steam? I will await your reply. Thank You.
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=761645
Generic problem for all Vacuums
Posted by hjopmi on Jul 09, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. I have a similar Hoover “SteamVac” and the vacuum does not create steam as you stated, but you do have to use the hottest water with cleaning solution and the Hoover will clean your carpet by spraying down the solution, the scrubbing brushes will loosen the dirt and the vacuum will pickup the excess water until the holding tank is full and then you have to empty it, and then start again. The word “Steam Vac” is something that the Hoover factory labeled but so far I have not seen anything that actual produces “Steam” while cleaning. Feel free to contact the Hoover factory with your complaint @ the information listed below. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 09, 2008 | Vacuums
Manual for model f5853-900
I need a mnual for the Hoover Steam Vac Model F5853
Jun 25, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover Steam Vac Clean Surge
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=618767&thid=407245
Posted by just a brat on Feb 22, 2008
I can not seem to get the attachment for the upholstery cleaner to operate what am i doing wrong????
The attachment works on the suction from the Hoover Steam Vac and it’s either a straight suction tool or a revolving brush, check the front of the machine to see if the is a switch to turn on and odd, also before you attach the upholstery tool check the end of the hose for suction, it may be that your upholstery tool may be clogged or the brushes are not spinning and a part may be broken. Feel free to check with you local vac dealer or a new or a good used part if you find out what is wrong. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
8 a.m. - 7 p.m. EST
Don – The Vac Man
Go Ahead. Use Us.
Feb 22, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
F5411 steam vac jr. spot cleaner
There is one manual for the Hoover F5411 SteamVac Jr. available on FixYa.com but, when I opened it, I was not able to actually download a "copy" of the manual.
Instead, it looked like I would have to download / save all the pages of the manual as individual web pages (and then, if I wanted, convert them).
I went to http://safemanuals.com/ (also a very good site) and, although they didn't have the manual there, I was directed to the main www.Hoover.com website.
There, under "manuals," I found the manual, available for download as a pdf file.
http://www.hoover.com/pdfs/manuals/F5411.pdf
Happy steamcleaning!
Peter
Nov 18, 2007 | Hoover F5411 SteamVac Jr. Canister Vacuum
Hoover F5411 SteamVac Jr. Canister Vacuum Logo
755 people viewed this question
Top Hoover Vacuums Experts
Marvin
Marvin
Mike
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
