Question about Mitsubishi WD-52525 52" Rear Projection HDTV
WD-52525 Image problem
To make a long story short, please refer to images
http://a789.ac-images.myspacecdn.com/images01/17/l_49ad5c0d57cee6e4ff51455db859b8fc.jpg
http://a871.ac-images.myspacecdn.com/images01/80/l_415e0aa91bc020a6e33caa5cb8221eee.jpg
Now that you see the problem, here's a brief version of the story.
I unplugged the power to clean out the air filter as stated in the Owners Manual, when I had plugged it back in, I got that image, Hit the reset button and it shuts down and the green timer light just blinks and blinks forever. I unplugged it and plugged it back in and the problem went away.
6 months later (Nov. 19th, 2007), unplugged my TV to re-arrange my living room and the problem came back.
Followed the steps above at least 3 or 4 times with no avail.
Any Ideas?
If no who wants to buy this TV for $200, lol I know no one will buy a broken TV.
Posted by vahdyx on
  • vahdyx Nov 22, 2007
    no kidding dude, i had to align the picture, I had to get a fan replaced, now this.
  • Anonymous Aug 14, 2008
    Developed the same trouble with my 52525. Can't get the unit to reset and the green light blinks constantly. According to Mitsubishi service center, TV will have to have the chassis removed and sent to Mitsubishi for repair. TV will be out of commission for at least 8 weeks. Mits is NO HELP at all. According to NINE different authorized service reps in my area (/ Dallas/ Ft. Worth) this problem is rampant. If you are willing to go without your TV for 8-10 weeks and then pay between $750 and $1000 for the repair, have at it. Mitsubishi customer service is PATHETIC and the reason my $3500 DLP set that is 3 1/2 years old will be out at the curb with the trash on Friday!
Anonymous
If you are in the Dallas area and want the Capacitors replaced I can do this for you. If you have replaced the capacitors and still have an issue There is one more repair I have found that has a 90% fix rate. Contact me and I can repair it for you inexpensively. [email protected]
Thanks
Mike
Posted on Jan 28, 2009
Anonymous
Same problem here. Just started today.
Posted on Sep 26, 2008
Anonymous
Still have this tv....I will buy some parts off you. My email [email protected]
Posted on Mar 22, 2008
neals
    Problem Solver:
  • 6 Answers
I have the same issue have not done the repair yet but here is a link to photos of the various boards and the problem caps:
http://www.fixya.com/support/t155026-flickering_blue_picture
Posted on Feb 16, 2008
Namnar
It looks like the swolen capacitor issue - I and alot others did the repairs myself but dont just replace the 4 1000 uf on the DM board, The 2 3300 uf on the PSU are probably bad and do a general inspection of all the boards for bad caps.
See here
http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
Posted on Nov 22, 2007
Anonymous
  • 3 Answers
THIS TV'S ARE CRAP, I HAVE NOTHING BUT PROBLEMS WITH MINE
Wd my book re format for mac
from pg 68 of the user guide.
Reformatting the Drive
Go to
http://support.wd.com
and refer to Knowledge Base answer ID 3865 for
information about reformatting the drive.
See "Troubleshooting" on page 66 for more information about reformatting a drive.
Restoring the WD
Software and Disk Image
After you have reformatted your drive for use on Mac computers, go to
and see Knowledge Base answer ID 7 for information about
downloading and restoring the
Mac versions of the WD Driv
e Utilities and WD Security
software and disk image.
The WD SmartWare software is not available
for Mac computers with this drive model.
Jul 05, 2014 | Western Digital My Book Essential Edition...
Have a red double image
Dust on the mirrors was only a minor problem, and one that I could have dealt with. Unfortunately the entire system shut down because of lamp and circuitry issues. The cost to repair would have been 2/3 the cost of a nice new tv, and I would have been left with a giant piece of garbage that was destined for more problems and a lifetime of expensive nearly annual lamp replacements. We got rid of it shortly after my first post. Biggest mistake ever.
Aug 06, 2013 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubiushi wd52525. Status light keps blinking..No fan or image
If it blinks yellow the air filter cover is open or the safety switch on the door is defective. If it blinks red then one of the fans has quit working
Dec 20, 2009 | Mitsubishi WD-52525 52" Rear Projection...
My WD-52525 green timer light keep blinking and the tv will not comes on
If you've never replaced the lamp on that TV, I recommend you do it. Most probably it reached it's average lifepsan they have and that's why you're not getting an image at all. Now if you already replaced the lamp and still have the same issue, it's most probable that the ballast is faulty, this is the board in charge of sending energy to the lamp so it can turn on. www.discount-merchant.com/?Click=48427
Dec 06, 2009 | Mitsubishi WD-52525 52" Rear Projection...
My wd-52525 lamp indicator indicated that I needed a new lamp. I purchased a lamp, installed it and of course it still indicates a bad lamp. I took the lamp assembly and had it checked out by a tech and it...
Actually Tim, it seems more like a ballast issue, I recommend you replace it, since ity doesn't have enough energy to keep up with the lamp, and that's why you gte a lack of image.
Aug 02, 2009 | Mitsubishi WD-52525 52" Rear Projection...
4yr old Mitsubishi DL 52525, HDMI input vide problem
Are you sure its the TV and not the source? Are you sure its only the HDMI port on the TV? The only reason why you must HDMI is to get 1080p and your TV doesn't support 1080p. Its supports up to 1080i. Your TV has a native resolution of 720p which means it can accept a 720p image and not need to scale it, so the picture will look the best at 720p but will support 1080i. I would use component cables to connect your sources and set them to output 720p.
Mar 20, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Yellow and blue ghosting
the DM and of the FMT boards are failing.check out www.tv-techs.com the boards need to be rebuilt
Dec 24, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Wd-52525 no image
have you replaced the lamp? If so and it still lights up as red you need the V26 DLP PWB PCB kit to replace the defective capacitors on the PWB the kit has all the capacitors and instructions on CD
Here is the link.
http://servicemanuals.vstore.ca/
Jul 02, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Color problem with DLP TV
If pic. is distorted when warm :. Suspect the FMT PCB part # 930B924002
Sep 24, 2006 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
663 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
