Question about Dryers
Parts for old inglis dryer
Looking for parts for 2 old dryer inglis model JO94580DR 1 and Lo89080 door switch for both
Posted by leffaceur on
  • leffaceur Nov 26, 2007
    Thank you for trying but could not find the part i was looking for , still searching.
    Thanks
  • Anonymous Mar 20, 2014
    The black plastic outer door ring has fallen off of my dryer. It looks like the plastic screw holders are broken! Parts breakdowns are very intimidating, not clear if these are part of the Outer Ring?!
James Greene
  • 240 Answers
Http://www.myapplianceparts.com/index.asp
These people can find a lot of hard to find parts. I know Inglis is owned by Whirlpool now, but dont know the age of yours, or how long ago this happened. Door switches were pretty much the same, so it shouldnt be to hard to find what you need. Let me know if you need any further help. Jim
Posted on Nov 22, 2007
  • James Greene
    James Greene Nov 26, 2007
    Do you have a way of sending me a pick of the switches. And could you verify the model numbers once again. They must really be old if thats the correct model numbers. I have some people that we refurbish very old units for, they love the older models, that might be able to get there hands on older and discontinued parts from somewhere. I will keep in touch with them and you both. Have no doubt, we'll find your parts somewhere.
  • James Greene
    James Greene Dec 16, 2007
    Also, just to let you know, Whirlpool has owned (or partnered with) Ingles for quite a while now. I would bet that a Whirlpool part would probably work (or will be the same) somewhere. I dont know what part of the country your in, but if you have access to a phone with 800 support, call this number. 1-800-241-4527. This is a number for Appliance Parts Warehouse. They might be able to help you out as well. Make sure you have your model numbers handy. If this doesnt work, let me know, I will still be trying. Jim
Will not turn on
Don't know much about them but wondered if it normally allows you to open the door while it's running and automatically stops. If so maybe there's a switch that closes when you close the door thats not working.
Jan 25, 2012 | Whirlpool Dryers
Tip
How to fix your dryer if it does nothing
kenmore, whirlpool, roper,estate,kitchaid,inglis,most of the time if your dryer does nothing you have a bad door switch or blown main fuse,to replace the door switch remove the 2 lint filter screws(top lint filter)pull the top toward you and up,remove 2 screws on old door switch,install new one,to check for a blown fuse remove the back look down to your left and you will see a small white fuse,that is the main fuse-mike
on Feb 11, 2010 | Dryers
My dryer was running but all of a sudden it just stopped and there was no power whats wrong?/
Well if you have this:
11_6_2011_6_00_12_pm.jpgor this:
Then yer fuse is gonna melt and kill the door switch circuit. It will be just as if the door was open.
Clever ain't it?
The fuse and dryer heat control klixon sit on the blower housing:
I recently cleaned up 2 diff styles of dryers made by wp:
2 wheel model
4 wheel model
More here
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 04, 2011 | Whirlpool Inglis IP8200 Dryer
Dryer runs but wont heat
There are 2 possibilities for this problem.
1. The limit switch is out. The limit switch is located on the heating element on the back of the dryer. This is a small button type part. it will have 2 prongs on it for 2 wires that slide on for power.
2. The heating element is out. This will be on the back of the dryer and depending the model it should be a long metal piece that has metal elements inside of it to heat the dryer. or it could be a large round unit. these can be tested with an om meter.
The limit switch will be the cheapest to start with on replacing.
If you need further assistance please do not hesitate to ask. I will need the make, model, and the serial number of the unit to help you further. the model and serial number can be found by opening the dryer door and looking by the hings. there should be a sticker with this information on it.
Apr 13, 2010 | Kenmore 64852 Electric Dryer
Heat cycle stops/goes off
  1. Changing from 3 to 4 wire hookup on a electric dryer
  2. Door switch replacement help for a common door switch
  3. Dryer basics - Venting problems and power supply
  4. Dryer basics - timers and how they work
  5. Dryer basics - power cord problems
  6. Dryer basics - dead dryer
  7. Dryer *general* repair flow chart....Click here
  8. Gas dryer smell
  9. How do dryer thermostats work?
  10. How long can my dryer vent be in length?
  11. How to change a common rear drum seal
  12. How the belt is suppose to look at the motor and idler pulley
  13. Help on replacing dryer motor and some wiring tips for the 279827 motor
  14. Help on replacing dryer motor and some wiring tips for the 279787 motor new25.gif
  15. Help for storing an appliance
  16. Important Disclaimer
  17. I dropped something down the lint filter area....help!
  18. Inglis, Whirlpool and Kenmore most common style dryer - how to take apart ( lint filter on top )
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show( lint filter on top )
  20. Whirlpool or Sears dryer with heater on the floor and four rollers for drum style - take apart helps ( lint filter in the door )
  21. Inglis, Whirlpool and Kenmore electric style dryers - no heat problems
  22. Inglis, Whirlpool and Kenmore electric element changing procedures
  23. Inglis, Whirlpool and Kenmore dryers - air flow
  24. Inglis, Whirlpool and Kenmore style dryers - noise problems....drum rollers and idler pulley information....
  25. Inglis, Whirlpool and Kenmore style dryers - belt change
  26. Inglis, Whirlpool and Kenmore dryer general motor problems
  27. Inglis, Whirlpool and Kenmore gas style dryers - no heat problems
  28. Inglis, Whirlpool and Kenmore dryers - where are my thermostats
  29. If your drum belt looks like either of these....change it!!
  30. Idler pulley slide troubles with newer Whirlpool build Roper dryer
  32. Newer style Whirlpool - Inglis - ( some ) Kenmore dryer front drum support ring install help
  33. Pilot flame help
  34. Sample wiring diagrams
  35. Test for ohm meter checking on electric dryers with no heat
  36. Taking apart an Duet or HE3 dryer for a belt change
  37. Taking apart a Whirlpool Thin twin washer/dryer to replace the belt
  38. Timers and some common Auto dry troubles and solutions
  39. What is a grounded element?
  40. Whirlpool - Kenmore dryer motor problems in the dryer with Even HeatControl....info on this is here + new25.gifExpanded repair helps for a common "Even Heat" dryer
May 15, 2009 | Whirlpool GGQ8831L Gas Dryer
Whirlpool gas dryer turns on drum spins exhaust is clear and blows air but it wont ignite
  8. Gas dryer smell
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show ( lint filter on top )
Mar 30, 2009 | Whirlpool LGR8648L Gas Dryer
Whirlpood dryer Model LER8620pwo Above dryer will not start. I've checked circuit breaker. I disconnected door switch thinking that would be the same as shutting dryer door; therefore, starter switch...
Pull the dryer out and unplug. At the bottom left of the back you will see your blower housing. on it you will see a 1 inch by 1/2 inch white thermal cut out. This is the part you are looking for. it is part number 3392519
This part is available and cost$18.00 to ship it to your door.
Mike Anderson
Anderson Appliance Repair
(865)945-3808
Dec 01, 2008 | Dryers
Dryers Logo
559 people viewed this question
Top Dryers Experts
Marvin
Marvin
Mike
