Question about Firearms
What year was my Smith & Wesson M 10 revolver manufactured? Serial number is C 989233
Posted by Andrew Manhattan on
Pete Blackwater
    Sergeant:
    Habit-Forming:
  • 97 Answers
T C1 to C223998 as 1948 to 1951.
The K frame 38 was S&Ws bread and butter gun, it was in production starting in 1899 as the M&P.
Posted on Apr 14, 2017
Date of manufacture Colt Single Action revolver Serial Number 263844
According to Colt's archives the single action of this serial number was manufactured in 1905
May 28, 2018 | Firearms
What does pd mean on a smith & wesson magnum 357
The PD series is Smith & Wesson's idea of a handgun that is lightweight enough to be always on hand when needed but it is not necessarily intended to be shot often. Carry ability and concealment are optimized while heft and shooting comfort are sacrificed.
"Personal Defense", PD as opposed to a gun that is mainly intended to be a range gun, showpiece or race gun (Performance Center, PC) or sidearm for military or police (M&P).
Apr 07, 2018 | Firearms
What is the manufacture date of my 22A-1 S/N UCN7657
You can contact S&W
[email protected]
or call 1-800-331-0852
if the info you need is about the RECALL
recall to 22-A manufactured from August 1, 2008 to February 19, 2009. serial number range:
UBW0000 - UBW9999
UBY0000 - UBY4104
Action to be Taken
STOP USING YOUR 22-a AND RETURN IT TO SMITH & WESSON AT ONCE
I’m happy to help further over the phone at https://www.6ya.com/expert/mike_316638c836088218
Mar 23, 2018 | Firearms
I need an owners manual for a S&W CS45
Contact Smith and Wesson
1-800-331-0852 Ext. 2904 8:00 a.m. to 8:00 p.m. Eastern Standard Time, Monday - Friday
Feb 28, 2018 | Firearms
Sw22 victory bolt wont come out what do I do
smith and wesson victory bolt problems Google Search
Hope this helps. Not sure of your specific problem. I am happy to chase down any more info if you require
[email protected]
Nov 02, 2017 | Firearms
I have a small frame 7 shot 22 Cal. break top H&R revolver. I was told my grandfather carried it in WWI. Serial# 371177. I would like to know the manufacture date and if it was an Army issue.
James
Decoding H&R serial numbers is not easy and it takes up quite a bit of the H&R book as different models usually have seperate serial number series. gererally speaking there were three types of serial number series.
Pre 1905 (1904 and before) which were more like batch numbers and usually ran from 1 to 99,999. on some models there was a different series every year.
Post 1904 (1905 to 1939) one single series starting at 1 and going into the middle 6 digits (some third model auto-ejecting revolvers have been observed with number in the 800,000 range.
Ift here does not look like there are any markings on the left side of the barrel other than the caliber this would be the premier model fitted with extra cost oversize grips and 6 inch barrel. during the same time (1925-1934)frame H&R offered this revolver as the H&R TARGET (aka model 766) the only difference was H&R Target was marked on the barrel. by the time the premier model was fitted with a longer barrel and oversize grips the cost was about the same for the two models. the offering of the H&R Target model was just another way to try to sell more revolver. factory serial numbers are not available for this model so i believe this revolver was manufactured before the H&R Target was introduced in 1924 (most likely 1920 to 1923)
below is information of both models.
H&R PREMER SECOND MODEL SMALL FRAME TOP BREAK R.F. & C.F. ----------1905-1941
Small fame double action top break revolver with double top post barrel latch; calibers and cylinder capacity, 22 rimfire-7 rounds, 32 S&W, 5 rounds; automatic cylinder stop; standard finish Nickel with case harden hammer and barrel latch; standard barrel length 3 inches, with 2, 4, 5 and 6 inches available as optional; HAS CALIBER MARKINGS ON LEFT SIDE OF BARREL WAS MANUFACTURED FOR SMOKELESS POWDER CARTRIDGE PRESSURES.
There has not been enough data gathered on serial number to try to come up with a serial number range for the different variations.
First Variation, model name & caliber marked on left side of barrel, patent dates 5-14-89, 4-2-95, 4-7-96---------------1905-Only
Second Variation, model name & caliber marked on left side of barrel, patent dates 4-2-95, 4-7-96-------------------1906-1908
Third Variation, caliber only marked on left side of barrel, patent date 10-8-95-------1909-1913
Fourth Variation, caliber only marked on left side of barrel, no patent date, state not spelled out in address (MASS)---------1914-1915
Fifth Variation, caliber only marked on left side of barrel same as 4th except different font used in barrel markings----------1914-1915
Sixth Variation, caliber only marked on left side of barrel. State name in barrel marking spelled out (MASSACHUSETTS)-----1916-1924
Seventh Variation, new grip frame, there is no step down for the grip panels to fit into-----1925-1942
After 1930 listed in catalogs as; PREMIER No. 30 .22 Rimfire 7 shot & PREMIER No. 35.32 S&W 5 shot
VALUE: 100%=$265 60%=$75 Add 10% premium for blue finish; 20% premium 4", 5" or 6" barrel; 20% premium for 22 rimfire caliber; 10% premium for 7th variation
If this is a top break it is a H&R Premier model manufactured in the 1924 to 1930 era or one of its variations. if it is a solid frame model it is a model 1906 or one of its variations manufactured in the 1932 to 1937 era. without a picture or knowning the exact markings i can't give you an exact model.
1940 and after letter codes used to denote year of manufacture. starting with A in 1940 and going to BC in 1986.
Caliber markings on the side of the barrel ALWAYS indicate 1905 or after manufacture. when H&R made the switch to smokeless powder in 1905 they started marking the caliber on the left side of the barrel of all their handguns. no caliber markings = black powder, caliber markings = smokeless powder.
Please keep in mind that H&R did not always obey their own rules and there are exception to every rule. during 1890 though 1904 H&R was manufacturing so many top break revolvers they starting using a letter code after 100,000 had been reached. these letter code were stamped along with the serial number on the bottom of the top strap (the cylinder had to be removed to see this location).
Hammerless Bicycle models (1899-1920). the caliber markings and 6 digit serial number indicate it is a second model and if in good condition it should be safe with modern ammo. the bicycle hammerless (small frame, 2 inch barrel) is serial numbered in the same series as the regular small frame hammerless model.
Pete
Apr 11, 2017 | Firearms
Firearms Logo
Top Firearms Experts
Marvin
Marvin
jws1013
john h
Are you a Firearm Expert? Answer questions, earn points and help others
