Computers & Internet Logo
Alan Matzke Posted on Apr 11, 2017
I have a Toshiba laptop that when it changes pages I get this flash that looks like a neg. photo, any suggestions on what is going on?
I did notice that I have a wireless mouse plugged into the USB port and if I pull that out and reinsert it the module in the port flashes then also. the graphics driver is updated and yes I am using windows 10, it does it plugged in or on battery.do you know if I uninstall the driver for the graphics card and then just do a restart is that doable ?
5 Related Answers
Anonymous
  • Posted on Jan 25, 2009
SOURCE: System freeze
The issue was resolved by uninstalling SP3. I uninstalled SP3 and the USB PCI card and rebooted. When SP2 reinstalled the device it installed the corect driver (5.1.2600.2180) and everything is now functional. Have no idea why the correct driver was not in XP SP3.
Anonymous
  • 9 Answers
  • Posted on Jun 10, 2009
SOURCE: red light flashing top of logitech wireless
The flashing light could be a reflection from the LED and mirror or laser on the bottom of the mouse. I had this similar problem and it drove me nuts until I happened to hold it up to a mirror and noticed the flashing was in sync bot top and bottom of the mouse.
Anonymous
  • Posted on Dec 05, 2009
SOURCE: Microsoft Wireless 4000 Mouse - No Red Light on Base
The red laser light stopped working on mine and it turned out to be the connetion between the battery tray and the circuit board. There is a metal tab on the circuit board and a matching one on the battery tray. When the battery tray slides in correctly the two tabs touch and viola (!), my red laser light came back on. Maybe one tab or the other got bent when I slammed the tray in crooked when replacing a battery- who knows.
Anonymous
  • Posted on Feb 18, 2010
SOURCE: wireless mobile mouse 4000, usb gets hot, and usb not recognized
I have this same problem right now... What did you end up doing?
gggg
  • 904 Answers
  • Posted on Aug 20, 2010
SOURCE: Dynex wireless mouse DX-PWLMSE won't work
The mouse should be Plug and Play. Did you install the drivers before plugging the mouse's receiver in? The PC has to have the drivers first in order to take advantage of the Plug and Play capability. If you plugged the mouse's receiver in before installing the drivers, unplug the mouse receiver, uninstall the driver, reboot your PC, reinstall the driver, then plug the receiver in and you should be fine.
Otherwise, press the Connect button on the receiver first, and then the Connect button on the mouse, and that should establish the connection. You don't need to disable your touch pad in order to use the mouse.
A205 speaker replacement
http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/laptop-disassembly-1.htm
1) Remove ALL power. Remove the AC adapter (Charger), and Battery.
2) Suggest lay a soft Static Free cloth, on the table you're working on. Helps prevent scratching the table, and laptop.
Use a multi-compartment container for the various screws you will remove.
Label each compartment for the area the screw/s come out of.
SOME screws look VERY similar to other screws.
Advise DO NOT mix them up.
You're going to remove the Top Cover. BEFORE this is removed you're going to need your ESD wrist str-ap on.
Electro Static Discharge
Your body carries Static electricity. Static WILL fry out, (Short Circuit), the delicate hardware components in a computer.
Wear an ESD wrist strap, have it's alligator clip attached to a good ground source; and your laptop is safe from Static.
Average cost is $3 to $6. Here is but one example,
http://www.radioshack.com/product/index.jsp?productId=2103245
The Processor (CPU) is the MOST susceptible hardware component to Static Shock!
Don't wear an ESD wrist strap, and have it's alligator clip attached to a good ground source; and you can use your laptop for an expensive doorstop, or conversation piece. (Oh that? Yeah, Static got it")
[Page1::Page2::Page3::Find another model; is on the Top and Bottom of all pages in White ]
Go to Step 1 and follow through to Step 17 on Page 3.
The Keyboard Bezel has to be removed,
Keyboard,
Display Assembly,
Top Cover. (Palm Rest Cover),
plus the other components to facilitate removal of the above.
In Step 17 you see the Speakers. They are a large unit that can only be accessed for removal, after removing the Top Cover.
Look for a part number on them. It is a Toshiba part number.
Put Toshiba + part number, in your browser search bar, and look for replacements. (No -> + )
http://www.discountedlaptopparts.com/toshiba-satellite-a205-left-and-right-speaker-set.html
Just for a point;
The above speakers look similar (To me), to the ones in the Irisvista link. (Pictorial disassembly guide)
Searching just now out of curiosity, I saw different styles shown, for the Satellite A205.
Point being I would want to see a PHOTO of what was being sold, to see if it is the right one. A lot of ads for Toshiba Satellite A205 speakers, didn't post a photo.
Could be different speaker examples for the different model numbers, of the model series.
(A205 is the Model Series. The number/letters after that designate the Model Number)
Seems that Toshiba STSA205 is the number, but you will know when you remove the speakers.
For additional questions please post in a Comment.
Regards,
joecoolvette
Toshiba satellite A200-27Z power cord led flasing failure to post will try any suggestions
Have you tried another Cord with the EXACT same power specs? Remove the battery. Has the cord/charger/transformer been damaged? Has the AC jack been damaged? Due to pulling on the cord while plugged in? At the AC jack "wiggle" the plug a bit to see if the plug and AC jack are making a good connection or Loose. Sounds like a loose AC connection.
2answers
Can't find hard drive on my toshiba satalite toshiba a35-s159
1) Make SURE you remove ALL power before removing the Harddrive.
Remove the AC adapter (Charger) and Battery.
2) http://www.irisvista.com/tech/laptops/toshiba-satellite-a35/complete-disassembly-1.htm
Page 3
Go down to Steps 19 and 20. Click on the photos to enlarge,
http://www.irisvista.com/tech/laptops/toshiba-satellite-a35/complete-disassembly-3.htm
[ The page numbers are in white at the Bottom, and Top of the pages.
Page1::Page2::Page3::Page4::Find another model ]
Regards,
joecoolvette
Hello there,My name is Mario, I have a Toshiba laptop, model 4060CDT. Owner/client wants to have a new system reinstalled and because it was a gift from a relative, there is bios password protected. I mdid...
The only solution is go to www.pwcrack.com check the top part of the page click "bios" scroll down to Toshiba and click, next scroll down the page for your model, Toshiba Satellite 4060CDT- Parallel Security Access Key- $39.50 click it so the right part is sent to you.
My toshiba laptop is askingn for a password to turn on. I know this relates to the cmos battery. I have the toshiba satellite A215-S7413, how to i get to the cmos battery?
How to get to the CMOS battery
The Toshiba Satellite A215-S4747 Notebook PC's CMOS battery, is soldered to a bracket on the bottom of the motherboard.
The laptop has to be completely disassembled to access it.
In this photo showing the bottom of the motherboard, the CMOS battery is in the middle,
http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/big/toshiba-satellite-a200-a205-21.jpg
This is a link to a free Service Manual, detailing disassembly,
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-toshiba
Go to the 11th line down. The one that starts with Satellite A10
Go across and click on A215
This is a PDF file. It may take up to 30 seconds before you see the first page, and additional time to fully download.
Suggest you let the file download all the way before looking through it.
1) Remove ALL power to the laptop. Remove the AC adapter (Charger) and Battery
2) Observe Anti-Static Precautions
Suggest you bu and wear an ESD wrist strap, and connect the alligator clip to a good ground source.
Average price is around $3 to $6.
3) Use a multi-compartment container for the various screws you will remove.
Mark each compartment for the area the screws come out of.
There may be as many as 60 screws and 12 different types.
Do Not mix them up.
(You can use a clean egg carton in a pinch. Mark each egg holder)
1helpful
2answers
What colour is the main coax cable for the wifi card ?
It's a White wire, and a Black wire.
I have no idea why it's named a COAX cable (Coaxial cable) since there are TWO separate wires,
and no shielding on the wires. (Just plastic insulation over the wire)
http://en.wikipedia.org/wiki/Coaxial_cable
Supporting data;
1) http://www.irisvista.com/tech/laptops/Toshiba6100/Toshiba_Satellite_Pro6100_dismantle_2.htm
Step 11. (You can click on the photos to enlarge)
This is on Page 2::
2) Toshiba Satellite Pro 6100 Service Manual, (free)
Go down to the line that starts with Satellite Pro, then go across and click on > 6100.
PDF file. Give at least 30 seconds for the first page to come up, and there may be additional time required for the file to fully download.
Suggest you let it download all the way before looking through it.
[ Took almost 60 seconds for me with a medium speed DSL connection ]
Page 7. (Reduce the view to 100 percent to see the page, then enlarge the page to view the Wireless LAN card wires)
4helpful
Cant access laptop apart from boot menu f5 f12...keeps saying tring to fix windows but not getting anywhere...i have alot of photos on there i do not want to lose...have toshiba recovery disc but that will...
Hi There, try booting in safe mode to download your photos to a flash drive or cd. When you first turn on laptop, and see the curser upper left side of screen, keep pushing "f8" to enter safe mode boot. Select "safe mode with networking" and continue on to save pics. Good Luck...
1helpful
I NEED A FREE USERS AND REPAIR MANUAL FOR A TOSHIBA LAPTOP SATELLITE A55-S1064 COMPUTER MANUALS DOWNLOAD.
This, is a link to Toshiba Tecra A2 disassembly guide, with photos and instructions. The Satellite A55 uses the same disassembly instructions.
http://www.irisvista.com/tech/laptops/Toshiba-Tecra-A2/notebook-disassembly-guide.htm
At the bottom you will see Page 1: Page 2: Page 3: Page 4:
When you go to the link, you will be on Page 1.
I don't have any information on a users guide at present, but will post back when I do.
You may also find this useful,
Laptop freezes when loading photos from SD card
This sounds like microsoft have updated updated windows quietly and in dooing so have broken the drivers for the card reader or dvd - another alternative is your onboard memory is faulty - the first should be easy to fix - go to the toshiba driver page here ->
www.toshiba.com
and look for the downloads pages for your machine - see if there are new driver packages and install them. If this does not fix the problem then I suggest downloading a small memory testing program - available from many places - just google - and check your system memory for faults.
if it does show faulting then contact toshiba for replacement memory if its still warrantied or take it to a reputable dealer if not
hope this helps - cheers
Toshiba Satillite A100 not powering up
hi
again $ again try 3 or 4 time to powerin on with ac mode,if not powering on then try it in backup mode with support battery if u dont have battery backup then get a battrey from any other laptop but it must be same model if powering on then change your adapter and try again if then also not warking go to nearer vender or service center.
by by.
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
