Re: How do I find the part number for my 2004 Tahoe Delco...
If it's got a CD player,it might be this one ??? Just found one on 'Feebay'..03-05 GM Chevrolet GMC Tahoe Yukon Silverado Radio Cd Player 15104155 JS26209
Check in the owners manual, backside radio or ask you dealer. Keep in mind that this is a unique code for each radio.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
well i guess it all depends on if it fits? u can put most any radio and speakers into a car and it fits and all the wires match up, but u also have to have the right connection, and if ur not sure how to put it in i would suggjest just going to a automobile shop or car dealer near you. Hope it helped
The radio display lights in this Delco radio are tiny incandescent bulbs that are soldered to the front circuit board of the radio, the radio must be removed from the car, the radio chassis covers removed to expose circuit the boards and the bulbs replaced, they are burned out. This requires allot of skill and the right tools, a low temperature soldering pencil a solder suction gun and new bulbs, they are available from Radio Shack the part number is #7219 (12 volt 60ma)
Common for the CD to get stuck on the Delco radio, Try resetting the radio by disconnecting the battery for 5 min and then reinstalling the cables. This will reset the radio and you should get your CD to work again, if there is an issue. You going to have to go to the dealer and they are going to have to use a Tech2 scanner to reset and reprogram the radio. If there is any mechanical issues the Tech2 scanner will identify the issues, but 90% of the time. It's just a simple reset and the other 10% is a reprogram or replacing the unit.
Thank you for using fixya and good luck.
You will need to take it to your local dealer for them to pull code and call Delco for the unlock code,This usually takes about 10-15minutes.Make sure they give you the unlock code so you could use it for that radio if you lose power to it .
we had to replace the air actuator door it was a 100.00 part from the dealer but we tried three from auto parts stores that looked the same but didn't fit. You need the ac delco part and it's hard to get to up in the dash.
I've heard of people using Delco Lock Codes (http://www.delcolockcodes.com) to get their radios unlocked. They seems like a legit site from what I've read. Good luck!!
