Question about InFocus POWER SUPPLY CORD Multimedia Projector
The power supply don't operates - INFOCUS X1
The X1 infocus power supply was damaged. It takes probabily a short circuit during the installation of the projector. The fuse and the parts like the fet 2sk3528001 and (termistor?) US-802 is damaged. I ask you if there is another parts damaged, and what parts I have to change in the power supply.
Thanks in advance - Osvaldo
Posted by RADIOMAX on
  • 1 more comment
  • RADIOMAX Nov 21, 2007
    And concerning about the power supply? what parts in it I have to change? I believe the bulb was not affected.
  • RADIOMAX Nov 26, 2007
    where I can buy only one unit of the infocus x1 parts:
    US 802
    2SK3825
    US 802
    2SK3825
Anonymous
Please, before give a solution, read the total post, usually the projector bulb, try to replace it first but I will not recommend you to do so but it is your decision,
that a bad help, he says:
Thanks in advance - Osvaldo:
and:
Posted on Feb 19, 2008
Anonymous
    Novelist:
    Champion:
  • 244 Answers
Usually the projector bulb, try to replace it first but I will not recommend you to do so but it is your decision.
Posted on Nov 21, 2007
  • Anonymous Nov 21, 2007
    Try to check the fuse if still working by using a tester.
    If not so you need to replace it by each specification. Please rate me SOLVED. I have to go now. just post any comments I will be right back after 8 hours I have to go sleep. bye
Infocus X1 Projector started with 3 blinking red lights.
Its due to lamp Ballast power supply is faulty,it need to repair or replace otherwise again it will damage Lamp so be careful
Mar 09, 2010 | InFocus X1 Multimedia Projector
The bulb on X1 blew out, I replaced the bulb, the
it's the fan. if it won't spin full power, it can't cool down the projector and it'll shut down. there are 2: 60mm (part # 526-0153-00) and 80mm (526-0152-00). both can be purchased from infocus or an infocus service center.
Aug 10, 2009 | InFocus X1 Multimedia Projector
Infocus projector power supply dead
the caps dry out. look for bulging caps. you won't find a schematic for the ps boards. infocus had someone else make them. the problem seems more like a overheating issue. as for the other one with the "just the fans", check the colorwheel.
Oct 03, 2008 | InFocus POWER SUPPLY CORD Multimedia...
Ballast
you have to go to an infocus authorized service center. you may be able to purchase it from them without having them put it in. check the infocus website for an asc. but for reference, the part # for the ballast/power supply is 520-0126-00 if there is a "0" in the 5th to last position in the serial #, and 520-0143-00 if it's an "a" in the 5th to last position.
Sep 29, 2008 | InFocus X1 Multimedia Projector
Thank you for your immediate reply. I could solve by myself. The problem was with power supply cable.
With regards
Gomohan
Aug 02, 2008 | Apple InFocus X1 Multimedia Projector
Con: Infocus x1 and infocus x1a projector
Hi there
You could most probably do that yes , it's normally only the Mainboard that is different.
Mar 21, 2008 | InFocus X1 Multimedia Projector
Infocus x2 dose nothing
Assuming the power outlet and cable is OK the most likely problem is the power supply and needs to be replaced.
Dec 06, 2007 | InFocus X1 Multimedia Projector
LP540 INFOCUS
good luck. not even the infocus authorized service centers get those. besides, they were made by another company that does not make power supplies antmore. and infocus doesn't have any new ones in stock. if you're getting no power at all, replace the mosfets. it works half of the time.
Sep 20, 2007 | InFocus SP-LAMP-017 Projector Lamp for...
InFocus X1 power problem
something blew the fuse the first time. if it blew again, the issue remains. something may be arcing. check near the plug, or if there is anything bouncing around in there or a crossed wire.
Nov 26, 2006 | InFocus X1A Multimedia Projector
695 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
martin hogg
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
