Question about Ricoh Aficio Office Equipment & Supplies
Richo afico 5002 code sc 878 - Aficio Ricoh Office Equipment & Supplies
Freckled legs
    Habit-Forming:
    Scholar:
  • Ricoh Expert
  • 129 Answers
1. Improper firmware update.
2. SD Card size greater than 2 GB used.
3. Multiple ROM data folders in SD Card.
4. Improper Java firmware update.
5. Power failure during firmware update.
6. Power line issues on the outlet.
Replacement of the Controller Board is necessary in case SC Code 878 occurs.
Posted on Apr 13, 2017
5 Related Answers
Anonymous
SOURCE: Error code sc 500
check the developer gear...txt me at 09275514418
Posted on Oct 27, 2008
Anonymous
SOURCE: error code sc 541
I have infotec machine when I powered machine a error code genereted sc 541 what is the solution?
Posted on Nov 10, 2008
Anonymous
SOURCE: richo copier 1060,error code sc-501
what is error SE541 on Ricoh 1060
Posted on Mar 27, 2009
joel_baleta
Joel Baleta
  • 155 Answers
SOURCE: What is meant by error code SC 403 of RICHO AFICIO
SC 403 is a Transfer belt position sensor error
The transfer belt position sensor does
not activate even if the transfer belt
contact clutch has been switched on
twice and rotated once. Pls check if
Main motor/drive, Transfer belt contact clutch if defective, Transfer belt position sensor
if defective. or your Photo sonductor drum/PCU carriage unit does not turn or stock up or not inserted properly.
Posted on Jan 24, 2010
santosj27
santosj27
  • 263 Answers
SOURCE: my aficio richo 2016 black
This error code is related to a overheat in the Fuser Unit.
Probably you have a faulty thermistor.
I advise you ito call a technician. But you can do this procedure to see if you can work while technician does not arrive.
Press yellow key.
Press 107 on the key pad.
Press red key at least 5 sec.
Press copy SP.
Exit all the way out and turn the machine OFF and ON.
I think did may help you.
See you!
Posted on May 11, 2011
Sc 878 error how can i resolve it Sc 878 erro como posso resolver
Bad controller board (where the print cable plugs in) try reseating
Nov 25, 2013 | Ricoh Aficio MP-C305SPF Color Copier :...
After replacing the main motor of my richo afico 2018 the copy result reduces is the cause of mismatch main motor?
Yes, If you have installed a main motor from Aficio 1015 the machine will work and there will be no SC Code displayed, but the machine will print a reduced image.
The part number for the main motor for Aficio 2015 is :
" AX06 0270 Brushless Motor 24V/20W "
Oct 05, 2013 | Ricoh Aficio 2015 Copier
Eror sc 878
sc 878 error what is the solution
Aug 07, 2012 | Office Equipment & Supplies
Richo error code sc 829
I have Aficio MPC 2550 and it displays Sc 829. Is the a way to reset this code?
Apr 05, 2012 | Ricoh Aficio 1035 Copier
Sc code
Go to sp mode press Clear Modes 107 and press Clear Stop for four seconds. Screen will change enter to SP Modes. enter 2109-1 and execute. then enter 2109-2 and execute. That should do it.
Nov 11, 2008 | Sharp AR-5316 Advanced Digital Imager...
Error code sc 541
Sep 21, 2008 | Ricoh Aficio 2018D All-In-One Laser...
Err0r sc 541
Hi
fuser code your thermistor is bad
good luck
Afico 3235
SC Waste toner full
Empty the waste toner, it shoukd go away. Look on the right rear side there should be a door, inside should be a big white plastic container 3/4 full of toner.
Sep 05, 2008 | Office Equipment & Supplies
Error sc 422
I HAVE THE LASER C522 AND I HAVE PROBLEM TELL ME REPLACE WASTE TONER
Feb 10, 2008 | Ricoh Aficio CL2000N Laser Printer
Open Questions:
1,410 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Bernard D'Souza
Timothy Van Der...
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
