Question about Bernina Sewing Machines
The needle doesnt want to lower into fabric. ive oiled the bernina 370 , old sewing machine. its just stuck
Posted by fay peters on
R.A. Ellis
  • Bernina Master
  • 12,731 Answers
Try directing hot air from a handheld hairdryer into the internal mechanism. If it is seized from dried oil, the heat may loosen it. However, if it has seized from old oil, it needs to fully addressed before trying to run the machine as it could damage the motor.
Posted on Apr 13, 2017
The feed dog on my bernina 1130 is not working. IT will not pull the fabric.
Even if you select a longer stitch? Have the feed dogs been dropped for darning? Otherwise, your mechanical machine may be seizing due to old oil that has solidified.
Wheel on right side that controls the needle up and down is very tight...
Sep 08, 2017 | Bernina Sewing Machines
The bobbin assembly has a lot of tangled up thread and is jammed. How do I clear it?
Avoid attempting to run the motor if the machine is bound--it may damage the motor.
Remove the presser foot and, if you can, remove the needle. Then remove the needle plate, the bobbincase, and the hook. If you are unable to remove some of them, you may need to use a small pair of scissors to snip the threads and gently pull them out with needlenose pliers or tweezers.
Once you have the thread tangle removed, clean with a soft brush to remove all the lint and thread bits and place a drop of good quality sewing machine oil (preferably Bernina oil for your machine) on the bobbin race. Install a brand new needle (in case the old one was damaged).. RAISE the presser foot, remove all the thread, and rethread from the very beginning. (The raised presser foot releases the tension disks so the thread will seat properly.) Use good quality thread--avoid old or bargain bin thread (some Berninas object strenuously to Coats & Clark thread too). Some threads create heavy lint buildup in the tension disks and bobbin area in addition to hanging up in the needle and elsewhere. Also, some fabrics shed more (ie fleece), so be sure to clean often. Try to oil your machine as instructed in the owner's manual--every time you change a bobbin, after 8 hours of constant sewing, or every 6 months if not in regular use.
When Thread is Caught in Sewing Machine Sewing Lessons
How to Fix Thread Jam Sewing Machine
Anyone have experience with jammed bernina sewing machine Discussions...
Having trouble with my new Bernina 820
This video may help avoid thread nesting:
How and Why to Bring up the Bobbin Thread
Oct 21, 2015 | Bernina Sewing Machines
What kind of oil do I use for a bernina 830 record electronic
I agree with Tally Girl in using a good quality, preferably clear, light machine oil. Do NOT use 3-in-one or cooking oil as both will become "varnished" over time leading to a gummed up machine. I have been repairing both commercial ad domestic sewing machines for 45 years.
Jan 30, 2015 | Bernina Activa 130
I have a bernina 801 sewing machine. I am unable to dis engage the wheel to reload the bobbin, it will not turn
Have you ever lubricated it? Sewing machines must be periodically cleaned and lubricated or they will get stuck and freeze up
Nov 20, 2014 | Bernina Sewing Machines
Wheel goes halfway then gets stuck
If it's a mechanical machine, it could be seizing due to old, dried out oil. How long since it has had a thorough clean and oil? If this is the cause, AVOID running the machine until the problem is addressed or the motor can be damaged.
Dec 10, 2017 | Bernina BERNETTE 65 Mechanical Sewing...
Everytime I work with my pfaff performance 2056, demonstrtation model, it breaks.It is still under warrenty for another 6 months.The seller helped me the 1st time, but ever since with every problem he...
First of all you should never leave the pins in, it can cause to many problems, especially with this machine and the included walking foot. It also leads me to believe that you are trying to pull the fabric through while you are sewing. Never do that since this machine is well made to do the work all by itself. Only guide so it stays straight. Never try to pull the fabric though faster than what the machine will sew or you will have messed up timing and broken needles.
Apr 01, 2017 | Sewing Machines
The needle is getting stuck in the fabric on my Bernina 1008.
Sounds like it needs to be serviced. Needle should NOT be hitting the bobbin case.
Since you don't want to have it serviced, you might check to make sure the bobbin case is inserted correctly and that the bobbin rotates clockwise as you are looking directly at it in the case. Also, is you needle compatible with the fabric?
Jul 29, 2017 | Bernina Sewing Machines
Thumping noise
change the needle again, when you hear a thumping noise that
means the needle is either damaged or not the right one for the
fabric
adjust the top tension one letter or number higher till the stitch look
better
it show the machine name is bernina model is 440,, so I'm putting
in a link for a manual for the machine
http://www.bernina.com/getdoc/56b4ec85-1b1b-4d17-8519-e892adfa5fa2/032907-52-04_1103_a430_a440_a450_EN
if this is not the manual, then let me know & I will find you another
one.
Sep 05, 2012 | Bernina Sewing Machines
Bobbin jaming up
Clean the bobbin area.
Thread the machine with the presser foot up - always,
Make sure the bobbin thread is feeding clockwise and through the guides on the bobbin case.
Lower the threaded needle down and back up while holding onto the thread end. This will pull the bobbin thread up. Hold onto both threads and pull under the presser foot and to the back of the sewing machine.
Hold on to the thread ends and lower the needle into the fabric, then press the foot pedal.
You may want to use a leader - a folded scrap of fabric that you sew to the edge of and then **** against the fabric you want to sew. Sew off the leader and onto the fabric and this will keep the thread from going down into the machine. You can have a few stitches between the two to make it easy to cut the leader away.
When you stop to adjust the fabric make sure the needle is down to anchor the fabric (turning corners, sewing a curve. etc).
The slightest movement of the fabric when the needle is up will sometimes cause a thread jam.
Mar 11, 2010 | Bernina Sewing Machines
Sewing Machines Logo
50 people viewed this question
Top Bernina Sewing Machines Experts
Chris Wetmore
Colin Stickland
Colin Stickland
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
