Octane Myth
What is octane? Octane cannot be seen, but it is of utmost importance when it comes to gasoline. One thing for sure, higher octane fuel costs more. Allot more!
Simply put, octane is a measure of gasoline's ability to resist detonation, which you hear as pinging and knocking in your engine. The higher the octane the more the fuel can be compressed without detonating before you want it to. Detonation, ping, knock, whatever you want to call it, occurs when the air/fuel mixture ignites before the spark plug fires. The mixture ignites from compression and not from the flame of the spark plug. In other words, the higher the octane the less likely it is to ignite prematurely. The only benefit to a high octane fuel is that it allows an engine to run at a higher temperature and with a higher compression ratio without pinging. Higher octane fuel does not provide more energy, more power, better mileage, more torque, burn cleaner, clean your engine, and is not better for the environment. If the engine is pinging when using the correct octane fuel, then it may be necessary to move to the next higher octane to prevent pinging, and damage to your engine, unless there is another problem. If you are using higher octane fuel for any of these reasons, STOP, you are throwing your money away. Also, never use a lower octane fuel than is recommended by the manufacture. If the manufacture recommends 89 octane then use 89. If they recommend 87 then use 87. The key is what was the engine designed to run at to achieve optimum performance and mileage? One exception is when you are towing a heavy load with a vehicle designed to run on 87 and you experience pinging. In that case it may become necessary to switch to 89 while towing. In conclusion, race car engines are designed to run on high octane fuels due to their high compression engines. You cannot make your engine a race engine just by upping the octane. Save your hard earned money, and use exactly the octane you need.
With further research online I have found this; so thanks may be in order to Pippal;-)
I have read that there is a problem with the Mass Air Flow sensor on almost ALL ford vehicles from 1990-1999.
Ford says to replace it.
Symptoms include..
* Lack of Power.
* Spark Knock/Detonation.
* Buck/Jerk.
* Hesitation/Surge on Acceleration.
* Malfunction Indicator Lamp (MIL) Illuminated. DTCs P0171, P0172, P0174, P0175 may be stored in memory.
There is a TSB on this issue.
Article No.: 98-23-10
Date: 11/23/98
Mass Air Flow (MAF) - Sensor Contamination
The affected vehicles are:
Ford:
1990-97 Thunderbird
1990-99 Mustang, Taurus SHO
1991-99 Crown Victoria, Escort, Taurus
1992-94 Tempo
1993-97 Probe
1995-99 Contour
Lincoln-Mercury:
1990-97 Cougar
1991-99 Continental, Grand Marquis, Sable, Town Car, Tracer
1992-94 Topaz
1993-98 Mark VIII
1995-99 Mystique
Light Truck:
1990 Bronco II
1990-97 Aerostar
1990-99 Ranger
1991-99 Explorer
1994-96 Bronco
1994-97 F Super Duty, F-250 HD
1994-99 Econoline, F-150, F-250 LD, F-350
1995-99 Windstar
1997-99 Expedition, Mountaineer
1998-99 Navigator
1999 F-250 HD, Super Duty F Series
OBDII DTCs
* P0171, P0174 (Fuel system lean, Bank 1 or 2)
* P0172, P0175 (Fuel system rich, Bank 1 or 2)
* P1130, P1131, P1132 (HO2S11 lack of switching, Bank 1)
* P1150, P1151, P1152 (HO2S21 lack of switching, Bank 2)
OBDI DTCs
* 181, 189 (Fuel system lean, Bank 1 or 2)
* 179, 188 (Fuel system rich, Bank 1 or 2)
* 171, 172, 173 (HO2S11 lack of switching, Bank 1)
* 175, 176, 177 (HO2S21 lack of switching, Bank 2)
* 184, 185 (MAF higher/lower than expected)
* 186, 187 (Injector pulse width higher/lower than expected)
__________________
