Question about Bissell Vacuums
How to remove back wheel from Bissell model 61Z4-F health home vacuum cleaner please?
Posted by Synelg Caasi on
5 Related Answers
Anonymous
  • 1673 Answers
SOURCE: My bissell vacuum cleaner has lost suction...
Sounds like either the hose or the inlet down by the brush roll is clogged.
Posted on Jan 09, 2008
Anonymous
  • 1673 Answers
SOURCE: need to download users manual/how to install brush belt
http://bissell.com/images/UserGuides/7901.pdf
same as 8901
Posted on Jan 17, 2008
Anonymous
SOURCE: Bissell Healthy Home
I had the same issue after using it daily for over a year. I checked everything and found no clog. I brought it to a vacuum cleaner repair center and they found a clog in the motor. It cost me $25 and was well worth it. I love this vacuum
Posted on Mar 01, 2008
Anonymous
  • 40 Answers
SOURCE: directions for Bissell upright rug shampoo vacuum
Indeed, losing directions can be quite frustrating. Below, I did some research and found a website which has most Bissell Vacuum cleaner manuals and directions online
http://homeappliance.manualsonline.com/manuals/mfg/bissell/bissell_product_list.html?s=gg314159
Hope this helps.
FerrariXP
Posted on Mar 17, 2008
Anonymous
SOURCE: Bissell carpet cleaner won't spray water on floor setting
I have the same problem, can someone help.
Thanks
Posted on Jul 30, 2009
I have a bissel proheat 2x health home shampooer. It is less than 1 year old and has benn used 3 time andd the brushes will not turn. Is there a reset button, I am overlooking?
If you haven't been cleaning the filters after each use now is the time to get that done. Turn the Flow Indicator Cap counter-clockwise and remove it. Lift the rotor out and under it is the filter. Clean and reinstall in the reverse order. Now under the Water Tank Cap is another filter that looks like a screen. Remove it and clean and replace. Now try your machine. If that didn't do it call Bissell Consumer Care at 1-800-237-7691
How do I clean my Bissell carpet cleaner model 47B2
Hi Susan. Cleaning the machine is easy. You'll need to remove, empty the dirt container, rinse thoroughly. Also, remove and rinse the foam filter.
Please refer to page 7 in the User's Guide for a complete list of cleaning tips.
Here's a quick link to download the User's Guide: http://www.bissell.com/user-guides/?cid=ccsocial
I was given a model 6591, plugged it in and it worked but didnt "****" and didnt sound right. I turned it off and removed the hose from the back found a badly plugged hose. Removed the hair...
The User Guide for the bissell Clearview Power Trak
http://canada.bissell.com/images/UserGuides/3590C.pdf
May not be your exact model but should be similar.
The Bissel vacuums include an internal thermal protector to protect it from overheating. When the thermal protector activates, the cleaner will stop running. Should this happen proceed as follows:
1. Turn the cleaner OFF and unplug from electrical outlet.
2. Check the Pre-Motor Filter and Post-Motor Filter for dirt accumulation.
3. Remove any clogs.
4. When the vacuum is unplugged and motor cools for approximately 30 minutes, the thermal protector should automatically resets and cleaning may continue.
5. If the thermal protector continues to activate after following the above steps, your cleaner may need servicing. Call Bissell Customer Service:
http://canada.bissell.com/Contact_Us.aspx
What kind of belt do I need to fix my vacuum?
Healthy Home Bagless upright vacuum cleaner replacement belt. Genuine Bissell part number 203-1329 or 2031329. Fits All Bissell Healthy Home, and Heavy Duty models including; 5770, 5770-5, 5770-8, 5770-P, 5990, 6100, 6405, 50C9. Belt contains the following code MS 3M-243-12 written on the outside.
1helpful
4helpful
2answers
How do you change the belt on a bissell 5770
The Bissell 5770/Healthy Home vacuum is actually fairly easy to change the belt on. The main thing you will need is a T20 screwdriver with at least a 4 inch shaft and a Phillips-head screwdriver. Four of the six T20 screws on the bottom plate are easy to locate, the last two are set deeper into the vacuum near the wheels. Once you have taken all six T20 screws out you will have to release the lock preventing the vacuum from tilting back so you can easily remove the top plate and gain access to the brush assembly. With the top plate off you will notice four Phillips-head screws holding a cover plate over the brush, simply remove them and you have full access to the belt.
1helpful
Have lost my instruction manual for my bissell PROHEAT PRO-TECH 7920E pLEASE CAN YOU HELP ME J Mills
Bissell has online USER Guides... for your model
CLICK HERE you can click on the user guide under your model to download a fresh pdf copy
Happy Cleaning!
Bissell powerwash upright deep cleaner 1690 j
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
werw
Water and soap coming out wheel area
heatman101
fddf
Vacuums Logo
Top Bissell Vacuums Experts
Mike
Gerry Harvey
Gerry Harvey
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
