Cars & Trucks Logo
Herbert Eplee Posted on May 12, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Will it hurt to replace the 20 amp fuse in my cigarette liter to a 25 amp it keeps blowing fuses
andrep
Level 1:
Problem Solver:
  • Contributor 8 Answers
  • Posted on May 12, 2017
andrep
Contributor
Level 1:
Problem Solver:
Answers
8
Questions
0
Helped
816
Points
17
If it keeps blowing fuses, you have a problem. The fuses are there to protect the wiring. If you put a larger fuse and it doesn't blow, you might overheat something, or worst your car could catch on fire.
Vernon Taylor
Level 3:
  • Cars & Trucks Master 7,446 Answers
 Vernon Taylor
Level 3:
Answers
7446
Questions
0
Helped
1956961
Points
26207
I am wondering if the fuse blows instantly or whether it lasts a while?
Fuse ratings for cars are usually mean or average values so a 20 amp fuse needs roughly 40 amps to cause it to instantly fail. I have not heard of a cigarette lighter needing that much current so I guess there is a fault that should be located and cured before you have a fire.
Maybe it is the element that is faulty...
I think fitting a 25 amp fuse would be slightly foolish...
1helpful
I want to operate a some equipment through my automobile cigarette lighter that currently has a 20 amp fuse. The equipment requires no more that 15 amps. Can I replace the 20 amp with a 15 amp fuse?
the 20 amp it to protect the circuit and wiring leave the 20 amp --you can put in a 15 if you want but if your equipment draws above 15 it will blow fuse
My 89 VW beetle blows fuses for the cig auxiliary port it requires a 15a fuse but I've tried 20 25 and30 all blew
of course they will blow
you have a dead short in the cigarette lighter socket
at 30 amp it is a wonder that the wires didn't burn up
pull the socket and check where the wire is shorting out
What fuse do i take out to keep the horn from blowing on a 2000 dodge stratus
Simply Take Out 10 amp Fuses One at a Time Until Horn Stops, Repeat With 15-20-25 amp If Necessary But Most Likely 10-20 Amp Fuse
Why does the starter/fuel fuse keep blowing out?
It depends on the year make and model what is running on that circuit.
Something is pulling too much current, just like when a fuse in the house blows.
2answers
What is the location of the fuse that controls the cigarette liter? What is the AMP rating of the fuse?
you did not state what kind of chevy but generally this the ctsy fuse short for curtesy normally this is a 20 amp fuse
2helpful
3answers
When I plug anything into the cigarette lighter or the power outlet the 20 amp fuse blows.
what are you plugging there?? is it 12 volts??check the item for bad cable they usually break when you bend them on the connectors...if fuse keeps blowing dont use item anymore and donot bypass the fuse your car or truck will catch fire
3helpful
2answers
Cigarette lighter stopped working
the cigarette lighter fuse is in the passenger compartment on right hand drive cars it is next to accelerator pedal under panel on right hand side the fuse is no 32 20 amps
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
