SOURCE: My fabric won't advance.
Hi Jodyk...Remove your flatbed so you can access your bobbin area. Open the cover of the bobbin area. The shiny/bright components consist of the Bobbin, which snaps into the Shuttle Hook, which is contained in the Race. Immediately right of the Race is a pewter/matte silver colored lever. Press the lower portion of the lever to raise the Feed Dogs. Pressing the upper portion drops the Feed Dogs, and is commonly used to accomplish free-hand applique work......good luck my friend.
SOURCE: Kenmore Model (385.15108200) Fabric not moving
hi! there if your feed dog does not move the fabric forward or backward,if this is so try to run machine w/o the fabric check if feed dog move on cycle,the teeth should be moving upward and downward rotation pushing action on your fabric,the teeth should come out to the plate slot of feed dog.if not adjust upward, and adjust also the presser foot of needle.if your feed dog is not moving when machine running,thre is a mechanical disengage or loosen in shuttle assymble and feeder dog mechanism they link together ubder the machine,as the shuttle move on one stroke the feeder also move also with the needle.Chesk the adjustment and link mechanism.in addition to this try to clean feed dogs by brush chips thread and fabrics sometimes stored on mechanism of feed dogs and shuttle.
SOURCE: My kenmore 385 won't feed fabric
Check to see what pattern is selected. Be sure it isn't the buttonhole.Select straight stitch.Move the stitch length setting to 4.Turn the handwheel and see if the feed dogs move forward. Press the reverse lever and see if they move backwards. Select straight stretch stitch and turn the wheel to see if the feed dogs move forward and backward.Check the presser foot release on top of the machine and make sure there is pressure on the foot.
Sometimes the reverse assembly on this machine stops working because it has the wrong type of grease on it and it turns into a hard gummy mess that won't let it work.
sewman7
SOURCE: I have a Singer Stylist 513 & I cannot get the feed dogs raised.
The model 513 Singer has two gears which operate the feeding mechanism. If one of these gears is broken, the machine will run except the feed dogs will not move. This is a very common problem with this model.
