Question about Apple iPod nano
IPod nano (3rd generation) not syncing
The first time I synced my ipod nano it synced perfectly. A few days after I decided to organise my music by putting proper names as well as putting some artwork for the albums.I could not get the artwork off of iTunes because I could not set up an account so I got some of the artwork off of a website named Art for iTunes.com.When I tried to sync my iPod I got an error message saying the required folder could not be found. I tried to restore the iPod but the same message appears can someone help me please.
Posted by bigjoe22 on
Anonymous
Hi ive just got i ipod nano do i have 2 down load anything 2 make it work thanks donna
Posted on Oct 03, 2008
Anonymous
  • 64 Answers
This is the advice I tell everyone.. Don't use the iTunes library!
There are times when you do need to use it, but 98% of everything you need to do can be done right on the iPod.
When you plug-in your iPod, you should see an icon for it appear in the left window pane. You can actually edit the song info, sort, categorize, or whatever right there.
The only thing you can't do is get iTunes to automatically download the artwork for you. But, to be honest, even when I do use the library to get my artwork, the artwork never "sticks" when I move it to the iPod, and I end up manually adding it every time.
I've had an iPod in some form for at least three years now. I've never had a problem editing directly on the iPod itself, and I don't miss the library one bit.
Hope this helps.
Posted on Feb 01, 2008
Load music on my ipod
Connect your iPod to your computer with the USB cable that came with your iPod. The iPod screen should say "Do not disconnect".
Your iPod should appear under Devices in the bar to the left.
Decide whether you want to sync your iPod with your iTunes library or manually put songs on your iPod.(nano only)
Syncing your iPod will automatically add all of the songs in your library to your iPod. It will also delete any songs from your iPod that are not in your library. Click on your iPod icon and select Sync in the lower right corner.
If you do not want all the songs in your library on your iPod, make a playlist of all the songs you do want, or decide which playlists you want to include on your iPod.
On the top bar, click on the button which says "Music"
Make sure the box that says "Sync Music" is checked, then check the box for whether you want your iPod to sync with the entire library or selected playlists. If you click selected playlists, select the playlists you want in the playlists category. For newer iPods you can check which artists are included on your iPod to automatically import all the songs from each selected artist onto your iPod
Mar 21, 2011 | Apple iPod nano
The problem is, i want to put music from my laptop onto my apple ipod 4GB a1051, how do i do that please?
The following information has come directly from the apple support web site.
Adding Content Automatically or Manually
There are two ways to add content to iPod nano: ? Automatic syncing: When you connect iPod nano to your computer, iPod nano is automatically updated to match the items in your iTunes library. You can sync all your songs, playlists, videos, and podcasts, or, if your entire iTunes library doesn’t fit on iPod nano, you can sync only selected items. You can sync iPod nano automatically with only one computer at a time. ? Manually managing iPod nano: When you connect iPod nano, you can drag items individually to iPod nano and delete them individually from iPod nano. You can add songs from more than one computer without erasing songs from iPod nano. When you manage music yourself, you must always eject iPod nano from iTunes before you disconnect it.
The following URL will bring you to the iPod Nano manual. For more information on setting up you iPod see chapter 2: Setting up iPod Nano
http://manuals.info.apple.com/en_US/iPod_nano_5th_gen_UserGuide.pdf
I hope that information above has helped is some way.
If possible please rate this solution.
Sep 02, 2010 | Apple iPod nano
I pod nano looses songs and scrambles albums.
This may have something to do with how the ipod is reading the names of the songs.
Hook your ipod up to iTunes and when the summary screen comes up uncheck the "automatically sync music"
This will put it in Manage Music Manually mode.
click the music folder and inspect the song titles.
if a son has something in the name such a a number before the name title change the song name to remove the numeral. see if it comes back in order.
as for losing songs, the ipod will remove songs when you sync if it doesn;t find it in your playlist.
this may be whats going on.
Apr 11, 2009 | Apple iPod nano 3rd Generation
My ipod nano will not sync all of the songs from my library. it will only sync the newest songs i purchased.
hey in the ipod music section in itunes put it as add sync all music and play lists
Mar 10, 2009 | Apple iPod nano
Getting music directly off Ipod nano 2gig
When you plug the iPod into the computer, a window may or may not pop up, depending on what you told Windows to do with the player the first time you connected it. If the window does not pop up automatically, double-click My Computer, double-click the icon of the iPod, and you should see a folder that says Music. If this folder is missing, that may explain your symptoms. Right click a blank area of the Nano window, and select New --> Folder --> and create a folder named "Music". Try syncing again, and see if it works.
-Tha Mp3 Doctor
Feb 22, 2009 | Apple iPod nano
Adding music
You cannot go into "My Computer" and open up the Nano drive and just drag and drop files to it. Itunes formats the files with different names as it puts them on the ipod. There are however, other pieces of software to use to sync the ipod with the music you have. A few of the more popular iTunes alternatives are Floola, WinAmp, gtkpod, Banshee, RhythmBox and Amarok.Good Luck.
This is my first solution. Any thoughts?
Jan 31, 2009 | Apple iPod nano
Apple Ipod isnt recognized on computer
You can only sync one ipod with one computer so if you put music on it already it will only work with the original computer you synced it with. Same with ANY ipod.
Jan 07, 2009 | Apple iPod nano
What seems to have happened is that either iTunes or the iPod folder has become corrupt. To solve this, download the very latest version of iTunes, install it, connect your iPod. If it wants to update the software on your iPod do this. Then on the main ipod page on iTunes click the button that says Restore. Choose the bottom most option if given any then go ahead and restore. You should now be able to sync as normal.
All the best
Sean
Pi
Aug 11, 2008 | Apple iPod nano
Who to repear my ipod
Try all the other 5 R's laid out in the manual - Apple's website has the full manual if you have lost it.
Jul 05, 2008 | Apple iPod nano
Apple iPod nano Logo
123 people viewed this question
Top Apple Audio Players & Recorders Experts
Ekse
ThaMp3Doctor
ThaMp3Doctor
Sean Cole
Sean Cole
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
