Question about GE Profile JGSP44 Dual Fuel (Electric and Gas) Kitchen Range
I have a GE Profile Gas/Electric Oven Range that has stop working
Our oven self cleans, once that was over, we could not get the oven programed back to normal operating standards. The LCD has a P7 on the screen and my brother -in law was able to reset the time. Please help, otherwise I won't have a turkey.
I don't know if this will help but I found this serial number on the inside of the oven door. 317B6641p001
Posted by Auntie Leona on
  • 3 more comments
  • Anonymous Jun 22, 2008
    Model# 317B6641P001 oven stopped working.
  • alijobentj Jun 30, 2008
    I have a HotPoint #317B6641P001 with a similar problem.
    The display went blank and I tried to reset the clock but the panel wouldn't work.
    I turned on one of the burners and the lights started flashing and I was able to enter the time.
    Although the light indicated that the burner was heating, it never got hot.
    The oven is non functional too.
    I reset the stove breaker in my electrical panel but it didn't help.
  • pahenry Oct 17, 2008
    Burners and brolier work fine oven stoped working.
  • tejanito3277 Nov 13, 2008
    I have the same problem. Although my broiler works, but not the oven.
  • adavis204 Nov 30, 2008
    The burners work, the self cleaning works and the oven light works but to actually be able to get the oven to preheat is a no go. The serial number is 317B6641P001 I have looked all over the web and have found no helpful info but I have found several people reporting the same problems with the same oven.
reallinx
    New Friend:
P7 means Shorted Matrix Key. Power down and power up control. If the fault condition reappears within 15 minute - replace control. I got this off a wiring diagram that was in an envelope attached to my range.
Posted on Feb 07, 2011
My GE xl44 gas range broiler won't work,
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jun 02, 2011 | GE Profile JGB900 Gas Kitchen Range
Instructions for operating the self cleaning electric oven of General Electric? ?
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Feb 26, 2011 | GE Profile 30" Self-Cleaning Freestanding...
I need directions on how to operate the self-cleaning mode on my GE profile electric double ovens
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Nov 26, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Lost manual for model # jgsp31ger3wg, GE Profile gas range. want to clean oven...
heatman101
Oct 11, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven door after self clean cycle won't unlock
Both the oven" ON " light and " Clean " light will flash when the clean has finished . When the " clean " light flashes , slide the latch handle to the left as far as it will go , then turn the " OVEN SET " knob to " OFF " to open the door.
Mar 26, 2010 | GE Profile JGS968SHSS Gas Kitchen Range
Ge xl44 self cleaning gas oven willnot come on
heatman101
Feb 20, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra Electric Oven.
call a appliance and parts store give them the tear and model number from stove it is inside the door or on back it5 mkay also be on the top under the fuse panel access door
Dec 27, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
How do I clean a GE gas range (self-cleaning oven?)
What do i clean the burners with ? the round surfers is harder to scrub, what do you advice .
Apr 20, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile JGSP44 Dual Fuel (Electric and Gas) Kitchen Range Logo
948 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Marvin
Marvin
Are you a Kitchen Range Expert? Answer questions, earn points and help others
