SOURCE: Kenwood basic M2 Amp Lightning strike
you can check the output transistors for short circuits with the low ohms range or diode checker . If they have failed, then it is often a good idea to replace all as much stress can be placed on an output array in this type of failure. to repair reliable, all outputs on an offending channel should be replaced.
Make sure the fuse you replaced was the same type of fuse. check markings.... T stands for sloblo... a fast blo duse may let go at turn on. The power supply may have a shorted rectifier diode in it also.
be aware however, every time a fuse of that rating blows... more damage may be occurring to the amp.
SOURCE: Alarm on "9000" displayed
Issue:
ERROR LCD: Error code (5xxx through 9xxx) appears on the display
1.
Press ON/OFF switch to reset the multifunction device
2.
Press Stop/Reset and ON/OFF to reset the printer
3.
The MP530 may require repair
SOURCE: lightning strike and tv picture messed up
This unit needs to be sent or taken in to a service center for complete testing and service. The lightning strike has caused a component failure, in the main board of the television. This is the board that controls all the functions of the television. The customer service telephone number for Insignia is 1-877-467-4289. You can also go to the website www.insignia-products.com. Go to the customer support section and ask them for help getting you television evaluated and serviced. I hope this information helps you solve your problem.
SOURCE: My Bose Wave radio died after a lightning strike
There is 0,5A fuse inside the unit. If that is blown, you can replace it.
SOURCE: sears model 139.664300 garage door opener - after
There is no reset button and due to it's age no parts available for this model.
Testimonial: "Thanks, that's what I was afraid of hearing, but I appreciate knowing that it is a lost cause so I don't waste more of my time trying to fix it."
